F650 Funduro tyre valves
Feasty
PostPosted: 15:20 - 30 May 2018    Post subject: F650 Funduro tyre valves Reply with quote
I've recently got a BMW F650 1998, and haven't been able to check the tyre pressures yet - I'm used to my bikes having the car type valves on them. Instead this has thinner valves on it, but I can't see how you measure the tyre pressure - nothing seems to push in to let the air out.
Anyone know what this type of valve is called? Or what adaptor I need to be able to use a standard tyre pump on it?
Pic attached.
Previous: Aprilia Habana Retro 50cc (beauty), Yamaha SR125 (fell apart), Honda XR125 (nippy little commuter), Honda SLR650 (Geewhizz), Yamaha Diversion 900S (Smoooooth) written off courtesy of a stupid escaped horse.
(7 year gap), BMW F650 (Relaxing ride). Aprilia Caponord ETV1000 (Big and bold). Yamaha FZS600 (got me in trouble too quick!).
Current: Yamaha TDM 900 (Comfy, light but big, power when needed). Also now a Tiger 1050, easily best of the lot!
Evil Hans
PostPosted: 15:36 - 30 May 2018    Post subject: Reply with quote
That's just a dust cover with a valve-core remover built in. Unscrew it, it's a normal valve underneath.
Nobby the Bastard
Harley Gaydar
PostPosted: 15:37 - 30 May 2018    Post subject: Re: F650 Funduro tyre valves Reply with quote
Pic attached.
Thats a dust cap with integral valve core removal tool....
Feasty
PostPosted: 16:05 - 30 May 2018    Post subject: Reply with quote
Uh!
I'm not sure whether to quickly remove this thread or say 'that's right, well done - I was just checking you knew!' Brick Wall
I was too scared to unscrew it in case the tyre just went explosively flat...
What's a valve core removal tool for? - apart from the obvious, why would you want to have a removal tool ON the valve?
Nobby the Bastard
Harley Gaydar
PostPosted: 16:07 - 30 May 2018    Post subject: Reply with quote
Must... fight... the... desire....to....
Nah, fuck it. It's for removing the valve core. Duh!
The only reason I can think of is if you want to let the air out to change the tyre.
PostPosted: 16:08 - 30 May 2018    Post subject: Reply with quote
Feasty wrote:
Uh!
To umm, remove the core? Wink
Wanna fill it fast, wanna flatten it easy, 2 useful uses Very Happy
Feasty
PostPosted: 16:12 - 30 May 2018    Post subject: Reply with quote
Well that's that one cleared quick and easy, thanks Thumbs Up
PostPosted: 18:08 - 30 May 2018    Post subject: Reply with quote
To remove cores from scootays who keep parking too close and knocking your wing mirrors.
yen_powell
PostPosted: 19:39 - 30 May 2018    Post subject: Reply with quote
Feasty wrote:
Uh!
You can also use it to check the valve core is nipped up enough if you seem to have a slow puncture. Or.... remove the valve core, blow out any grit and refit in case that was holding the valve core slightly open.
Take it off, turn it round, put in the valve tube and turn it till the two little prongs engage in the valve core. Now you can remove or tighten it.
XT1200Z and a DR350 in bits
The last post was made 8 years, 144 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.92 - MySQL Queries: 14 - Page Size: 62.38 Kb
