Fuel pumps?
PostPosted: 00:04 - 27 Oct 2017    Post subject: Fuel pumps? Reply with quote
Not bike related but could be.
All electric fuel pumps I have come across click when you switch them on and stop when they get up to pressure.
I have just fitted a Facet cube pump to my narrowboat diesel as a lift pump.
I turned it on and it worked, but kept clicking. Removing pipe etc. has proved beyond doubt it is pumping so can anyone tell me if they keep clicking even when up to pressure or is it not working correctly?
I am pissed off at how many times I have filled the bilges with bloody diesel testing and changing pumps so want to get this right.
temeluchus
PostPosted: 00:13 - 27 Oct 2017    Post subject: Reply with quote
Yes, they keep running when up to pressure, this is normal.
MCN
PostPosted: 00:37 - 27 Oct 2017    Post subject: Reply with quote
https://www.facet-purolator.com/faq.php
BMW's attempt to get fuel from the tank to the injection system used a relay controlled affair.
The relays burned out and left the rider hi and dry.
The fix was to make a jumper and drive the pump direct from the battery by-passing the relay.
I think the pump was relay controlled to prevent the pump overheating.
The relay cut in or out depending what fuel pressure is sensed.
So I would guess your cube pump could still use a relay/pressure sensor to stop the pump when it is up to pressure.
Or fit a bypass/regulator valve in the line. (Bugger that.)
https://cbrforum.com/forum/cbr-600f3-17/purpose-fuel-pump-relay-101822/
PostPosted: 01:02 - 27 Oct 2017    Post subject: Reply with quote
That's the answer I was hoping for Thumbs Up
Andy_Pagin
PostPosted: 13:59 - 27 Oct 2017    Post subject: Reply with quote
I've fitted a couple of these to my Landrovers and yes they do click loudly even when up to pressure.
The last post was made 8 years, 342 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.98 - MySQL Queries: 14 - Page Size: 44.57 Kb
