POD filter on a 125
classified-moto
PostPosted: 11:43 - 11 May 2017    Post subject: POD filter on a 125 Reply with quote
Hi all
I'm new to the forum and have only had my bike 1 year
It's a Suzuki 125 and I spoke to the people who I got it from and from another mechanic who said that fitting a POD filter on to the carb would not need a re-jet as everything else is standard on the bike so the other day I got up the courage to do it
Now I'm just paranoid that it's going to be running lean however I've took her out about 5 times and she's actually running and idling beautifully with seemingly no problems. I've noticed a split second hesitation in 4th but that was also there with the air box
What should I be looking for to check if it's lean and any advice would be great. I personally feel she runs smoother with the pod and is more responsive when the throttle is cracked up than she was before but would appreciate some advice
Andy_Pagin
PostPosted: 11:55 - 11 May 2017    Post subject: Reply with quote
If it's running lean the spark plug insulator will look very white and glazed, by insulator I mean the one inside the engine not the one where the lead plugs in.
classified-moto
PostPosted: 12:15 - 11 May 2017    Post subject: Reply with quote
I thought I had to check at the top of the spark plug to see if it's tan
How would I check the insulator inside the engine-do I take spark out and shine a torch inside there?
Are there any other signs of a lean running engine
PostPosted: 12:31 - 11 May 2017    Post subject: Reply with quote
Pitchers worth a thousand words mate
Mr Pagin means the white bit just under the tip
https://www.aa1car.com/library/reading_spark_plugs.jpg
PostPosted: 12:40 - 11 May 2017    Post subject: Reply with quote
It'll be really hard to make it run right. Your mate who is a mechanic or whatever sounds like he's talking nonsense.
classified-moto
PostPosted: 12:51 - 11 May 2017    Post subject: Reply with quote
According to those pictures my spark plug looks like the top one in all honesty. It has a lovely tan colouring under the tip
PostPosted: 13:04 - 11 May 2017    Post subject: Reply with quote
You might get lucky, just keep an eye on the plug for a while. Don't sweat it too much, you'd unlikely to melt the piston.
What I'd expect you to notice is some hesitation when cracking the throttle open from idle. Every carbed bike that I've meddled with has run better when I've put the stock airbox back on.
However, if it's running right and sounding better (can't beat that mighty 125 roar... Whistle) you're good. Plenty of us dick around with our bikes and get away with it.
For future reference we have a Workshop section for technical questions.
classified-moto
PostPosted: 13:08 - 11 May 2017    Post subject: Reply with quote
Thanks for the reply-yeah at the minute I can crack open throttle hard from idle with no hesitation or problems at all. Ill ride it and check the plug after every ride
Is there anything really major that might happen that I need to look out for
I have none of the popping on decel, no hesitations, it doesn't struggle to start up or anything
The only thing I've noticed might be a slight loss of power but that might just be in my head because I'm looking for something wrong
The last post was made 9 years, 40 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.55 - MySQL Queries: 13 - Page Size: 56.13 Kb
