| droog |
 droog Spanner Monkey
| stinkwheel |
 Posted: 16:30 - 13 May 2020 Post subject: |
Why not both. So they only come on with high beams AND when switched on?
I'd go battery > Fuse > Switch > Relay > Spot.
Use a SPNO automotive relay (also called 4-pin). I'd use a take-off from the hi-beam telltale to trigger the relay so if it buggers up, you don't lose the lights.
Relay pinout:
30- feed from switch.
85 - Trigger from hi-beam indicator
86 - earth
87 - output to spot.
You can get fused relays but I preferr to use a fuse nearer the battery, or you may have an existing "spare" accessory fuse you could use.
If you have canbus wiring, the above may not apply. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Easy-X |
 Easy-X Super Spammer
 Posted: 16:33 - 13 May 2020 Post subject: |
Spotlights are auxiliaries that you'll probably not be doing a fantastic job of aligning In which case you should have them on their own switch so they can be disregarded for the MoT. ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Nobby the Bastard |
| droog |
 Posted: 20:13 - 13 May 2020 Post subject: |
Thanks guys - lot's of food for thought there - will ponder your advice - much appreciated -
(thanks for the detailed stuff Mr Stinkwheel - cheers)  |
The last post was made 6 years, 167 days ago. Instead of replying here, would creating a new thread be more useful? |
