| c_dug |
 c_dug Super Spammer
 Posted: 22:27 - 04 Mar 2021 Post subject: Anybody else have constant issues with Pinlock? |
I've had maybe six or seven different helmets with Pinlock across four manufacturers in the last ten years, and without fail they have all ended up shaking around, scuffing themselves and/or the visor, and steaming up on the inside.
The obvious thing is to say I'm fitting them wrong or maintaining them wrong, but I've actually been to bike shops and had them fitted from brand new on more than one occasion, and followed countless guides to cleaning and adjusting.
Without fail they end up loose and shaking around.
On my last visor I took to running a thin line of tape around the outside of the Pinlock which was excellent, but I don't see anybody else having to do the same? And in any case there was already damage by the time I thought to do this.
I've just bought a new visor and pinlock and this time I'm tempted to run a very thin bead of silicone sealant around the join.
Curious on if anybody else has these issues, or any suggestions? ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
| kgm |
 kgm World Chat Champion
| Weisse Schlange |
 Weisse Schlange Spanner Monkey
| MCN |
 MCN Super Spammer
 Posted: 00:16 - 05 Mar 2021 Post subject: |
Nope, never, ever.
The pins have a cam on them.
If the insert is loose, pop the pins out.
Insert in the holes so the offset of the cams are facing in.
Insert the insert.
Be careful when handling the insert as the inside surface coating is easily damaged.
https://pinlock.com/support/ ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| FretGrinder |
 FretGrinder World Chat Champion
| Easy-X |
 Easy-X Super Spammer
| MarJay |
 MarJay But it's British!
| Fat Angry Scotsman |
 Fat Angry Scotsman World Chat Champion
| tom_e |
 tom_e Brolly Dolly
| Copycat73 |
 Copycat73 World Chat Champion
| MCN |
 MCN Super Spammer
| Copycat73 |
| c_dug |
 c_dug Super Spammer
| stinkwheel |
 Posted: 21:02 - 05 Mar 2021 Post subject: |
Yes. Every time.
They also fog up. I find they produce marginally better vision during daylight but cause so much flare and starburst at night from oncoming headlights that I'm better without them.
Useless waste of money. Emperors new clothes. People can't believe they spent £20 on a piece of plastic and convince themselves it was a good idea.
EDIT: All the disciples will try to tell you you are using it incorrectly. Last one I had on my Arai was supplied by an arai specialist in York, already fitted to a new visor because I told them there was no way I was putting a screwdriver anywhere near an new £45 visor.
It became the worlds most expensive tear-off before Scotch Corner because I was doing 100mph on a dark motorway and couldn't see where the fuck I was going. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| kgm |
| Pigeon |
 Pigeon World Chat Champion
| stinkwheel |
| MarJay |
| stinkwheel |
 Posted: 12:41 - 06 Mar 2021 Post subject: |
They make double-glazed visors with electrical heating elements in them in the US for use in snowmobiles. They just don't let enough light through for UK regs.
You can retrofit them to HJC lids. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| MarJay |
| stinkwheel |
 Posted: 13:49 - 06 Mar 2021 Post subject: |
AYe, thing is, as pinlocks demonstrate, the coatings only work up to a point. That point being when you really need it to work. If the inside of your helmet reaches dew point, a coating is going to do fuck-all. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| MCN |
 MCN Super Spammer
 Posted: 16:51 - 06 Mar 2021 Post subject: |
Im a disciple
I used Fag-City years ago but they were a bit of DIY to fit and pernickety AF to align properly.
If you got it wrong then it was a new visor and a new insert that was required as they use/d some strong AF adhesive to stop it coming off and to maintain the air tight seal. Same principle as Pinlock.
Double Glazing.
The issue I have, that is the only criticism I can honestly level at a Pinlock insert, is that they can only deal with so much humidity and cold.
They are trying to defy the laws of fizix.
The water in humid air will condense on cold surfaces
In winter on those minging wet cold days the atmospheric conditions probably overwhelm the device.
The coating is a moisture absorber.
If it's already loaded with moisture then fitted to a visor then any air that is trapped plus the absorbed air will freeze or fog.
Winter riding and some summer riding in rain is difficult and systems are just not available that can cope with 100% of the problems.
There's device around called Precipitation Friend or something like that. Think it's crowd funded.
It's probably shite too. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| Kentol750 |
 Kentol750 World Chat Champion
| DJP |
 DJP Crazy Courier
 Posted: 12:24 - 07 Mar 2021 Post subject: |
The factory fit one on my Nolan is great but the retro fit ones I've had have been a bit iffy. ____________________ Suzuki Bandit 1250
https://deejayp999.atwebpages.com/index.html
That's http not https |
| BRUN |
 BRUN Trackday Trickster
The last post was made 5 years, 202 days ago. Instead of replying here, would creating a new thread be more useful? |
