RF900 won't start
King29
PostPosted: 13:12 - 14 Jan 2020    Post subject: RF900 won't start Reply with quote
I've an RF900 1997 P reg. Layed up over winter. I went out to try and start it today, no dice. Before laying it up for winter I brimmed the fuel to the top of the tank and left the battery on the optimate. Battery has plenty of power, it turns and turns and turns over but wont start. I've a petrol lawn mower that I emptied the fuel out of on the last cut of the year, syphoned some fuel out of the RF900 tank and the lawn mower started on the 4th pull of the rip cord which is about standard. So the fuel is ok.
I've an inline spark/ignition tester and all spark plugs fire a spark. I'm at a loss now. Any suggestions? I don't need the bike for work or anything, so I'm not stranded as I have a car but I'm miffed that on my day off I've gone to check the bike and it won't start.
Nobby the Bastard
Harley Gaydar
PostPosted: 13:15 - 14 Jan 2020    Post subject: Reply with quote
Are the plugs wet when you pull them?
Triumph Sprint ST 1050
Easy-X
PostPosted: 13:19 - 14 Jan 2020    Post subject: Reply with quote
Didn't drain the carbs before storing?
davebike
PostPosted: 13:21 - 14 Jan 2020    Post subject: Reply with quote
Drain the carbs and let them refill If it uses a fuel pump (I cannot remember!) you will here it clicking
Fuel "goes off in carbs quicker than a brimmed tank"
Dave
NC750Xdct + others at work !
[email protected]
Copycat73
PostPosted: 13:29 - 14 Jan 2020    Post subject: Reply with quote
replace the spark plugs
caveat emptor
King29
PostPosted: 13:57 - 14 Jan 2020    Post subject: Reply with quote
No. I sorted it now. I drained the carbs before lay up, the fuel tap is busted. It's just the dial spinning not operating the tap. Although it was showing in the correct position it wasn't. More fvckery to get done this after noon.
Thanks for all your help folks.
yen_powell
PostPosted: 17:22 - 14 Jan 2020    Post subject: Re: RF900 won't start Reply with quote
Turn the fuel tap to prime, open up the drain screws on the bottom of the carbs, when fuel runs out do them up and try starting it again.
XT1200Z and a DR350 in bits
Tankie
PostPosted: 18:16 - 14 Jan 2020    Post subject: Reply with quote
Read the thread YEN! he found the fault!
yen_powell
PostPosted: 19:12 - 14 Jan 2020    Post subject: Reply with quote
I wasn't listening, what a twanny eh.
The last post was made 6 years, 169 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.72 - MySQL Queries: 14 - Page Size: 59.29 Kb
