Separate rebound and compression
PotatoHead202...
PostPosted: 21:56 - 10 Aug 2021    Post subject: Separate rebound and compression Reply with quote
Finally decided on a nitron shock for the vfr but now can't decide between r1 and r2. £700 is the absolute max (there goes my bonus) so no ohlins etc
Will the extra adjustability be worth jt? I want rid of the bouncing out the saddle experience on the oem shock.
I just want as smooth as possible
Suzuki V Strom 1050XT, Honda CBF500 ABS,
PostPosted: 08:22 - 11 Aug 2021    Post subject: Reply with quote
I had the R1 on my VFR800, and it was great. The balance between rebound and compression was better than on most dual adjustable shocks. Once I got the damping dialled in, it just worked and made the bike feel epic.
For the road it's not worth the extra unless you want to spend money on bling. Nitron REALLY know what they are doing, and even in their most basic shock it shows.
Fizzer Thou
PostPosted: 11:01 - 11 Aug 2021    Post subject: Reply with quote
Either the Nitron....or the YSS shock,which I have read are good value for money.This and a pair of K-Tech fork springs for £85 would give a good balance
https://www.brooksuspension.co.uk/honda-vfr1200x-yss-shock-absorber-12-16/
Always have a 'Plan B'
PostPosted: 12:12 - 11 Aug 2021    Post subject: Reply with quote
The YSS and the Nitron don't deserve to be in the same sentence. YSS is an OEM replacement, Nitron is on another level.
PotatoHead202...
PostPosted: 16:25 - 11 Aug 2021    Post subject: Reply with quote
How was it in places such as overtaking on hashed lines etc? Finding that awful at the moment with the stock one. Fairly compliant?
PostPosted: 19:23 - 11 Aug 2021    Post subject: Reply with quote
Better, yes, but the old one literally had no damping left. You're right though, overtaking on bumps and ripples in the road was AWFUL until the new shock made it buttery smooth.
Fizzer Thou
PostPosted: 23:34 - 11 Aug 2021    Post subject: Reply with quote
I did not say they were on a par...only that the YSS is a consideration ....
If the VFR1200 is a keeper then spending the extra on a Nitron is worthwhile Thumbs Up
When I replaced the OEM shock on the R1 with an Ohlins I very quickly realised that the front end needed some attention.The Ohlins front springs complemented the shock fitment considerably Thumbs Up Cool Thumbs Up
PotatoHead202...
PostPosted: 12:11 - 12 Aug 2021    Post subject: Reply with quote
[/quote]
When I replaced the OEM shock on the R1 with an Ohlins I very quickly realised that the front end needed some attention.The Ohlins front springs complemented the shock fitment considerably Thumbs Up Cool Thumbs Up[/quote]
Oh i'm definitely set on it. Consensus at the moment seems to be the R2 is overkill for the road. Have put K Tech springs in the front which are much, much better albeit I may get a piston kit
Blah blah
PostPosted: 16:51 - 12 Aug 2021    Post subject: Reply with quote
I've got an ohlins on the back of my Monster, with separate canisters for rebound and compression.
I've touched neither of them since I put it on the bike and TBH would rather have the bit of space back that they take under the seat.
If I was doing it again, I'd go for a 'basic' Nitron
The last post was made 4 years, 277 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2 - MySQL Queries: 14 - Page Size: 64.53 Kb
