Single phase alternator winding pattern
PostPosted: 13:53 - 29 Jul 2021    Post subject: Single phase alternator winding pattern Reply with quote
This is complex. I'm a bit out of my depth with it.
The alternator I have on my Enfield is an aftermarket one. As purchased, it was made with an AC/DC setup. What turns out to be a very small, single DC coil to slowly charge a diddy battery and a much meatier three coil AC output for lighting. It turns out it was setup with an AC regulator and a halfwave rectifier for the DC.
Here's the stator I have:
https://lh3.googleusercontent.com/pw/AM-JKLWCge-Mx9EhF3Nmn3vMO5gIfEoOvnzOp69Lt_3aTPwpq1vUQ0V16rUPyXWB51CK4zdS18qKLudhSJCiT7_b97994Cki5RQVVPV75v6dQxgv7GYMb_ZSc78P5_mK6SZ9i-wg3TelyY2oLYyENYlsAGd6=w1182-h886-no
The top coil, wrapped in black is for the ignition and is totally seperate.
It has a white, yellow and black wire. Black is ground.
The AC comes in on the yellow, takes 20 clockwise turns round the left coil, 100 turns anticlockwise round the bottom coil and 100 turns clockwise round the right coil and terminates to ground.
The DC comes in on the white, takes 80 turns clockwise round the left coil over the top of the AC winding then terminates on the yellow.
I want to convert this to single phase DC. I have a proper, single-phase DC reg/rec now.
The company now sells a DC stator for this exact purpose. Thing it it's a) out of stock and b) £150.
It does however use exactly the same base plate and rotor. Here's the only picture I can find of the DC stator:
https://lh3.googleusercontent.com/pw/AM-JKLWLnA2-pVsDVjtziR0Rtao4SFq7OrYSTSdBWE4l-bAxs1RirhA2tH2E0rs8V0r1j-hkToZFREmpTFcCcemMTl8izaZ1el1cdyExIfccILFWmrwClpkokdAJvPe69jI11KOYStNLm66cYTWPKa6yfPcF=w693-h462-no
I think it's a fair assumption each coil still holds 100 turns and is using the same gauge wire. My question is, how should I wind it? I see two options (but there may be more);
Option 1:
Wap 100 turns round each in turn. Then take the end back to the other output.
Option 2:
Wrap 50 turns round the bottom and left coils, `100 round the right then come back with another 50 turns on the bottom and left coils.
I have a feeling it actually makes no difference?
Then direction? Looking at the picture, it seems as if the left and right are wound anticlockwise and the bottom is wound clockwise but it's not easy to see. This roughly fits with how they did the AC output on the original (bottom wound the opposite direction to the left and right).
Or am I going to set fire to my bike?
steve the grease
PostPosted: 15:12 - 29 Jul 2021    Post subject: Reply with quote
Thanks for the drawings. You need to take phasing into consideration as windings could add or cancel each other out. If the curves lay on top of each other they will add - doubling the current ( on the assumption that the amplitude is the voltage) if the curves are in opposition they will cancel each out, wholly or partially depending on phasing.
PostPosted: 15:24 - 29 Jul 2021    Post subject: Reply with quote
I thought direction might make a difference because a north pole magnet may be going over one coil as a south goes over another.
I did some fag-packet sketches of what i have now and what I'm proposing.
https://lh3.googleusercontent.com/pw/AM-JKLXQFSyN4ufht9KSKzC1SkDGiboJcG7spq5bwogo2vG4M-yjccmCRG2ohrv978v9WsSB1NG-Y57jAp4YpTVZmU4jbJSkZMqxnQDafHp0Qg3s8TGpoEbSLpXlsr6qVNzbEcv0n7XquNl51jyXIEO6ZU6p=w499-h886-no
Or should I be paralelling the windings. Like this?
https://lh3.googleusercontent.com/pw/AM-JKLWO-xI6lrM43pJ0gVd4S3Vg-frSgQ8lcVwGs7AEeLdbbsvThSDHL3S3_G-1JwSlwPgqjPm3fku-BqwyHQoyfOv3cVIAhkfgmgvNBEjL7jIoyc7PLGeYwWf7hJeJx1iGKt8nkryIjQpv2riZ8NvYh_mY=w1576-h886-no
PostPosted: 15:38 - 29 Jul 2021    Post subject: Reply with quote
Aha.
A mate just came up with this from an electonics textbook which seems to fit the ticket. Effectively 100 round each and back to the start with the "bottom" coil wound in the opposite direction to the two side ones.
WD Forte
PostPosted: 19:21 - 29 Jul 2021    Post subject: Reply with quote
I find this thread prompts questions
Are you going for a full 12v negative ground system
for both lights and ignition as used on most bikes?
this would make many common(cheap) electrical parts available
to you.
Its what I'd do
or is this a part old, part new hybrid type thing?
what is the expected load?
why single phase?
how many magnets on the rotor?
bikers smell of wee
PostPosted: 20:59 - 29 Jul 2021    Post subject: Reply with quote
stinkwheel wrote:
Aha.
That diagram is indicative of a typical basic setup you have the same number of coils as magnet poles and it generates two full waveforms per revolution. You need to check how many coils vs how many magnet poles you have to decide on the winding arrangement.
Series vs parallel:
Almost certainly series is going to be a winner. In series the voltage produced by each coil is cumulative so if a 100-turn coil produces 6v then your 100+100+20 will produce 13.2v.
Now the charging coil being connected to the head of the lighting coils could just be a way of boosting the AC lighting circuit output enough to provide the extra for rectifying in order to charge the battery in other words the lighting circuit does dual duty with the charging circuit 'topping it up' for charging. I don't know the significance of having the lighting circuit connectd to the Reg/Rec.
The fact that your bike has a LED light which presumably requires a 12vdc input to the driver explains why the system has fallen over - the original lights needing no recitification means the charging system needed only to provide DC for the ignitioncoil and horn and whatever other minimal load now suddenly has to provide 10+ amps for the LED driver.
The picture of the DC stator is I think deceiving. IMO it should have four identical coils of equal turns of heavier wire. No reason to have that extra black coil in there but having four equal ones would improve efficiency a lot. I think thay have put up a stock image of a ac/dc stator.
PostPosted: 00:49 - 30 Jul 2021    Post subject: Reply with quote
I should say, I've unwound the stator. it's the only way I found out what was going on. I was expecting a straight single-phase setup. Metering it suggested a short in the windings. it turned out that the lighting coils earth to the chassis and that little 80 turn single coil on the left is the only charging output
The top black coil is nothing to do with the charging system. It's an integrated ignition generator coil and hall effect sensor which is connected directly to the CDI on a stand-alone circuit. It both produces and times the spark. This works very well and reliably. The other three coils deal with the lighting and charging.
My 12V LED lighting system draws 2.1A total when running off a battery. That's full beam, brake light on and flashers running. Yes I'm going for 12V negative earth. I'm using a capacitor in place of the battery. The rotor is fully enclosed but I believe there are eight magnets.
It's all a bit of a workaround. These bikes were originally designed to run on a magneto mounted behind the engine. They changed them in the mid 60's to charge from a standard lucas alternator on the end of the crank but there was no room for the points so they kept them on the end of the shaft that used to run the mag.
This is a performance engine so the 11 degrees of backlash you get on the standard ignition timing gears is unacceptable. This is the only system that can run both charging and ignition off the end of the crank but space is very tight (it was originally designed to only have the primary drive in there). The rotor diameter is small and there isn't much space for the charging coils. As such, the ability to generate power is a compromise.
Pete. wrote:
Series vs parallel:
This is the direction I'm leaning in. I briefly considered trying to make it 3-phase but I don't think it'll fly. It would give a clean(er) output but not enough of a peak from each coil. I just don't think they're big enough to give a 12V RMS from each one. It's going to have to kick it up on each coil. Hopefully the capacitor is big enough to smooth out the dips in the single AC phase but I can add another one if needed.
Here's where an oscilloscope would be handy. But I don't have one so I'll wind it as three coils in series and see what the output looks like on the meter. If it's putting out plenty of power, it would be comparatively easy to seperate the coils into a more conventional 3-phase star configuration. There again, if it's putting out plenty of power, there's probably no need to.
PostPosted: 06:23 - 30 Jul 2021    Post subject: Reply with quote
I had no idea that the LED drew so little.
When you un-wound the stator did you find any fault or evidence of shorting? Any portion of the winding wire discoloured? Usually a short in a coil makes at least some of it turn black and crispy.
You say that the coils are dirty-earthed through the base of the stator? Bit poor really it could possibly be the source of your fault. It's a thing that work fine when it works (which is most of the time) but it much more reliable when loom earths are used hence why all those 70's Japanese bike indictors with just a feed wire and dirty earth return were replaced with 2-wire units.
PostPosted: 09:31 - 30 Jul 2021    Post subject: Reply with quote
Windings were fine as it turned out. I'd done the usual tests expecting my two output wires to be isolated from earth like a straight single phase alternator. Only ones I've seen earth the lighting coil through the frame have been small capacity jap bikes with those crescent-shaped single coils. I knew there was a radial pattern of coils so I wasn't expecting continuity with earth. It wasn't until I got it mostly unwrapped I saw the end of the main wire soldered to the backing plate.
It all seems like a bit of a lash-up in terms of design (although neat enough in execution). I presume the manufacturer thought so too because they don't make this type any more. New ones are configured for a conventional, single-phase, regulated and rectified DC output. I'm just trying to work out how they've done it so I can replicate that.
Not that I'm criticising them because if I'd used it how it was designed to be used, I'd have a dim but functional lighting system. The upshot is, it wasn't what I thought it was and they way I was trying to use it would never have worked. Because the coil is a circuit to earth, there's nowhere for a voltage regulator to dump to.
WD Forte
PostPosted: 16:45 - 30 Jul 2021    Post subject: Reply with quote
Its probably a project that needs some experimenting
and woudl love to put my scope on it but
my initial thoughts on a single phase setup would be to
wind all the bobbin in the same direction as in your proposed setup pic
This cos as the coils are at 90 degree intervals and the rotor has 8 ( or 4)
magnets, all windings will be swept by the same N or S pole at the same time
Make sure to sleeve and insulate the wire from the engine body(ground) and run both
tails to something like this which I assume/hope has a full wave bridge rectifier inside
as well as voltage regulation
https://i.ebayimg.com/images/g/~EwAAOSw5W9e62Zp/s-l1600.jpg
https://www.ebay.co.uk/itm/313119747851?hash=item48e7642f0b:g:~EwAAOSw5W9e62Zp
On the output as well as a big cap, I'd add a smaller secondary cap for extra ripple smoothing
as leds tend to react a lot more to voltage variations than an incandescent blub.
I'd consider using a weeny scooter battery if voltages allow as this can help smooth out voltages
I can only guess but comparing it to similar setups I reckon you may get say 70-80 watts/6A-ish out of it
which is enough to run a 20w headlight which will be fookin bright!
Be wary when buying led headlamps as I've seen many sellers state the equivalent power rather then actual which can be misleading
and say its 100W when in reality it uses 20W of real power
bikers smell of wee
The last post was made 4 years, 315 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.74 - MySQL Queries: 14 - Page Size: 78.37 Kb
