Exhausts from China/Ali-Express type
definitelyinc...
PostPosted: 15:17 - 13 Jan 2017    Post subject: Exhausts from China/Ali-Express type Reply with quote
Hello everyone,
Has anyone got experiences purchasing exhausts from Ali-Express and other places, where the exhausts come from China, I'm looking at them, full systems, for (what look to be) my bike (2013 ER6N).
I'm tempted of spending £150/200 on one of these rather than £400/500+ on the branded exhausts, as it will take a while for me to save up, considering I've also got other modifications planned, and this is by no means the most urgent purchase.
Has anyone purchased any of these unbranded exhausts for their bikes, experiences?
https://www.aliexpress.com/item/ER6N-ER6F-NINJA650-Motorcycle-Exhaust-Muffler-for-Kawasaki-ER6N-ER6F-NINJA650-2012-2016/32788764419.html?
https://www.aliexpress.com/item/GT-Motor-Full-Exhaust-System-and-Carbon-Fiber-Muffler-for-Kawasaki-ER6N-ER6F-Ninja650R-2012-2016/32687766769.html?
(Slip ons are not an option as my exhaust is a one-piece, unless I invest in older headers, I have to invest in a full system)
Bonnie Lad
PostPosted: 15:29 - 13 Jan 2017    Post subject: Reply with quote
Superb, another 'what tat can I stick on my commuter shed' thread from raptor1223455xxxL4lyf
Protip: learn to ride the thing first Thumbs Up
definitelyinc...
PostPosted: 15:35 - 13 Jan 2017    Post subject: Reply with quote
I'm doing my best to learn riding it as well as I can Smile
And yes, I'm asking whether people have experiences of sticking said tats on their bikes. Smile
tom_e
PostPosted: 16:01 - 13 Jan 2017    Post subject: Reply with quote
Can you not just chop the original can off and put an aftermarket slip on on the end? This is the only way to fit a new end can to my bike so it's not unusual.
definitelyinc...
PostPosted: 16:10 - 13 Jan 2017    Post subject: Reply with quote
You mean welding? It's possible I guess, but at the same time I could get this full system for (probably) less than a branded slip on even lol.
So far I found 1 or 2 posts that didn't have many replies but the ones that did said they were surprisingly good, I'm just hoping for some more replies with this being a large forum, it certainly seems like a good option at this point.
If I decide not to go down this route rather than chop I'll most likely grab headers from a previous generation and slip a slip on with that, as they are interchangeable from what I hear Smile Thumbs Up so this is the next option for me if a full system doesn't workout.
I am struggling to find any used full systems for mine, however if I go for last gen i could probably find a fair few I'd imagine.
Thank you for your suggestion though! Smile
Last edited by definitelyincompetent on 16:11 - 13 Jan 2017; edited 1 time in total
redeem ouzzer
PostPosted: 16:11 - 13 Jan 2017    Post subject: Reply with quote
Save the money for a sportsbike when you get a proper licence.
Or some track days.
Be a REAL MAN!
definitelyinc...
PostPosted: 16:18 - 13 Jan 2017    Post subject: Reply with quote
Or some track days.
All in good time my friend Smile
This isn't even about racing, I'm just rather jelly of all the throatier bikes that I see and want mine the same way.
Track days will be a maybe for me, once I get my bikes upgrades all in order and once I sort out (hopefully) my second bike, tough life of an apprentice Smile
tom_e
PostPosted: 16:28 - 13 Jan 2017    Post subject: Reply with quote
No need to weld anything, slip ons can be clamped onto the existing pipe.
I've got a cheap Chinese slip on from Aliexpress as I wanted to try a stubby one, it's now in my shed as a backup. It weighs an absolute ton and the quality is a bit rough if you get up close.
I wouldn't want to try they're full systems I imagine they'll rust through pretty quickly, fit won't be great and they'll probably add weight rather than take it away.
definitelyinc...
PostPosted: 16:41 - 13 Jan 2017    Post subject: Reply with quote
Lots of forums saying I'd need to weld it on, can't confirm though.
ER6N has a fat exhaust, 7.9KG, apparently the one on there is 5kg and another is 3.5kg, according to ALI-Express it's refundable if not as described, so then I can just ask for a refund if I weight it and find it to be heavier.
Regarding the rusting there's ways to prevent it and clean it, if it turns out really bad I'm sure I will be able to replace it, once it does go really bad, I'll just have to do my best to prevent it if it's an issue Smile
Also since you did buy one, how was the sound?
Baffler186
PostPosted: 17:21 - 13 Jan 2017    Post subject: Reply with quote
it will be as described, you'll get an exhaust. You won't be able to return it in 6 months if it starts to rot. You can't keep the inside clean and oiled, that's where it'll start.
Why don't you get a used, branded end can. Chop yours and get the correct size gasket. You can use all sorts of gauze, putties and sealants, but if the sizing and gaskets are appropriate you should get a good seal. Not much point (IMHO) shelling out for a low quality full system, if you only want a louder can.
definitelyinc...
PostPosted: 17:25 - 13 Jan 2017    Post subject: Reply with quote
The item is as described, yes, an exhaust, but the description claims 5KG, if it turns out more then it's not as described surely?
Anyway, other points noted, might just fork out on a used end can for previous gen provided I find a cheap enough can for previous gen, current gen has none at all as it's seen as a full system only bike, and to get something going it's either chop or previous system headers and can.
Going to research soon, at work right now so I shouldn't be doing this :s
P.
PostPosted: 17:48 - 13 Jan 2017    Post subject: Reply with quote
Call delkevic. Ask for their assistance.
Petemate
PostPosted: 19:00 - 13 Jan 2017    Post subject: Reply with quote
From experience, the following:-
During the (budget) restoration of my little 250 Custom Honda, I purchased a full system from The Motor Lodge. Cost 110GBP. It is rusting badly, and the appearance leads me to believe that there was just a quick layer of chrome plate applied straight to the bare metal with no other treatment first.
For the cost, I suppose the system is good performance-wise. However, as I do not see what I could possibly have done to avoid the rusting. I am regarding the system as a 'consumable' item. The original is no longer available new, (the bike is virtually a CM125C but for bore and stroke) and even if the CM125C system was available OEM new, no good as with the engine being a shorter bore, the second radii of the headers would foul the underside of the engine. So I will thoroughly flatten what remains of the finish on the silencers and pop on some silver BBQ paint to make it last a bit longer. Strangely, the headers seem to be holding out without bad rusting but of course are very discoloured.
We will see how it goes. I suppose 110 quid every 4-5 years is not bad, and it may even last a good bit longer.
Motad not available. Pattern silencers could be obtained and fitted but who is to say how long they would last? Cheapest seem to be about 35 quid each, higher quality ones double that but still no guarantee of good chrome. If the original was available, I would have considered purchase when I was doing the resto but I bit the bullet and went for the el cheapo.
So whatever bike I end up with in the future, I will be tempted to go for original even given the cost. Depends on how long one keeps a bike I suppose.
My bad.
82 not out....1983 Honda LA250 Custom
2008 Saab 9-3 1.9 Tid 150 Vector Sport estate
2005 Stirling Eccles Topaz 2-berth
331X2
PostPosted: 21:46 - 13 Jan 2017    Post subject: Reply with quote
Don't do it, 180 degree twins sound shit with loud exhausts. I know this because I ride one...
PostPosted: 09:38 - 14 Jan 2017    Post subject: Reply with quote
It'll fall to bits quick smart.
Black Widow, SP Engineering or Delkevic if you want UK based cheap tat. Will probably last a little better.
wots
PostPosted: 11:54 - 14 Jan 2017    Post subject: Reply with quote
Delkevic is cheap for this bike, about £130, removes the cat and silencer.
BUT, it sounds seriously shit and seriously loud, ear plugs were never enough, don't forget it is right underneath you. My bike was always one of the loudest on rides, but not in a good way. It was awful.
For the love of god, just don't.
SkyBadger
PostPosted: 12:14 - 14 Jan 2017    Post subject: Reply with quote
you can probably find videos on youtube which will give you an idea what these exhausts sound like fitted.
https://www.youtube.com/watch?v=DPjj8RiPLy4
If you are after a budget exhaust I would recommend the SP engineering ones.
definitelyinc...
PostPosted: 11:29 - 15 Jan 2017    Post subject: Reply with quote
Cheers mate, Black Widow don't seem to be doing any full systems for my gen, SP Engineering same (but I would be considering them if I go down the header route), Delkevic seem to have exhaust systems for £250 which is apparently not road legal, and around £300 for a road legal one, if I get the one for £250 then I' m more or less just £50 off the Chinese system (Exhaust + Massive delivery fee).
@Paddy. - What's the need to call them? Am I likely to find an even cheaper solution you think?
@wots Which one is £130? If you mean the slipon then I'd also be getting headers, at which point I'm spending same as a full system, that is if that's what you meant though... I really need a loud system tbh, I'm noticing a big difference from when I ride with friends who have mostly invested in aftermarket systems. Aside from that I don't think the Delkevic sounds bad from the video? Sounds rather throaty, am I missing something?
@skybadger Sounds really throaty for me, I like it! I was going to look for the chinese ones, but if I can grab a UK based manufacturers sytem for £250/£300 (depending on whether it's worth investing in £50 for road legal stuff) then the Chinese ones aren't really worth looking at I guess!
I mainly saw systems for around £500+ and thought that's what I'd have to fork out, thank you guys. Smile
ThatDippyTwat
PostPosted: 13:35 - 15 Jan 2017    Post subject: Reply with quote
My Chinese "pit bike" can is decent. My UK sourced downpipe has already got surprising amounts of corrosion. It's the fastest I've ever seen this much orange fur appear.
I think it's pure luck, or just knowing the quality of parts (Importer, specialist Chinese distributor etc). If you plan on keeping the bike, get a decent stainless system and forget about it.
Alpineandy
PostPosted: 14:36 - 15 Jan 2017    Post subject: Reply with quote
You can fit a 'slip-on' on pretty much any bike.
Just need to get one with the right bore.
Any mildly competent mechanic can sort it quickly.
The above comment isn't necessarily the truth and anyone that says it is, is only correct if it's the truth or they're bigger than me.
Azoth
PostPosted: 16:14 - 15 Jan 2017    Post subject: Reply with quote
Try it and see if it works. I suspect we're getting screwed on oil, voodoo-science aftermarket handlebars and aftermarket exhaust systems. Would be interested to read your experiences of a Chinese pipe.
Safety in numbers
definitelyinc...
PostPosted: 16:42 - 15 Jan 2017    Post subject: Reply with quote
In many cases we are, I know someone who built their own YZF-R125 from the frame up, and what I can tell you is that most of his parts are from Ebay etc. resourced from China, his bike is spot on, including all the Chinese parts, it is still a matter of you get what you pay for, however the price to pay for a decent part is lowered considerably. (Not in all cases of course)
Also I would be half tempted to go and try it, but with Delkevic being only £100 more for a full system I might just end up grabbing that part instead
definitelyinc...
PostPosted: 16:45 - 15 Jan 2017    Post subject: Reply with quote
Yeah, as the time comes nearer I will spend more and more time just looking at reviews and experiences for my chosen exhaust (most likely Delkevic).
@Andy Yeah, I could most likely cut the end off and weld/add another one (with a friends assistance and tools Razz), however I think i'll just go for a full system, get fresh headers too while I'm at it and whatnot Smile
wots
PostPosted: 19:05 - 15 Jan 2017    Post subject: Reply with quote
The headers are just replacements all nice and shiny, I wouldn't bother. Especially, as they can be a twat to get off as the bolts corrode at the manifold.
It is a slip-on, but it isn't. As it comes with the link pipe, all the hangers and everything to fit it. As from the header pipe at the bottom on it is one (heavy) piece.
I've got this kit in my garage, which I've used for about a couple of hours, because I hated it.
https://www.delkevic.co.uk/index.php?route=product/product&path=2154_2433_2434&product_id=7649&Title=DS70+225mm+Oval+Carbon+Fibre+Silencer+to+fit+ER-6F+ER+6F+%282006-2008%29&SKU=KIT0399
Conzar
PostPosted: 13:13 - 16 Jan 2017    Post subject: Reply with quote
A stubby can on A ER6 is going to sound fucking wank and you will look like a right n00b
Current ride: ZX6R 636 ------- Previous:KTM EXC 450 Supermoto --- ZX6R B1H --Hornet 600--CBR 600--SV650
11:05:35 Rob Fzs: i just wanna own an rd350 valve before they send us to war with durkadurkastan
The last post was made 7 years, 102 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.65 - MySQL Queries: 17 - Page Size: 137.17 Kb
