| F1.ash |
 F1.ash Renault 5 Driver
 Posted: 10:03 - 28 May 2017 Post subject: Hyperpro rear springs |
I'm thinking of changing my rear spring, primarily to help with setting of correct preload. At the moment the adjuster on my V-Strom is wound all the way up and it's still 8mm outside of ideal setting.
Should I expect a Hyperpro spring to assist in this or is it more a like-for-like swap that's considered an upgrade?
Any advice appreciated  |
| Fizzer Thou |
 Posted: 14:31 - 28 May 2017 Post subject: |
A friend chose a Hyperpro front and rear spring kit which,together with the correct grade fork oil as supplied,made a big difference to his Bandit 1200.The kit was a much cheaper option to a replacement rear shock and was easy to install.
The website for Hyperpro https://hyperpro.com/products/ suggests Performance Parts Ltd https://www.performanceparts-ltd.com/ as the UK importer and they should be able to suggest the correct spring for the weight and type of riding that you are contemplating.
When I replaced the rear shock on my R1 I quickly found that the front springs then felt inadequate.It is an idea to upgrade the front at the same time,although a little time then needs to be spent setting up the best spring preload and damping clickers  ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
| F1.ash |
| F1.ash |
 Posted: 09:41 - 29 May 2017 Post subject: |
| Fizzer Thou wrote: | A friend chose a Hyperpro front and rear spring kit which,together with the correct grade fork oil as supplied,made a big difference to his Bandit 1200.The kit was a much cheaper option to a replacement rear shock and was easy to install.
When I replaced the rear shock on my R1 I quickly found that the front springs then felt inadequate.It is an idea to upgrade the front at the same time,although a little time then needs to be spent setting up the best spring preload and damping clickers  |
I have it in mind not to be surprised if this is the case. I went for ride yesterday evening and the bike has the sensation of being higher at the back, ie not as compressed as much which is what I might expect, but the composure of it over certain undulating or rippled poor surfaces is not great. It clearly doesn't like having it's pre-load adjuster at maximum. It's like trying to stay on a horse if you know what I mean. It does seem to originate from the rear end but has you say, it's bound to highlight other shortcomings once it's changed out.
I'm no expert at bike suspension/handling, this is my first so I'm finding my way. |
| Wafer_Thin_Ham |
| F1.ash |
The last post was made 8 years, 268 days ago. Instead of replying here, would creating a new thread be more useful? |
