Kawasaki zzr1100
jamie182861
PostPosted: 21:31 - 26 Jul 2018    Post subject: Kawasaki zzr1100 Reply with quote
I took my bike out for a spin, I was on my way home and the bike cut out. I put the choke on it runs fine. Soon as I give it throttle it cuts out. Just got the carbs cleaned and got new spark plugs but not yet fitted them, can anybody help with this problem?? Thank you
jaffa90
PostPosted: 22:09 - 26 Jul 2018    Post subject: Reply with quote
Sounds like the choke / cold start jets are clear but the others blocked.
An inline filter should stop crap going into the carbs.
jamie182861
PostPosted: 22:30 - 26 Jul 2018    Post subject: Reply with quote
This wee filter water filter
jaffa90
PostPosted: 22:38 - 26 Jul 2018    Post subject: Reply with quote
jamie182861
PostPosted: 00:06 - 27 Jul 2018    Post subject: Reply with quote
Hi mate just had the carbs cleaned from mechanic and set carbs to right specs
Kentol750
PostPosted: 00:25 - 27 Jul 2018    Post subject: Reply with quote
Then, I'd suggest you go and ask him to ride it. He'll know what he did.
Some bikes.
Wonko The Sane
PostPosted: 13:32 - 27 Jul 2018    Post subject: Reply with quote
carbs probably need cleaning, got some muck in them.
I had similar problem with my ZZR600 a few years back, I'd let the fuel level get too low and sucked some crap through (past the filter) into the carb, running with half choke on (never needed full choke even in winter) and a good motorway blast sorted it out, it was rough and jerky for a bit but after a few miles it was starting to behave again, dropped the choke off and it carried on being happy.
jamie182861
PostPosted: 14:16 - 27 Jul 2018    Post subject: Reply with quote
Just changed sparks plugs got carbs cleaned waiting on jump start to charge get bike started battery is dead hopefully do what u said give her good blast just waiting on jump start to charge battery dead
fatjames
PostPosted: 15:05 - 27 Jul 2018    Post subject: Reply with quote
You probably need This
jamie182861
PostPosted: 15:12 - 27 Jul 2018    Post subject: Reply with quote
That’s for MacBook it says
PostPosted: 15:14 - 27 Jul 2018    Post subject: Reply with quote
Sounds like fuel starvation.
Try it on prime. Also try it with the fuel cap open.
If someone has just been at the carbs, they could have trapped a fuel/breather hose or forgotten to reattach a vacuum hose.
Do you get a good flow of fuel out of the tap with it on prime?
jamie182861
PostPosted: 15:20 - 27 Jul 2018    Post subject: Reply with quote
I do all my own bike work if u can show me pics be better for me only bought bike last month weather to good to miss connected all carbs up give them try let u know results once jump started been charged up
Nobby the Bastard
Harley Gaydar
PostPosted: 15:26 - 27 Jul 2018    Post subject: Reply with quote
Can you add these to make yourself intelligible?
Triumph Sprint ST 1050
jamie182861
PostPosted: 15:29 - 27 Jul 2018    Post subject: Reply with quote
What u mean bud
So far done to bike
Spark plugs change
Carbs cleaned by mechanic
Checked fuel pump working
Nobby the Bastard
Harley Gaydar
PostPosted: 15:34 - 27 Jul 2018    Post subject: Reply with quote
jamie182861 wrote:
What u mean bud
If you were to use grammar (I.e. form proper sentences) we might stand a chance of understanding what you are typing.
Your statement above reads as a random collection of words.
jamie182861
PostPosted: 15:36 - 27 Jul 2018    Post subject: Reply with quote
I can get video no good puting stuff into sentences
fatjames
PostPosted: 15:37 - 27 Jul 2018    Post subject: Reply with quote
These conversations tend to go the same way for 4 stroke engines when the electrics aren't to blame.
Is it getting fuel?
Is there compression?
Is it sparking?
Is there a pigeon stuck in the inlet?
Check these things first, it will help us to help you.
Alternatively, you've just had carb work done. So.. start there.
If you can get it to start, I'd be tempted to give it some beans and see if that 'unblocks' anything.
As has been mentioned, sounds like a fuel problem. Check the fuel tap / air locks in the system. Possibly carb to inlet rubbers.
jamie182861
PostPosted: 15:52 - 27 Jul 2018    Post subject: Reply with quote
I check fuel tap in see
jamie182861
PostPosted: 18:31 - 27 Jul 2018    Post subject: Reply with quote
anyone know what hoses go where carbs and water filter hose
The last post was made 8 years, 112 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 1 - MySQL Queries: 14 - Page Size: 96.14 Kb
