| Mrflashy |
 Mrflashy L Plate Warrior
| Nobby the Bastard |
| stinkwheel |
 Posted: 19:25 - 10 Jun 2023 Post subject: |
Obvious and easy one would be that the nut has come undone and the sprocket is no longer properly engaged on the splines.
Compex and annoying one would be that either the mainshaft has snapped, a gear has let go or the bearing has walked out of the crankcase ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Nobby the Bastard |
| Mrflashy |
| Nobby the Bastard |
| stinkwheel |
 Posted: 20:33 - 10 Jun 2023 Post subject: |
If the nut is unscrewing itself, the way they used to prevent this (other than the obvious properly tightening/thread-lock etc) was to use a grub screw into the sprocket.
You get an M6 cheese head screw, these usually have a 10mm head diameter. Measure 5mm away from one of the flats of the main sprocket nut on the sprocket and drill and tap an M6 hole in the sprocket (some sprockets actually already have these).
Once you've tightened the main nut down, take it a little either way until a flat is adjacent to the screw hole and screw the cheese-head in. Use a good spring washer and loctite, I'd suggest a nord-lok washer. Then you have a good mechanical lock preventing it happening again and because it's offset somewhat, is less prone to precessing out.
Old pre-unit brit bikes use this as it's very difficult to do up the mainshaft nut particularly tight for a variety of reasons. They don't come undone, even if they are barely past finger tight ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Pete. |
 Pete. Super Spammer
 Posted: 20:43 - 10 Jun 2023 Post subject: |
Broken output shaft is common on bike-engined carsbecause the larger mass of the car means that the engine is at peak torque for longer (because the larger mass needs more time to accellerate through peak torque). Many people fit an outboard support bearing and in fact they make a stronger shaft for the Hayabusa engine for this very reason and strengthened case bolts too as they sometimes burst the cases.
Only way you're going to find out is have it apart. ____________________ a.k.a 'Geri'
| Mrflashy |
| Mrflashy |
| Nobby the Bastard |
| stinkwheel |
| Nobby the Bastard |
| WD Forte |
 WD Forte World Chat Champion
| Mrflashy |
| Pete. |
 Pete. Super Spammer
 Posted: 18:09 - 11 Jun 2023 Post subject: |
That's a result for you. Bike engined cars often get geared down with a smaller sprocket because usually 1st gear is too tall for the job. The downside is that you lose some speed at the top end. ____________________ a.k.a 'Geri'
| stinkwheel |
 Posted: 18:10 - 11 Jun 2023 Post subject: |
Wow, that's a dinky sprocket. What is it 13 tooth? Grub screw trick wont work on that.
If you can't get the tabbed washer under it, it's likely to happen again.
If there's enough thread, you could try a nordlok washer, those things are remarkable. Better than anything else that isn't a physical mechanical lock like your tabbed washer or lockwire. Including nylok, loctite and double nuts.
My other thought would be milling/surface grinding the outside face of the sprocket so you can get the splined washer on and the nut on properly. Only reason I can think of to use a fatter sprocket would be to get the chain line and that's determined by the inside face. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Pete. |
 Pete. Super Spammer
 Posted: 18:54 - 11 Jun 2023 Post subject: |
High strength threadlock on the nut threads. When you want it off, cook it with a blow torch and it'll come loose easy as anything. ____________________ a.k.a 'Geri'
| Mrflashy |
| MCN |
 MCN Super Spammer
The last post was made 3 years, 28 days ago. Instead of replying here, would creating a new thread be more useful? |
