2005 YN50 Neo's digital speedo not working
Olly666
PostPosted: 19:03 - 28 May 2019    Post subject: 2005 YN50 Neo's digital speedo not working Reply with quote
2005 YN50 Neo's digital speedo not working, any ideas ? Any common faults ? Rolling Eyes
PostPosted: 19:41 - 28 May 2019    Post subject: Reply with quote
I would imagine it's cable driven rather than magnet + sensor.
If it was me I'd get it on the centre stand and unbolt the covers around the handlebars so you can get to the back of the speedo. At this point you might get lucky and find the speedo cable has just got loose and just needs screwing back in.
If not, unscrew it from the back of the speedo... top tip: stick a cable tie around the speedo cable just under the collar you're about to unscrew otherwise it'll just drop down the cable and you'll be fishing around for it like an idiot. Don't ask me how I know Smile
The end of the actual cable in the sleeve will be a square shape. Spin the front wheel around and see if this square end rotates. If it does the the speedo is knackered. If it doesn't then the wheel end is knackered.
If it's the wheel side you might want to examine it before buying a new one. Take off the front brake, wheel and then you should see the only cable left being the speedo one. Carefully take this off the axle as some bits might fly out! There should be something like a cog inside that engages with a worm gear. Check the worm gear and cog for wear...
Hope that gives you some pointers!
Olly666
PostPosted: 20:09 - 28 May 2019    Post subject: Digital speedo. Reply with quote
Thanks for that but it is definitley a digital one.
PostPosted: 20:26 - 28 May 2019    Post subject: Re: Digital speedo. Reply with quote
Arse...
Well all I can suggest is checking the cable from the back of the speedo down to the sensor on the wheel and check it's not chaffed. Other than that the easiest test is swap sensor/cable/speedo till you find the fault Sad
Riejufixing
PostPosted: 20:52 - 28 May 2019    Post subject: Re: Digital speedo. Reply with quote
Check: are you absolutely certain? Places like "pedparts" sell mechanical cables for them.
PostPosted: 00:28 - 29 May 2019    Post subject: Reply with quote
Hang on... when I say "digital" or "cable" I mean the input not the display Smile
You can have an LCD speedo and it still have a mechanical cable input.
Does the back of the speedo have this:
https://i.imgur.com/E6RdxEZ.jpg
Olly666
PostPosted: 13:03 - 29 May 2019    Post subject: Digital Speedo Reply with quote
Absolutely certain this model/year has a completely digital speedo with wires from the sender to the head unit. This was the first thing I checked, Pedparts sell them for £45. I was asking if anybody had any known faults/repairs etc. to save myself some money.
PostPosted: 13:06 - 29 May 2019    Post subject: Reply with quote
Soz, more scope for an easy fix with mechanical Sad
Meatybeaty
PostPosted: 14:41 - 29 May 2019    Post subject: Re: Digital Speedo Reply with quote
Hi , HD is right ,its a cable driven off your front wheel to a wave connector into the back of the cluster
https://www.amazon.co.uk/Sensor-Speedometer-Cable-Yamaha-Ovetto/dp/B01N64ZAVT
PostPosted: 18:15 - 29 May 2019    Post subject: Reply with quote
Lol... there are two types for this bike (so it seems) mechanical cable driven and electronic sensor. OP says it's sensor. I would imagine it'll be a sealed unit at the wheel so not much to do Sad
PostPosted: 23:26 - 29 May 2019    Post subject: Reply with quote
Define "not working". Blank display? Only shows zero? Shows random numbers when moving?
Throw us a frikkin bone here.
Olly666
PostPosted: 10:27 - 30 May 2019    Post subject: Digital speedo Reply with quote
Definitely no cable, wires all the way. By not working, I mean the needle on the speedo stays at 0 mph and the miles on the digital display stay the same.
There is a gap of 6 years, 52 days between these two posts...
Dougster7
PostPosted: 10:35 - 19 Jul 2025    Post subject: Re: Digital speedo Reply with quote
Did you ever solve this issue as I have the same now Sad
The last post was made 1 year, 6 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 2 - MySQL Queries: 13 - Page Size: 76.26 Kb
