| Tp1992 |
 Tp1992 L Plate Warrior
 Posted: 04:07 - 10 Mar 2020 Post subject: Spray Painting Air Compressor help |
Hi,
Sorry if this has been asked before but I just wanted to put the question out there myself to get a answer for the specific model I'm looking at.
So I've been wanting to spray my bike for a long time and now I've finally decided to go a head with it and looking for any advice or info on equipment.
https://www.spraygunsdirect.co.uk/index.php/compressors-kits/standard-compressors/sealey-compressor-24-litre-2hp-6-8cfm-displacement.html#sthash.a1RHHXrC.dpbs
I'm looking to get this air compressor and would like to know if it'll be suitable for what I intend to do. I have a CB600F Hornet and would like to sprey the tank and plastics.
If this air compressor isn't suitable for the job then any recommendations would be appreciated
I have a rough idea of the other equipment I need just not sure on the air compressor, are these things worth buying second hand to save a bit of money? |
| MCN |
 MCN Super Spammer
| Hawkeye1250FA |
 Hawkeye1250FA World Chat Champion
| stinkwheel |
 Posted: 13:28 - 10 Mar 2020 Post subject: |
More volume is more volume, they go through air very quickly.
Oil-less bearings for preference.
Other considerations are:
1) Spray booth. The overspray makes a horrendous mess. It gets absolutely everywhere (including under doors, through keyholes, up under dust sheets). Also keeps dust off your piece. Ideally a sealed area with ventilation or all that overspray settles again. You can buy popup tent type spraybooths if you don't have an area you can section off.
2) PPE. Proper respirator or forced air ventilator, not just a dust mask. Most especially if you are using 2k paints. Minimum P3 mask for spraying normal paints. I'd want a proper forced air respirator (plugs into compressor, which you locate away from where you're spraying so it doesn't suck in the overspray) or gas mask for 2k coatings. They give off nasty fumes. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
 - Super Spammer
| Baffler186 |
 Baffler186 World Chat Champion
| dynax |
 dynax Trackday Trickster
| megaross |
 megaross Borekit Bruiser
| stirlinggaz |
 stirlinggaz World Chat Champion
| sickpup |
 sickpup Old Timer
| stirlinggaz |
The last post was made 5 years, 333 days ago. Instead of replying here, would creating a new thread be more useful? |
