| Chrisjlm |
 Chrisjlm Derestricted Danger
| NJD |
 NJD World Chat Champion
| Ste |
 Ste Not Work Safe
| dynax |
 dynax Trackday Trickster
| stinkwheel |
 Posted: 15:57 - 04 Oct 2020 Post subject: |
If the valve was jammed, the pump would offer a lot of resistance. If air is going out of the pump but the tyre isn't inflating, you have a puncture.
If you're getting nothing at all even with a compressor, I'd guess the valve has torn off the tube. This is a common issue if you run on an underinflated/flat tyre and the tyre itself slips round on the rim.
If this is what happened and you are running low tyre pressures for offroad grip, consider fitting a rimlock. Or if you aren't using it on the road at all, a mousse.
I run my trials bike at 6psi and the tyre can still slip, even with a rimlock. I never screw the little nut down against the rim for this reason. I put the valve cap on and screw the nut up against it, then if the tyre moves slightly, I'll notice the valve sitting at an odd angle. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Chrisjlm |
 Posted: 17:04 - 04 Oct 2020 Post subject: |
So I got the inner tube out and it had completely torn away from the valve. I guess it’s just a case of fitting a new tube then. Any advice on stopping it happening again?
https://ibb.co/wzXgcwG
https://ibb.co/1Tb0fsP |
| yen_powell |
 yen_powell World Chat Champion
| Riejufixing |
 Riejufixing World Chat Champion
| stinkwheel |
 Posted: 18:06 - 04 Oct 2020 Post subject: |
In addition to my previous about running soft tyres etc, you also need to ensure the tyre is properly seated onthe rim when you fit it. There is a thin line on the outside of the tyre sidewall all the way around. You need to make sure you can see this an equal distance from the rim all the way round on both sides.
It can take a lot of pressure to achieve this. I had to put 90psi into the roadrider front tyre on my Enfield with the valve core out to get it fully seated. Once seated, I let the air out again, re-fitted the valve core and inflated it to the correct pressure. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Riejufixing |
| stinkwheel |
| Jozzer |
 Jozzer Two Stroke Sniffer
| blurredman |
 blurredman World Chat Champion
 Posted: 12:18 - 05 Oct 2020 Post subject: |
Some tyres indeed can be pigs to re-install, esspecially if they're more inclined for tubeless applications. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 - 40k, 1989 MZ ETZ251 - 52k. |
| redeem ouzzer |
 redeem ouzzer World Chat Champion
| steve the grease |
 steve the grease Crazy Courier
 Posted: 18:51 - 05 Oct 2020 Post subject: |
| Riejufixing wrote: |
90 psi That's dangerous. You should use tyre paste. |
When I briefly worked in a remould factory the tyre carcasses , once all the tread had been scrubbed off, where mounted on a rim and inflated to 150 psi to check for bulges , punctures etc. So, whilst 90 psi is 'a lot of pressure' which it is, a healthy tyre should easily be able to stand that, for a short time at least. ____________________ All the above is my personal opinion, you can see my lips move, but I'm talking out of my arse.
I've been riding, and fixing , bikes for 50 years, in that time the more I learn, the less I am absolutely sure of..... |
| Jozzer |
 Posted: 19:07 - 05 Oct 2020 Post subject: |
| steve the grease wrote: | | Riejufixing wrote: |
When I briefly worked in a remould factory the tyre carcasses , once all the tread had been scrubbed off, where mounted on a rim and inflated to 150 psi to check for bulges , punctures etc. So, whilst 90 psi is 'a lot of pressure' which it is, a healthy tyre should easily be able to stand that, for a short time at least. |
Yup, quite agree buddy, I used to work for ATS, 90 should be fine as long as the tyre is in good condition, wouldn't wanna go too far though, 100/110 tops on a 4ply radial...
11-22.5 10ply truck tyres run 100-110 anyway...
It's all in the square inch/volume of the tyre, pressure has little bearing on it...  |
| Polarbear |
 Polarbear Super Spammer
| Ste |
 Ste Not Work Safe
| Johnnythefox |
 Johnnythefox Traffic Copper
| Jozzer |
| oilyrag |
 oilyrag Nova Slayer
| Evil Hans |
 Evil Hans World Chat Champion
 Posted: 01:09 - 12 Oct 2020 Post subject: |
| Polarbear |
| Riejufixing |
The last post was made 6 years, 8 days ago. Instead of replying here, would creating a new thread be more useful? |
