Brake bleeding
Lewissealey
PostPosted: 18:15 - 27 Dec 2023    Post subject: Brake bleeding Reply with quote
Trying to bleed the brake on a lexmoto 125 but I’ve tried to bleed them pumping the brake the reverse method and vacuum to no luck it’s a brand new brake system so there shouldn’t be any leaks
And advice
PostPosted: 18:18 - 27 Dec 2023    Post subject: Reply with quote
There's often a big air bubble just at the top banjo bolt. Try bleeding the banjo like you would the bleed nipple with a rag sat under it to catch the drips. Once it's stopped farting air out there, move further down.
stevo123
PostPosted: 20:29 - 27 Dec 2023    Post subject: Reply with quote
I've had decent results using gravity and just tying the brake lever to the brake applied position with some tape an dleaving it overnight - the air travels upwards and it self bleeds. Gets you pretty close. Hope it helps.
Honda XL125-Yammy DTR125-Honda NSR125-Yammy TZR 250-Aprilia RS125-KTM RC 125-
KTM RC390-Kawasaki Ninja 636-KTM Duke 390
PostPosted: 14:13 - 28 Dec 2023    Post subject: Reply with quote
In my experience an old, dirty brake system (with regards to the internals) is more likely to want to hang onto air bubbles. Stripping the system apart and using a can of proper brake cleaner wouldn't hurt for starters. Worst case scenario you might need a master cylinder rebuild kit.
When reassembling check how good your banjo washers are and make sure everything's tight. I spent 20 mins one time trying to bleed a system with a slightly loose banjo bolt and air was sneaking in.
Bleeding the master then adding the pipe and bleeding then adding the caliper and bleeding will obviously be messy but at least you know fluid is flowing through each stage.
to v or not to v
PostPosted: 19:50 - 28 Dec 2023    Post subject: Reply with quote
use one of these, makes bleeding a doddle-
https://www.ebay.co.uk/itm/404164972818?
Moto Guzzi V7.
The last post was made 2 years, 57 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.15 - MySQL Queries: 13 - Page Size: 43.71 Kb
