1996 Honda XR400RT rear suspension
 Topic moved: from Forum Feedback & Help to The Workshop by stinkwheel (4 Mar 2021 - 11:44)
Pedro Oz
PostPosted: 07:42 - 04 Mar 2021    Post subject: 1996 Honda XR400RT rear suspension Reply with quote
Need to fit grease nipples on all my linkage points. Has anyone done this. It seems pointless pulling everything down just to get grease in when various well placed nipples would suffice
MCN
PostPosted: 10:19 - 04 Mar 2021    Post subject: Reply with quote
Grease paths can be weaknesses in Load Paths.
Many manufacturers fit sealed for life or 'lifetime fit.
That means, lasts until a certain mileage has been reached. (With average use)
Fitting after market could be problematic where an engineered area design excludes lube points for a reason.
Welcome to mayhem.
And you should post this sort of subject in the Workshop section. Thumbs Up
PostPosted: 12:50 - 04 Mar 2021    Post subject: Reply with quote
Had it done on my GPZ500 unitrak. Had custom made bronze bushings fitted at the same time. That bike had plastic ones as standard and it was a piece of poor budget-driven design. The bronze bush/greaee nipple combo saved having to replace bushings annually at the MOT. Although I'd expect your bike would have roller bearings?
If you do fit nipples, plan the location well so you can a) Get at them when the parts are on the bike and b) They don't foul anything in their range of movement.
All that said, greasing bearing linkages isn't a job you tend to need to do very often UNLESS you are in an extreme environment with lots of water and dust getting into the linkages. Then I'd question if you wouldn't be better stripping and cleaning it all anyway because adding more grease is no good if the bearing is contaminated.
Fizzer Thou
PostPosted: 14:48 - 05 Mar 2021    Post subject: Reply with quote
Owning a Honda XR400R as I do,I can say that the needle roller bearings are caged and there are no positions where a Zerck fitting can ideally be located.If the seals are good then an annual service in the lower shock mount area does not go amiss.
The main area of attention is the swing arm pivot shaft as this passes through the frame,the swing arm and the back of the engine.The number of people that I have heard of having real difficulty removing seized components runs into double figures.Be sure to utilise high melting point grease Thumbs Up
Always have a 'Plan B'
trevor saxe-coburg-gotha
PostPosted: 17:34 - 05 Mar 2021    Post subject: Reply with quote
vanvans had plastic bushings - someone machined up some bronze ones
they were great except for one thing - they squeaked like fuck on some bikes iirc
The last post was made 5 years, 234 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.67 - MySQL Queries: 17 - Page Size: 45.05 Kb
