Mucky chain and slippery back wheel..
JodieWodie
Reflective Banana
PostPosted: 17:38 - 01 Sep 2004    Post subject: Mucky chain and slippery back wheel.. Reply with quote
Went to Bassetts Pole last night with a mate...on the way back I nearly came off as my back wheel suddenly got very slippery...and it was like that for the rest of the 20 minute ride home...although it did ease.
Went to clean my bike today...there is black oily grease sh*t splattered all over my back wheel...including tyre...the chain itself looks 'muckier' than usual...instead of light oil and lube it looks as if there is black THICK oil/paint cr*p all over it...and the chain guard.
Could this be something I rode through that has splattered all over...or is it a symptom of a more serious underlying problem ?
I have de-greased the tyre and checked for leaks..none...but I am worried as I am going out on the bike again later...and want to know if this chain is safe.
Thanks in advance,
JO xx
Courage doesn't always roar. Sometimes courage is the quiet voice at the end of the day saying, "I will try again tomorrow"
mr jamez
PostPosted: 17:45 - 01 Sep 2004    Post subject: Reply with quote
Sounds like you rode through a load of oil then Confused as long as you cleaned it all off the back tyre, then you should be fine, and extra oil wont do you're chain any harm Razz But I would wipe the excess off that incase it flings everywhere.
JodieWodie
Reflective Banana
PostPosted: 17:51 - 01 Sep 2004    Post subject: Reply with quote
Okay..cheers...as long as it is that then Thumbs Up
I wanted to know if the chain could mess up or anything...but I guess not....
I did clean the excess off..and although it looks a bit different, I guess it's okay.
JO x
mr jamez
PostPosted: 18:00 - 01 Sep 2004    Post subject: Reply with quote
Well if you are scared Wink Clean the chain up with parrafin or white spirit then re-lube it, piece of mind and all that Smile
Guest
PostPosted: 19:16 - 01 Sep 2004    Post subject: Reply with quote
Check your gearbox/engine oil level is ok, just in case the gearshaft seal behind the front sprocket has failed.
The last post was made 21 years, 189 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.73 - MySQL Queries: 14 - Page Size: 43.46 Kb
