ZX9R Sticking gears - C2 (1999) 19k
TheGazWaz
PostPosted: 18:43 - 24 Jan 2020    Post subject: ZX9R Sticking gears - C2 (1999) 19k Reply with quote
Hi everyone. Really concerned about this. The problem started this morning on my way to work.
Basically the bike will go up through the gears fine but intermittently doesn't want to shift back down. It's like instead of a gear shift there's a space on the lever.
So I'm in 5th gear, approaching a roundabout, 50mph, Drop down to 4th, 40mph, go to drop down to 3rd. nothing but a space. I keep pressing, clutching in and out but it just won;t go. Selects up fine and back down to 4th. Finally gets 3rd and does the same thing until I finally get second by which time I'm at the side of the road waving people past while frantically trying to get first.
Any ideas guys. I'm pretty desperate here. The bike has never missed a beat. It never slips out of gear. The engine sounds fine. No grinding when in gears. When I pull away it will be fine for a while then it does it again.
Please help
Gary
Went like this.. 43 years old(2013) decided to do CBT to get a 125 for new job. Bought 2011 YBR, loved it for three months then hated it because it was too god damn slow. Did DAS 4 months later then bought RF600 Loved it, sold it bought Bandit 1200(K3). EFFIN lOVED IT. Wanted something a bit more sporty so got Triumph Sprint ST 955i (53). Not sporty enough so now on my GSXR 1000 K3 and absolutely love it. 1 year down the line, nearly died way too many times on this bike. Sold it. Had a 6 month break. Missed biking so now, Aug 2019 have a 1999 ZX9r. What a beauty she is too.
Bhud
PostPosted: 18:56 - 24 Jan 2020    Post subject: Reply with quote
Interesting problem. I did a quick Google search, and apparently others have reported similar issues. This web page is interesting:
https://www.ksrc-au.com/html/fixing_a_zx9r_gearbox.html
And there are a lot of other reports on the web to read.
From the sounds of it, all other things being good, you will need to remove the engine and split the cases to see what's wrong.
stevo as b4
PostPosted: 20:26 - 24 Jan 2020    Post subject: Reply with quote
Apparently all C-series ZX9R's do this, as do all early R1's lose 2nd gear, and all R6's munch up their cylinder linings too. And let's not forget all RGV250's destroy their power valves and let the pistons smash them to bits.
TheGazWaz
PostPosted: 21:09 - 24 Jan 2020    Post subject: Reply with quote
I can get every gear and there's no slip or jumping out. It's just downshifting like something isn't returning to accept the next shift.
PostPosted: 21:24 - 24 Jan 2020    Post subject: Reply with quote
I just looked and they have a similar gear selector shaft pawl to a GPZ500. I've had two of these fail in the way you describe. it has a couple of hooks on a bit of flat plate on small bendy springs that grab the selector drum and rotate it. if the hooks wear round, it doesn't always grab the next notch on the drum.
Beore you do anything though, make sure you are taking your foot totally off the lever before going for the next shift. You wouldn't be the first person to have a gearshift problem that was their new boots making them leave their toe on the lever (do you have new boots?).
On a GpZ, the selector is under a cover of its own behind the front sprocket and you can wiggle it out with the engine in the frame. No idea about a ZX9R though.
DJP
PostPosted: 06:04 - 25 Jan 2020    Post subject: Reply with quote
That^^. My gearchange went to rats when I got new boots. Turned out that I wasn't properly pressing the lever and I couldn't feel it because new boots.
Beyond that, I'd start with chain adjustment/lubrication, clutch adjustment and gear linkage condition and adjustment.
All of which can have a drastic effect on the gearchange.
Suzuki Bandit 1250
https://deejayp999.atwebpages.com/index.html
That's http not https
1198
PostPosted: 09:42 - 25 Jan 2020    Post subject: Reply with quote
On my ZZR the pin that is used to hinge the left footrest has an annoying habit of moving up just enough to obstruct the gear linkage.
I don't think it's this, but it's worth a check before you start ripping engines to bits?
trevor saxe-coburg-gotha
PostPosted: 10:41 - 25 Jan 2020    Post subject: Reply with quote
The issue is well-known and potentially very easy to cure. It is usually NOT the gear box and may be down to this:
https://i.postimg.cc/0ywddfBp/zx9-gear-change-peg-recess.jpg
There are stories of entire gearboxes being replaced and the problem remaining - until eventually being chased down to that one peg.
In short I think there is room for cautious optimism.
Go here for more information on this and other aspects of the C2:
https://www.zx-9r.net/viewtopic.php?f=48&t=22019
NB you may need to join that website in order to access the relevant content - but if you're running a nine it's invaluable and there are still a fair few active and very knowledgeable owners there, even though the bike is now about 20 years old.
TheGazWaz
PostPosted: 15:32 - 25 Jan 2020    Post subject: Reply with quote
Thanks for the replies everyone. Certainly a few bits to check there.
One thing I did notice that very morning was that my gear selector seemed higher than the last time I was on the bike. To the point that I had to lift my foot off the peg to go down.
The sprocket where the gear mech is attached to is all in order. No slippage there. I nipped it up a bit just in case.
My chain is not only about due a change but it's also a bit slack. I'll sort that out. Clutch seems to be pulling in OK at the arm but I'll see if I can adjust it a bit tighter.
Do gears just fail like this? I mean with out any progressional warnings?
I've also sprayed a sh1t load of WD40 around where the gear selector shaft goes into the case. I was pretty corroded up round there where I've been riding when there's salt on the road. Maybe something is sticking there.
I'll let you know how I get on.
Cheers again
Gaz
Sister Sledge
PostPosted: 18:49 - 25 Jan 2020    Post subject: Reply with quote
Gears can indeed fail in many areas. Earlier versions of the engine in mine (DRZ400) is known for gear teeth fracturing off.
Let's hope yours is the easy foot peg fix.
CCM 404 DS
TheGazWaz
PostPosted: 15:47 - 30 Jan 2020    Post subject: Reply with quote
Looks like I got Lucky,
I striped down the footpeg and gear select mechanism. It was pretty crudded up. Gave it a thorough cleaning then plenty of grease.
Also did an oil and filter change.
Bike runs beautiful again. I took it for quick spin that ended up lasting 2.5 hours and it didn't miss a beat. All gears selecting smooth and positive.
I am sooooo happy.
Cheers all for your help especially to trevor saxe-coburg-gotha. I feel I've just dodged a bullet.
Gaz
Bhud
PostPosted: 16:14 - 30 Jan 2020    Post subject: Reply with quote
Lucky
PostPosted: 18:18 - 30 Jan 2020    Post subject: Reply with quote
I am sooooo happy.
Gaz
Sweet. As I said, it really is A Thing with the C and C2 (and probably other nines). The bike developed a reputation for a weak gearbox - it was totally undeserved, and I think this is now starting to be more widely accepted. One thing I do love about the zx9r (esp. the C and C2) is just how easy you can buy spare parts. There's page after page after page on eBay. And cheap too.
The last post was made 6 years, 268 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.69 - MySQL Queries: 13 - Page Size: 80.64 Kb
