| tokai |
 tokai Derestricted Danger
| Sister Sledge |
 Sister Sledge World Chat Champion
| bikenut |
 bikenut World Chat Champion
| tokai |
 Posted: 12:12 - 19 Jan 2019 Post subject: |
Pictures will be forthcoming...
https://www.cmsnl.com/honda-cbr1100xx-superblackbird-2004-4-englandasv-mkh_model2078/partslist/E__1001.html
The shaft that drives the waterpump has a notch in the end which slots into the rotating bit in the engine.
It feels like its seated correctly as the fins on the pump don't turn freely once its in, it may be that is only partially seated but then the pump housing is tight up against the engine with the bolts hand tight and the gap on each bolt remains...
Will report back with pics. |
| jaffa90 |
 jaffa90 World Chat Champion
| tokai |
 Posted: 13:53 - 19 Jan 2019 Post subject: |
This is a pic of the pump minus the cover, seated but not bolted in.
You can see the gap between the bolt hole and the pump housing.
The rubber seal is also just visible. To get it to seat i rotated the pump fins until the notch slots into the bit the drives it, then the pump is fully seated in the hole.
It doesn't turn once seated although there is a slight bit of side to side movement it does feel like its seated properly.
2nd pic shows the hole with the square bit that drives the pump.
https://imgur.com/a/MGePcdr
With the upper an lower bolts in, tightened incrementally the gap remains at both bolt holes. |
| tokai |
| bikenut |
 Posted: 11:38 - 21 Jan 2019 Post subject: pump |
visit cmsnl and figure out how the dog inside the engine is driven, by an other dog perhaps.
Perhaps the shaft inside the engine sticking out that drives the water pump is sticking out and not fitted properly, visit cmsnl and post a link to the water pump of your exact bike......
any tell tails marks to suggest the shaft in the engine is sticking out tooooo far?????
cmsnl link
is the water pump dog driven via the oil pump dog??
https://images.cmsnl.com/img/partslists/honda-cbr1100xx-superblackbird-2004-4-englandasv-mkh-oil-pumpoil-pan-oil-filter_bigecatv41e__1200_e60b.gif
part number 3??
if so are the dogs ( flat drive "plate" on oil shaft and its water pump "slot" ) in line?? ____________________ nuts about bikes |
| bikenut |
| sickpup |
 sickpup Old Timer
| tokai |
 Posted: 09:30 - 25 Jan 2019 Post subject: |
Yeh, I was just being a fud.
Test fitting the pump after removing the seal allowed it to slot in all the way home with no gap.
Refitted with a lubed seal and its all good now.
Cheers for the help  |
| bikenut |
The last post was made 7 years, 258 days ago. Instead of replying here, would creating a new thread be more useful? |
