125CC doesn't have power!
Rooz12
PostPosted: 16:50 - 29 Dec 2022    Post subject: 125CC doesn't have power! Reply with quote
Hello,
I have a JINLUN 125cc JL 125-11 which is a project.
I managed to get this started a few times so I know it starts and runs. This was a week ago so not long ago.
But today I tired to start it again and it looks like I get no power!! I have no horn either!
The bike doesn't have a kickstart... It only has a electric start/button.
When I push the start button, I get nothing, no sound from the starter coil either!
So, I checked the fuse and it was fine. it only has 1 main fuse I think.
Next I checked the battery and when I plugged it into my battery charger, the charger shows its almost full (1 bar less than full battery).
I tested some of the wirings using my needle voltage tester and they all seem to have some power running through them!
I'm actually confused as to whats causing this and why this has happened!
During my research online, I came across some information about the bike not being neutral hence not having any power so I made sure the bike is on neutral as well. I can spin the front sprocket forward and backward with my finger.
Can someone please shed a light on this?
Thanks in advance.
jaffa90
PostPosted: 18:17 - 29 Dec 2022    Post subject: Reply with quote
What is the battery voltage reading (dc) and then using the negative / earth probe on the bike frame when fitted?
In other words is the battery connected to the bike?
PostPosted: 19:46 - 29 Dec 2022    Post subject: Reply with quote
There are usually cut out switches on the clutch and sidestand. Are they working correctly?
Triumph Sprint ST 1050
Rooz12
PostPosted: 23:17 - 29 Dec 2022    Post subject: Reply with quote
I havent tested this but will do tomorrow and will update here.
Rooz12
PostPosted: 23:20 - 29 Dec 2022    Post subject: Reply with quote
I have a kill switch on the side stand but the bike is on the middle stand.
The issue is that my horn doesnt work either and this was working regardless of kill switch!
It looks like nothing electrical works now but I havent changed anything since the last time I started it which was last week...
PostPosted: 00:49 - 30 Dec 2022    Post subject: Reply with quote
WTFs a 'needle voltage tester' ?
is that a spikey probe with a light type thing?
jaffa90
PostPosted: 01:36 - 30 Dec 2022    Post subject: Reply with quote
Maybe,???
Rooz12
PostPosted: 04:00 - 30 Dec 2022    Post subject: Reply with quote
Hahahaha
Yeah brother... that's the one... it's a sharp needle that you push into the wires and the light goes red if its live.
This one to be exact:
https://www.ebay.co.uk/itm/311989643737?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=mNxrbkO5Sx6&sssrc=2349624&ssuid=qBQFqjchSoO&var=&widget_ver=artemis&media=COPY
It's basically a circuit tester.
PostPosted: 10:37 - 30 Dec 2022    Post subject: Re: 125CC doesn't have power! Reply with quote
This seems to be the most serious aspect.. I'm surpised Nobby hasn't already proposed a remedy.
PostPosted: 11:15 - 30 Dec 2022    Post subject: Re: 125CC doesn't have power! Reply with quote
TBH I've only just seen it. What about lights? Does anything work?
Beginning to suspect the ignition switch.
PostPosted: 11:47 - 30 Dec 2022    Post subject: Reply with quote
I'll make the assumption that the wiring is just like, with all due respect, any other piece of Chinese shite.
The horn wiring order will be something like:
Battery (red wire) Ignition (black wire) Horn Switch (yellow wire) Horn (green wire) frame/battery negative
Your colours may be different but the above is generally what the Chinese use. I would start tracing out from the battery and along the chain and see where the power stops.
Kawasaki Jimbo
PostPosted: 12:58 - 30 Dec 2022    Post subject: Reply with quote
Horn and clutch switch being on the same side I’d wonder whether there is a shared but broken earth on the left handlebar.
Any change when you have the stand up and the clutch pulled in?
Rooz12
PostPosted: 15:27 - 30 Dec 2022    Post subject: Reply with quote
Thanks everyone. I managed to start it again. The issue was as stupid as it sounds. There was a black earth wire that was pulled out of the ignition somehow.
But I still dont have a horn!
I will need to investigate this further and find out why the horn stopped working now.
I wonder if this is because of another wire getting pulled out somehow!!!
PostPosted: 15:48 - 30 Dec 2022    Post subject: Reply with quote
I see
Not utterly useless but of very limited use.
Getting a voltage is not as useful as knowing what voltage
You could have bought a basic but respectable and very useful
meter for that.
This one for instance is half the price and way more than twice as useful for bike electrical work.
https://www.ebay.co.uk/itm/314265055493?
The last post was made 2 years, 134 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 3.99 - MySQL Queries: 13 - Page Size: 82.66 Kb
