Few running issues (video)
DonnellyShard
PostPosted: 00:03 - 29 Dec 2016    Post subject: Few running issues (video) Reply with quote
Hi everyone. Picked up a 2013 lexmoto xtrs 125cc on the cheap. On the book its a 125-23 engine. Ive adjusted the valve clearence to the following. Inlet 008, outlet 011 (wansnt running at all before adjustment, was just all wrong). video below explains most of it though sorry for mic going shit when running but bike went very loid. Any help mich appreciated. Thank you.
https://www.youtube.com/embed/vcJMt-veayA
jaffa90
PostPosted: 01:00 - 29 Dec 2016    Post subject: Reply with quote
Running rich, smelling, no choke to start it??????????
Sounds like the choke is stuck on or the carb is flooding ?????????
Have you any leaks under the bike????????????
WD Forte
PostPosted: 01:04 - 29 Dec 2016    Post subject: Reply with quote
Partial credit for the vid effort
but its dark, crap sound when engine running
( cam mic may be too close, back off !)
and you don't keep the bloody camera still
So, 0.008 and 0.011 eh? what? inches or mm?
I'd expect the valve clearances to be around say 0.1mm inlet and
0.12mm exhaust or 0.004 and 0.005 inches/thou
Why no electric start? one of my lads has the Arrow version
probably same or similar engine and all quite simple really
so hopefully it just needs a bit of TLC.
bikers smell of wee
WD Forte
PostPosted: 01:11 - 29 Dec 2016    Post subject: Reply with quote
Just had a google and see the XTRS uses the 156FMI
so, its an OHC engine.
The lads previous bike had similar and we found the cam chain tensioners
are piss poor and can easily work loose.
I'd want to inspect the valve timing to see if it's slipped at all
so would remove the cam sprocket side cover and crank case plug and see if the marks line up
bikers smell of wee
DonnellyShard
PostPosted: 01:52 - 29 Dec 2016    Post subject: Reply with quote
Cheers for the replies guys. Nope no leaks from what I can see. Choke lever aint stuck open . Yeah sorry for quality, holding a 10 inch tablet after a few beers proves to be a task in itself lol. Does have electric start but battery is knackered and couldnt be bothered to get my booster out in the dark. Yes inlet is .008 (.203mm) and outlet is .011 (.279mm) . Reason for this is because I was told that the stock settings is 008 inlet and 015 oulet, though 015 seemed very tappy so I reduced it slightly. Saw one of the guys on here has set both inlet and outlet to 008and it runs nice so I may try that and fiddle with the carb. See how it goes. If still bad I will have to take your suggestion and check.the chain timing, which I can tell will irritate me if its wrong because of lack of space to work around the frame. Ive turned lazy to what I used to be. There was a time id look fir an excuse to rip a engine out
The last post was made 9 years, 278 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.61 - MySQL Queries: 14 - Page Size: 43.71 Kb
