What's the best oil for a bike and when should I change it?
MCN
PostPosted: 01:15 - 02 Jan 2020    Post subject: What's the best oil for a bike and when should I change it? Reply with quote
Sinthetic or regulir oil? What is the best?
Can I change oil too soon?
PostPosted: 03:50 - 02 Jan 2020    Post subject: Reply with quote
Whatever your manual says, although I usually use decent semi synthetic working on the principle, rightly or wrongly, if I need to top up the oil and I haven't got the correct one with me, semi synth is more likely to be available and compatible.
I usually use Shell advance simply because I worked for them or Motul because it's easily available.
As for changing it, all you are doing if you change it early is wasting money, especially if it's expensive oil.
Triumph Trophy Launch Edition
PostPosted: 07:49 - 02 Jan 2020    Post subject: Reply with quote
Just use old cooking oil. Change it when the smell of chips stops or the engine stops, whichever is sooner. Don't use stuff from the other half of the frier or your bike will smell of fish and battered mars-bars and you'll have children chasing you down the street with forks in their hands.
If you are in Edinburgh, you might want to pre-mix some brown sauce in the fuel so you don't get battered but only use vinegar on the West coast.
Sister Sledge
PostPosted: 08:21 - 02 Jan 2020    Post subject: Reply with quote
We tend to use lard in the North East. I always slightly overfill and when I'm on a ride and hungry I dip bread soldiers down the filler hole.
Dunno tbh. I'm using a semi-synthetic but only cos it's what a CCM parts supplier lists! I change way before it's due but only because it's an older engine and I give it hell. Costs more but meh it's only 1.7 litres.
CCM 404 DS
PostPosted: 09:45 - 02 Jan 2020    Post subject: Reply with quote
Lavender for economy, Tea Tree if you're running in.
seeyalater
PostPosted: 10:04 - 02 Jan 2020    Post subject: Reply with quote
I got a silkoline and k&n filter deal online, oil is what the manual says so will do as such. i dont think you can do it too often really. dont forget sump bolt washer needs to be new. unless you have your own way of sealing. Smile
MCN
PostPosted: 10:38 - 02 Jan 2020    Post subject: Reply with quote
I've been using beef dripping but the consumption went sky high after I fitted the Scottish Plain Filter.
I like the Essential Oil suggested by The Shaggy D.A.
The Mrs. swears by Ylang Ylang but I just checked online and it's extortionate.
Old chip pan oil it is.
Stinkwheel, is there a way to pour the used oil that fish was cooked in through fullers earth to remove the fishy smell? I think I read something about that.
Riejufixing
PostPosted: 12:33 - 02 Jan 2020    Post subject: Reply with quote
No, weight! The others are having you on. Use Castrol R40, it's not syntheyetic or minerall so it's very good for the planet, greeter thuneberger's dad uses it all the time, and also it's so good you only need to use half the normal quantity in your engine so it are reallt cheep two.. There should be no need to change it for the life of the engine.
xX-Alex-Xx
PostPosted: 16:41 - 02 Jan 2020    Post subject: Reply with quote
WD40. Keeps the engine and gearbox clean, and smells good at the same time Laughing
DILLIGAF
WD Forte
PostPosted: 17:04 - 02 Jan 2020    Post subject: Reply with quote
Anything with with 'Ultra' or 'hyper' or 'Super' or 'Max' on the bottle
"UltraHypersupermax Sports" is the bestest of course.
Ignore numbers that's just sales bollox, it dont mean nuffin.
bikers smell of wee
chickenstrip
PostPosted: 00:18 - 03 Jan 2020    Post subject: Re: What's the best oil for a bike and when should I change Reply with quote
You're such a slow rider, you could manage with no oil at all Razz
weasley
PostPosted: 08:48 - 03 Jan 2020    Post subject: Reply with quote
https://www.enginelabs.com/news/video-what-happens-when-you-run-wd-40-as-engine-oil/
jaffa90
PostPosted: 16:39 - 03 Jan 2020    Post subject: Reply with quote
Where`s Tef about Castrol R ????????????????
chickenstrip
PostPosted: 18:17 - 03 Jan 2020    Post subject: Reply with quote
Don't you have to say his name three times whilst looking in a mirror or something?
Nobby the Bastard
Harley Gaydar
PostPosted: 18:23 - 03 Jan 2020    Post subject: Reply with quote
Nah, thats mpd, teffers just turns up un-announced.
Triumph Sprint ST 1050
The last post was made 6 years, 221 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 2.14 - MySQL Queries: 14 - Page Size: 87.77 Kb
