2003 Varadero 125 running bad when hot
Glades
PostPosted: 16:11 - 15 Feb 2022    Post subject: 2003 Varadero 125 running bad when hot Reply with quote
So I've had this bike almost a year now but over the past few weeks its been developing an issue with spluttering after a few miles. I was serviced when I got it and I've been keeping up with maintenance. Just got it onto the stand to swap out some brake pads and noticed petrol dripping from the exhaust, a decent bit. I have no idea what it is, fuel/air should be right, idles at 1.5-2k at operating temp when its not having issues. Any advice or where I should start looking would be appreciated.
Its a 2003 Honda Varadero 125cc carbed Vtwin
A̶l̶m̶o̶s̶t̶ On the road again
Nobby the Bastard
Harley Gaydar
PostPosted: 16:17 - 15 Feb 2022    Post subject: Reply with quote
Petrol would not drip from the exhaust. Its probably water.
Triumph Sprint ST 1050
WD Forte
PostPosted: 19:39 - 15 Feb 2022    Post subject: Reply with quote
It's old enough to have developed all manner of issues
so may need a wee bit of TLC to get it sorted
Moisture from the exhaust may just be condensation
or it may be a head gasket issue
I'd have a look in the header tank as it's running to see if there
are any signs like bubbles
I'd also check the plug colour
If they're sooty it may be running rich and start easy but get finicky as it warms up and so point to a carb problem
If it actually is petrol ( which we doubt) that's a serious failure of the fuel system and that much fuel in the cylinder would probably soak the plug and stop that cylinder running
bikers smell of wee
Glades
PostPosted: 19:52 - 15 Feb 2022    Post subject: Reply with quote
Smells like petrol, burns like petrol. Its petrol.
Glades
PostPosted: 20:00 - 15 Feb 2022    Post subject: Reply with quote
By the feel of it, it could absolutely be a cylinder not firing, Ill pull the plugs tomorrow and check for that soot. Ill try running it leaner too and see if that makes any difference. I replaced the battery not long ago when it was dropping charge so I'll just make sure the plugs are getting that power. Could it be an issue with one of the carbs not opening/closing?
Nobby the Bastard
Harley Gaydar
PostPosted: 20:33 - 15 Feb 2022    Post subject: Reply with quote
99% of fuelling issues are electrical. Check for spark on both cylinders whilst it it splittering, preferably with a spare plug.
WD Forte
PostPosted: 21:48 - 15 Feb 2022    Post subject: Reply with quote
I wouldn't mess about with mixture
you want the right stoichiometric value roughly 14:1
fiddling won't solve anything
You want to remove possible issues not add them
If one cylinder is flooding badly , I'd suspect something like a faulty float chamber valve not shutting off the flow
(maybe age hardened) or a float not err 'floating' properly.
At that age I'd hope to see an inline filter to keep crap out of the carbs.
Does it have a manual or auto choke?
check its function on both carbs either way.
bikers smell of wee
Zen Dog
PostPosted: 01:56 - 16 Feb 2022    Post subject: Re: 2003 Varadero 125 running bad when hot Reply with quote
Glades wrote:
...its been developing an issue with spluttering after a few miles...noticed petrol dripping from the exhaust, a decent bit.
Ok, so first just to clear up any potential misunderstandings. When you say petrol is dripping from the exhaust, do you mean "petrol is coming out of the end of exhaust can from the inside" or do you mean "petrol is running from *somewhere* onto the outside of the exhaust and dripping off"? Or something else? Was the bike running while this was happening?
If it's the second option, could it be a sticky float valve on the carbs? Failing to close sometimes and coming out a badly routed/missing overflow (and so petrol on exhaust). And other times failing to keep the float chamber full enough (and causing spluttering)?
Current - '94 VFR750FR (Dead), '00 VFR800FI, 2011 CBF125 Previous - '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win (chinese copy of an old Honda design with a C90 engine)
Tdibs
PostPosted: 04:36 - 16 Feb 2022    Post subject: Reply with quote
Does it drop to one cylinder after running for a while?
Replace HT lead/plug cap. Will explain dripping fuel out of exhaust but that is a extreme amount.
Also worth cleaning your plugs when fitting new leads - the bad lead cylinder will be rich as hell.
Other option is is a bad petcock/float - but this would likely be pooling fuel when the bike is off and making it very hard to start.
Video would help.
Islander
PostPosted: 09:20 - 16 Feb 2022    Post subject: Reply with quote
If you've got petrol coming out of your exhaust the I'd recommend checking that you haven't got any in your engine oil as well as the plug/lead/coil checks...
Also, this made I chuckle somewhat...
WD Forte
PostPosted: 13:32 - 16 Feb 2022    Post subject: Reply with quote
Thas yer modern science mate
Rigorous mathematical exactitude is like well rassis innit?
so we has to allow variations for culteral/gender differences.
bikers smell of wee
Glades
PostPosted: 16:58 - 16 Feb 2022    Post subject: Re: 2003 Varadero 125 running bad when hot Reply with quote
The bike had been well ridden up until 5 mins prior, the petrol was dripping from inside the exhaust. I was hoping it was a crack in the tank or a fuel line but no hope.
Glades
PostPosted: 17:05 - 16 Feb 2022    Post subject: Reply with quote
Video would help.
The bike is very hard to start once it is shut off but returns to its easy ignition one cold again. If we are assuming that its dropping a cylinder then yes, Id guess about 5 mins after getting to temp I can expect it to drop once I release the throttle, up to that point it works perfectly with full power.
Until I've sorted this somewhat, Im a bit doubtful of riding it so I wont be able to get a video til then. Hopefully at that point there wont be any issues
Glades
PostPosted: 17:13 - 16 Feb 2022    Post subject: Reply with quote
I'm happy to work with direct injection but Im very unfamiliar with carburetors so Id like to try everything else before stripping and rebuilding them. It has no filters, Ive ordered an aftermarket one once I found out, should be here tomorrow.
Choke is manual but broke af, got it like that and I havnt had issues starting for almost a year until now, previous owner never had issues either.
Im starting to think i may be a carb issue which Im dreading as it isnt easy to get to them in the first place
jaffa90
PostPosted: 17:37 - 16 Feb 2022    Post subject: Reply with quote
"""" Choke is manual but broke af, got it like that """"
It was serviced when i got it???
I`ve been keeping up with the maintenance ????
Shocked Shocked Shocked Shocked
Nobby the Bastard
Harley Gaydar
PostPosted: 18:21 - 16 Feb 2022    Post subject: Reply with quote
Can't see.how it would work fine when cold but gash when hot when petrol is pissing out of the exhaust.
Glades
PostPosted: 19:02 - 16 Feb 2022    Post subject: Reply with quote
There has been no need to fix it, dont fix what aint broke
...ok it is broke but engine works and has, choke isnt the problem
Glades
PostPosted: 19:09 - 16 Feb 2022    Post subject: Reply with quote
This is why Im here because I have absolutely no idea either. Im no expert and I certainly don't claim to be.
My best guess from what I've gathered here is that one piston works fine as I've always got -some- power when I get on throttle but not as much as normal. Idle is weird when its like that but rarely dies so something is keeping it alive.
A question for anyone who knows carbs- does the needle jet shut off once the main jet begins working or do all three jets supply at the same time at full throttle?
Nobby the Bastard
Harley Gaydar
PostPosted: 19:11 - 16 Feb 2022    Post subject: Reply with quote
Basically, there is no situation where it could work fine when cold,shit when hot and have so much fuel going into the exhaust that it runs out.
Kawasaki Jimbo
PostPosted: 19:30 - 16 Feb 2022    Post subject: Reply with quote
Custard test.
WD Forte
PostPosted: 21:00 - 16 Feb 2022    Post subject: Reply with quote
Don't guess, test.
Plug/s examination for starters
Whip em out, examine, note/ photograph
Clean, refit, run until it goes wonky then repeat
This will give you an idea of the mixture
If one plug is sooty brown and dry
and on side is sooty black and wet ( or just wet)
it will at least give you pointers.
bikers smell of wee
Glades
PostPosted: 21:09 - 16 Feb 2022    Post subject: Reply with quote
Sorry to ruin your dreams then
Nobby the Bastard
Harley Gaydar
PostPosted: 21:14 - 16 Feb 2022    Post subject: Reply with quote
What do you think would happen to petrol dripping into a hot exhaust?
jeffyjeff
PostPosted: 04:48 - 17 Feb 2022    Post subject: Reply with quote
How about maybe a broken choke? You know, the one that's broken af?
Glades
PostPosted: 17:10 - 17 Feb 2022    Post subject: Reply with quote
You seem to have missed the part where its been broken for not only the past year but a long time before that without issue.
The last post was made 3 years, 318 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.32 - MySQL Queries: 14 - Page Size: 130.16 Kb
