what to look for when buying 2nd hand
CraigofScotla...
PostPosted: 12:28 - 08 Feb 2020    Post subject: what to look for when buying 2nd hand Reply with quote
I passed my mod 1 and 2 last week and now looking at bikes. (been on the forum a while but just reading until i had my licence, didnt want the added pressure of having a bike in mind).
600 hornet sized, likely naked something. 2nd hand, potentially from 2005 ish seems to be the budget that fits.
Whats classed as high mileage on a bike? the type of miles that even with a service history you start to think hmmm.
Wheels, chains, sprockets, brakes, suspension, engine, electrics.
Any other advice when looking at the bike in the flesh?
Pete.
PostPosted: 12:47 - 08 Feb 2020    Post subject: Reply with quote
Check out the chain, sprockets, tyres and pads. £500 for good new ones so if (as you'll often find) the tyres only have 2mm, the chain adjusters are near the back of the slots, the sprockets are hooked or badly lubed your '£300-cheaper bargain' might be more expensive than a nicely kept bike with good consumables which is up for more money.
Nice bikes (not just nicely cleaned bikes) are fairly easy to spot, as are the owners of them. Blingy junk like anodised bolts, bar ends, levers, footpegs reduce the value IMO, rather than increase it.
a.k.a 'Geri'
RhynoCZ
PostPosted: 12:48 - 08 Feb 2020    Post subject: Re: what to look for when buying 2nd hand Reply with quote
Make sure all the fingers are present and fully functional, also make sure you buy the correct side hand, you wouldn't want to end up with two left or right hands, would you? Razz
Riejufixing
PostPosted: 15:14 - 08 Feb 2020    Post subject: Reply with quote
You could have a look at old MOTs online. Yes, things should have been fixed, but they may give you an idea of whether it's been looked after.
seeyalater
PostPosted: 18:47 - 08 Feb 2020    Post subject: Reply with quote
I got a 650 bandit great price, low insurance..
Check tyres, forks, brakes and it sounds sweet..
PostPosted: 19:25 - 08 Feb 2020    Post subject: Reply with quote
If you stick the registration into https://www.check-mot.service.gov.uk/ then you can see the MOT history of the bike to get some idea of how the current owner and previous owners have treated it.
The MOT history isn't a definitive answer for how it's been looked after but you'll have some idea of how the bike has been treated when it's not made to look shiny for the purposes of selling it.
CraigofScotla...
PostPosted: 23:22 - 09 Feb 2020    Post subject: Reply with quote
MOT is a good shout tbf. I will do that.
So many choices of bikes that arnt local Sad Could get delivered but its a bit risky not seeing beforehand.
Pigeon
PostPosted: 00:38 - 10 Feb 2020    Post subject: Reply with quote
Have there been a lot of owners in a shortish space of time.
Not a bad thing in iitself, could be reasons. But increases the potential number of idiots to a have been custodian. Or could indicate a problem child.
Has the engine been running before you arrive.....not necessarily a bad sign, but make a note.
Is it parked on gravel or grass? If so, try and check for oil leaks, or ask to leave some paper towel down for 15 minutes.
When the bike is running, is the brightness of the lights altered by the revs? If so, would walk away or be aware at least, potential charging fault.
If they talk about DIY maintenance, are there any records? Any empty oil cans lying around (if so what brand). What's their general level of organisation. Any other vehicles there, or the property in general. Do they take care of stuff, are they on top of things.
Not essential, just builds a picture.
ThatDippyTwat
PostPosted: 06:16 - 10 Feb 2020    Post subject: Re: what to look for when buying 2nd hand Reply with quote
Mileage isn't the be-all and end-all. It also depends on the bike. At that size/capacity, some bikes derived from the CBR600 motors are largely bulletproof (Hornet, CBR600F, CBF600), and will do >100K easily with regular, normal maintenence. The same with the late 90's Bandit 600's and GSX600F's, but rust may be an issue. Other bikes may well be worn out well before the 50K mark.
Do see if it's looked after, that's much more important than mileage in most cases. Does the seller have oil bottles around the place? Dump pans and funnels? Chances are they do change the oil and service it regularly. Dusty garage and crap accumulating on the bike when you look into nooks and crannies? It's ridden and ignored - walk away.
wr6133
PostPosted: 08:12 - 10 Feb 2020    Post subject: Re: what to look for when buying 2nd hand Reply with quote
So what is the actual budget? The above is a list of wants budgets are expressed in £.
When looking just go over it front to back.
Look beyond consumables (though do look at consumables). Brand new pads in the front calipers could have been done for sale, what does the actual caliper look like? If pull the lever then shine a torch in the caliper what do the exposed caliper pistons lips look like? Have the little rubber caps on the bleed nipples been cleaned and kept nice (if they have the owner is probably OCD)?
Exhaust headers, whats the state of the collars and bolts holding to the head? It's easy to make the pipes look good with some harpic but the collars and bolts are hard to perfect without actually removing them.
If it's a floating/semi-floating brake disc give the outer a wiggle. See how seized those bobbins are. It's a good indicator of the level of care it received as many ignore these.
Make sure the bike is cold, properly stone cold when you get there. If it's warm it probably is a bastard to start or makes horrible noises when cold..... there is some reason the seller doesn't want you to cold start it.
Remember to give the forks a good bounce and look for misting, sometimes the crap that accumulates in the dust seal can leave marks on the stanchion when you do this, if it does tell the seller it's leaky seals. If they don't have a clue there's some money off there. You can get a feel for the entire assembly here by clamping the front wheel between your legs and ragging the bars about.
Check the rear shock, as in get your phone torch shining in there (if a monoshock). Rear shocks new are not cheap, if it's shagged you want to know. Bounce the arse end up and down a bit make sure it returns to where it should.
Does 1 key match all the locks? Not essential but I'd want money off if not. It's a real pain in the arse having separate keys for ignition, tank & seat.
Check the MOT history before getting there, gives a good idea of condition and any mileage irregularities.
HPI check it before getting there. Finding a Cat D a seller didnt declare is a good way to disarm them and get the price negotiation going in your favour.
Rear sprocket, look for hooking. Chain look for condition, if the bike has a centre stand get it up on it and spin the back wheel. Front sprocket you have to go on faith, if the chain and rear look good assume it's ok. If the chain looks great but the rear sprocket looks half dead, pay attention to the chain they may have put some horrible £20 piece of crap there to look good for sale. Quick generalisation, if the chain is not branded DID, RK, AFAM or Regina then it is probably cheap Chinese shit that will last 5 minutes.
Condition of plastics..... if you buy something faired/half faired check on eBay that you can get pattern fairing kits from China. If you can then view damaged panels as on opportunity to knock money off. If you can't then walk away from knackered plastics, you don't want to buy your first bike and spend the next 3 months collecting panels from eBay.
Test ride it, check google maps beforehand so you know where you are going. You want a decent straight, no cameras. Redline at least the first few gears and accelerate as hard as you can with both wheels on the ground. If it jumps out of gears, walk away, it's been abused and you don't want to be stripping the transmission on your first bike. Similar vein try some slow speed stuff, make sure the clutch feels good.
Check for signs of track bike, not as common on a naked but not impossible (didn't the hornet have a series?). You are looking for signs of lockwire, so holes drilled through bolts. Sump plug is usually a good giveaway. Also if any body work is far better condition than the rest of the bike, this often points to track use (road fairings kept in a box, race fairings used on track).
The above is not exhaustive. If you can see it without stripping the bike, check it. If the seller is civilised they will offer you a brew anyway so you have plenty of time to go over the bike with a fine comb.
And never forget
- The seller is not your friend
- The seller wishes to extract maximum cash from you
- The seller is probably hiding something, having possibly spent many hours doing so they are not going to magically tell you just because you asked nicely.
- If you pay book/asking price you lost.
SmokeMeAKippe...
PostPosted: 07:46 - 13 Feb 2020    Post subject: Fireblade 929 Reply with quote
Hi guys. New member, lurked here and there on threads when generally googling bike stuff.
Anyways....I’ve been scouring the net for hours regarding a 929 I viewed last night and stumbled across an old thread on here that gave some info. I have just joined and there was a dude that seemed to know these bikes inside out. Signed up and PMd him. However I think putting a post out would help too. Get a collective opinion.
Anyhoos... onto business.
I’ve been offered a swap for a 929 for my 918. I shan’t bore you with the details but basically mines runs fine the 929 has some issues.
The guy reckoned there’s an rattling from clutch basket, fair enough. However on viewing this rattle was more of a knock. The bike idles with a solid knock every 2-3 seconds. Noise vanished when clutch lever is pulled in though. Also this noise took about 2-3 minutes before it started. Seemed to kick in when bike was warmed up. Defo coming from clutch basket/potential gear box area. My old boy reckons the gearbox is shagged. Anyone have any input?
Second, it started up on 2 cylinders, then 3rd cylinder kicked in after a minute or so. 4th didn’t. Thing bloody stank of fuel as well. Like really strong instantly after it was started and continued to smell. Guy says he’s changed over 2 pencil coils and had another 2 going spare but can’t be bothered to get back into bike as it’s too cold in his work shop to be farting about on bikes and he’s just not interested in the bike. He wants an older blade. There was also a hole in the exhaust can right at the bottom.
We had the bike up on a paddock stand to check it was running through the gears and it went through them without any untoward noises. Also the knocking went away under load. Only seemed to be there idling. It did hit a few false neutrals coming up through the gears though.
Other than that the bike looks well looked after. My dad reckoned it was a turkey but then he was talking me out of it before we even seen it. Too good to be true kinda thing which I understand.
The guy swapping says he simply wants an older blade and can’t be bothered fixing the minor faults. I can’t get the bike out my head tbh. So I’ve been researching as much as possible but it’s all rather vague and conflicting.
Obviously if I can justify the punt and these are easy fixes then I’ve won a watch.
The bikes an 01 on a Y plate and has 34k on it. Mines is a 99 on an X plate with 54k and is used all year round so as much as it’s not humped cosmetically it does have some “patina”
Any help would be really appreciated! Like I say I can’t seem to get the bike out my head. I’d just like to get some info on these bikes from folk who know them as my research so far has shown they’re defo a temperamental one and I could have the deal of the year, or a huge headache..
Cheers in advance, [/list]
CorriganJ
PostPosted: 09:37 - 13 Feb 2020    Post subject: Re: Fireblade 929 Reply with quote
Why would you swap a bike that works for one that doesn't?
SmokeMeAKippe...
PostPosted: 09:43 - 13 Feb 2020    Post subject: Reply with quote
Well ....
If it was a simple enough fix (the problems seem common enough let’s be fair) the bike would be worth more than mine.
The bike was newer and minted cosmetically
I fancied a change and the thought of an easy project enticed me
In between jobs and on a budget
I’m sure a few other reasons but I’m sure you get the jist. I was hoping for some feedback with similar experiences...
Cheers.
SmokeMeAKippe...
PostPosted: 10:54 - 13 Feb 2020    Post subject: Re: Fireblade 929 Reply with quote
Well ....
Cheers.
PostPosted: 13:03 - 13 Feb 2020    Post subject: Reply with quote
If the bike's your only transport it'd be a bit of a risk! Even so I'd be wary of swapping good bike for bad. If it was just a bargain bike I thought I could get working then it'd probably be the sort of stupid project I'd take on myself Wink
The cylinders not firing is probably something you could chase down - probably an electrical issue given the smell of fuel - but I don't like the sound of that knock so to speak!
If I were to take a guess I would say there's something loose that is stuck in a pool of cold oil and, once the oil warms up a bit, it wakes up and has a stroll around your crank case Shocked You'll not know unless you take a peek inside...
Could you say to the guy you'll seriously consider it but you must look inside first and offer him a fresh oil change if you decide against the bike?
SmokeMeAKippe...
PostPosted: 13:33 - 13 Feb 2020    Post subject: Reply with quote
Yeah man I only ride, all year round.
Scored a local job mind you as a support worker so waiting to start that so I’m not commuting now.
The guys got a video of clutch plate out and rattling. Also got a video of the bike running prior to viewing and the knock was nowhere near as bad. We sort of heard the knock then walked. He’s saying it goes away when it heats up further. We thought maybe a knackered piston...
The bikes stunning apart from the issues. It’s soooo tempting. Like i say he’s adamant it’s the clutch plate knocking. I managed to find one video on YouTube making similar knock from clutch but he never updated to whether it was fixed or not.
I’ve really researched loads before posting here so I know all the maybes kinda thing. I was hoping for someone who’s had direct experience of clutch basket issues to chip in. That’s not no say I’m brushing your input aside though. I’m honestly grateful for any help for sure.
I dunno I think because the deal is potentially so sweet I’m trying to find an excuse to say yes tbh. The fact is if it pays off I could ride through summer then punt for a tidy profit and shoot for a zx6 or r1. I mean looking at it financially the bike would break into more than mines is worth eventually. I’d sacrifice a summer of riding perhaps but could grab a winter bargain 🤔
I just wish I could have a direct “yeah that happened to me or my mate and this and that fixed it”
Like i say, I’m trying to sell it to myself by justifying the risk.
Cheers! Much appreciated!
Sorry zx10....
SmokeMeAKippe...
PostPosted: 13:45 - 13 Feb 2020    Post subject: Reply with quote
Oh... I did find that Honda issued a recall on certain VIN no’s for that exact fault. Bad clutch baskets. Without the VIN no I can’t be sure though, but again. It’s another possible route, although I don’t know how long recalls go and any further information on this is sparse so if anyone out there works for Honda I’d certainly be interested in info?
PostPosted: 13:47 - 13 Feb 2020    Post subject: Reply with quote
There'll always be another sweet deal, the 929 is common enough so there's no shortage of them.
If you were to end up needing to pay a garage to sort the noise out then the sweet deal will leave you with a sizeable bill.
In conclusion, I'd keep looking for bike, one that doesn't make bad noises. Wink
SmokeMeAKippe...
PostPosted: 13:51 - 13 Feb 2020    Post subject: Reply with quote
Yeah man it seems to be the general consensus all round so far. I know the bikes not going anywhere soon so I’ll live in hope. He’s quite firm he wants a swap and not cash so I do have the upper hand the now. He’s also fairly adamant he wants a 918. It’s a roll of the dice for sure.
Like you say though, always a bargain to be had.
Cheers!
SmokeMeAKippe...
PostPosted: 13:54 - 13 Feb 2020    Post subject: Reply with quote
To be fair as well I talked a mate OUT of buying a 928 in favour of the 954 only last summer because they aren’t perfect. He ended up with a zx12 though.
So yeah I think I’m just looking for a quick fix and when my brain slows down I’ll prolly end up taking my own advice. It was just such a nice wee bike. 😫
CorriganJ
PostPosted: 16:06 - 13 Feb 2020    Post subject: Re: Fireblade 929 Reply with quote
Well ....
If it was a simple enough fix... the bike would be worth more than mine.
It's a big if was my point.
That said, if you want, swap bikes, break / part this one out and buy something good with the profit? Lot of hassle though.
SmokeMeAKippe...
PostPosted: 16:16 - 13 Feb 2020    Post subject: Re: Fireblade 929 Reply with quote
Well ....
Well ....
Yeah man totally, I did figure that was yer angle. No hassles like, it’s all good.
I simply don’t know if it’s a big issue. If it was just a rattle like most reports of sale issue I’d be all over it like a dog at a burst ball. The knocking is quite a thud like, disappears with clutch lever in and no notice of it when pulling up through the gears. I couldn’t even swing it round the block as no insurance tax etc. Plus roads were snow/slush. We had to make do with it up on a paddock stand. The ads away now so I’m not sure if he’s decided to fix himself as he did say he might just do that then sell it. Or if someone’s took it.
I’ve asked him to keep me updated whilst I look into it anyways, seems nice enough so if he’s sold it I’m sure he’ll let me know. He also liked my bike so I did offer a potential px if it was fixed 100%.
And yeah braking it was a worst case scenario if I went through with the deal after some info.
Cheers.
PostPosted: 19:50 - 13 Feb 2020    Post subject: Reply with quote
There's no problem that's insurmountable given enough time or money...
If the engine's fucked how do you feel about a complete engine rebuild? If the answer isn't "that sounds like fun!" move along Wink
SmokeMeAKippe...
PostPosted: 19:55 - 13 Feb 2020    Post subject: Reply with quote
He’s keeping the bike now anyways. Has ordered parts up. Fair play and best of luck to him! My blade still puts a smile on my face so no love lost and some knowledge gained in general. Every cloud and all that.
Cheers guys
The last post was made 5 years, 254 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 0.64 - MySQL Queries: 15 - Page Size: 145.3 Kb
