Battery drain issue
PostPosted: 12:09 - 10 Mar 2024    Post subject: Battery drain issue Reply with quote
So, bought a battery because the old one died, stranding me in Bristol a few weeks ago.
On arrival, it couldn't start the bike, it was saying 12.3V. Charged it up and the bike started with no issues.
Went to use the bike a couple of days later and it wouldn't start again, battery only showing 12.5V. I persevered but it consistantly would not work, after being left overnight, but if charged that day was fine.
Supplier sent another, that was dead on arrival at 12.1V.
They both went back and a new one sent to me (different make) which was on 12.6V on arrival, was unable to start the bike and after 20 seconds of cranking was at 12.3V.
Started the bike once charged but after being left overnight can't start the bike, same before and after voltages same length of cranking.
Draw by the bike for clock etc is 20mA but the battery wasn't even connected when left overnight.
I'm a little loathe to think its another duff battery but I can't find anything wrong with the bike. It starts on the button with a freshly charged battery.
Any ideas?
Triumph Sprint ST 1050
PostPosted: 13:42 - 10 Mar 2024    Post subject: Reply with quote
Two properties of a battery one would be interested in: can it supply ~12V over a long period at a low current drain (normal running) and can it supply a shed-load of power for a few seconds (cranking current.)
So far, so obvious. I would suggest either the batteries are not chucking out the power they should or for some reason the bike is asking for more power than it should. That a completely topped-off battery can start the bike but an even slightly discharged battery cannot points to the bike demanding much more power than it should to crank over, I would say.
Before I changed the (probably the 2016 OEM) battery on my XSR I'd occasionally have trouble starting it, e.g. left for >1 week. In the borderline cases where you could hear it struggling but it did manage to start the battery voltage was between 11~12V which is much worse than what you're encountering.
I'd be thinking about the starter motor, starter solenoid and starter switch.
PostPosted: 13:59 - 10 Mar 2024    Post subject: Reply with quote
So it'll crank the bike over for 20 seconds+? Then it wont crank it any more or it'll crank it but not fire up?
PostPosted: 14:00 - 10 Mar 2024    Post subject: Reply with quote
I've considered that but I can't actually test cranking amps because my meter can only test up to 10amps, which my bike draws from the batter just by turning on the ingnition because thats what dipped beam would draw.
As a 10Ah battery is going from 12.6 to 12.3V (or fully charged to the point where it can't crank the engine over) in 20 seconds it's either pulling fucking rediculous amps or the battery is fucked. If ity were pulling 30 it would blow the main fuse so I don't think it is that.
Also bear in mind that it should not have lost even a tiny amount of power overnight simply because it wasn't even connected to anything.
PostPosted: 14:06 - 10 Mar 2024    Post subject: Reply with quote
Won't crank over at all. For the 20 seconds it's slower than normal and it clearly isn't up to the job of actually running it all at the same time to get started.
Fizzer Thou
PostPosted: 14:08 - 10 Mar 2024    Post subject: Reply with quote
Having dealt with batteries of all shapes and sizes for many years,on lifeboats as well as on vehicles,they should always be conditioned by charging them for a pre-determined length of time.No battery straight out of the box is going to give its best.This is particularly true of lead/acid batteries.
What type is the battery that is your preferance?
Did you buy them from tayna.co.uk?
Always have a 'Plan B'
PostPosted: 14:16 - 10 Mar 2024    Post subject: Reply with quote
It's from Wemoto and there is a sticker on the box saying it was filled and charged by them on Thursday.
PostPosted: 14:43 - 10 Mar 2024    Post subject: Reply with quote
It's always hard to diagnose anything at a distance but
is it possible you have had run of bad batteries?
If you have perhaps the supplier bought a bad batch of chinese knock offs?
this is just a vague possibilty of course, I've never heard of this actually happening
but who knows?
12.6v dropping to 12.3v after 20 seconds of cranking sounds like pretty normal behaviour
Voltage only gives an indication of health, we need to know how much current a battery
is capable of providing on demand (CCA)
CCA should be as per spec when new but will drop over time in any battery.
I bought a Topdon battery tester recently which has proved very useful in determining the state of health (soh) of my bike and car batteries.
It gives them various tests in and out of a vehicle and even checks the charge
voltage and ripple voltage.
I'd want to check the charge voltage (circa 14V) and current to the battery is being
properly charged when running.
If your new battery checks out as healthy with CCA as per spec or near as
and is being well charged then I may want to see the innards of the starter motor
A high build up of carbon dust could leech off some current when starting
and I once had one where the oil seal had failed and the starter was full of
an engine oil and carbon dust slurry!
Surprisingly, it worked like this but was never very lively at throwing a cold lump over, a strip down, clean up and new seal and brushes got it working like a good un again.
All just guesses of course, but I've had many's a battery at 12.6V ish that started
a bike OK
As always of course, check all related leads connections and grounding.
As it happen I've just been checking the car over as I'm off up norf next week and I took some pics of the gadgets I did do buy, will start a fred in workshop.
Fizzer Thou
PostPosted: 14:47 - 10 Mar 2024    Post subject: Reply with quote
So it is a lead/acid type then....
They come from the factory 'dry charged' but still need to have at least 20 hours charge with a constant rate of about 1 amp for motorbike use.
Car battery chargers are useable but charge at far too high a rate and can buckle the plates.Some chargers have the option of car or motorbike use but the one that I have I fit a one ohm 5 watt wire wound reisitor in series to reduce the current flow.This then reduces as the internal resistance of the battery increases as it charges.
Optimate type trickle chargers are no use as they vary the charging rate and cannot supply a constant rate.I tested this function a while ago with an oscilloscope and a multimeter when checking the difference between one of my older Optimates and a newer version.
P.
PostPosted: 15:21 - 10 Mar 2024    Post subject: Reply with quote
My blackbird was similar but ended up having a new starter fitted post my sale and that sorted it. I just had a 24v starter circuit to skip that issue because I didn't want to strip it down and replace the starter.
PostPosted: 15:51 - 10 Mar 2024    Post subject: Reply with quote
Instructions that came with the battery say it has to be charged if it drops below 12.4v.
It's getting to 12.3V in 20 seconds...
It's also a strange coincidence that a problem like this began at exactly the same time as the original battery died (it literally won''t retain more than 12.2V and the charging trick doesn't work on it.)
Kawasaki Jimbo
PostPosted: 15:56 - 10 Mar 2024    Post subject: Reply with quote
Another vote for always charging a new battery before first use.
Was it flat, or was it cranking but not firing like the newer batteries?
I reckon you’ve comprehensively demonstrated that the battery itself isn’t the real problem.
When you’ve been able to start the bike is it charging?
I’d guess that something (ignition coils?) are under-par so once you’ve taken the top 5% off the battery’s capability there’s not enough to effectively power the starter, fuel pump and ignition at the same time. Not the battery’s fault.
PostPosted: 16:04 - 10 Mar 2024    Post subject: Reply with quote
As I just said, the old battery is comprehensively dead, only retains 12.2V despite charging and cannot start the bike even if after immediately charged.
PostPosted: 16:19 - 10 Mar 2024    Post subject: Reply with quote
Ignore bit about the main fuse, the fuse doesn't cover the starter motor. It could well be drawing more than 30 amps.
PostPosted: 17:46 - 10 Mar 2024    Post subject: Reply with quote
So, my options are it's either the battery wasn't sufficiently charged by Wemoto (and bear in mind they sell fuckloads of them all the time so should know what they are doing) or the starter motor is dying.
PostPosted: 19:30 - 10 Mar 2024    Post subject: Reply with quote
Maintenance Free (vented AGM) work from the box.
No need to pre-charge.
Acid-Charged batteries like a charge but not necessarily if they are used to start an engine that has a working alternator and it gets a decent run time at charge speeds.
I suspect the starter motor has a short.
Robby
Dirty Old Man
PostPosted: 20:36 - 10 Mar 2024    Post subject: Reply with quote
Did you charge the battery overnight before using it? If not, do that before trying to diagnose anything.
A healthy, charged battery should sit at around 13.5 volts. 12.6 is almost flat, so it will drop to 12.3 pretty quickly.
PostPosted: 20:54 - 10 Mar 2024    Post subject: Reply with quote
Charged for 4 hour earlier (finished charging at 3 this afternoon), sitting at 12.87V at present. It's lost about 00.05V since the initial drop after taking it off the charger.
The instructions that came with the battery from the manufacturer state charge for 5 hours a 1 Amp.
Everything I can find on the internet says 12.6V is normal.
jeffyjeff
PostPosted: 23:14 - 10 Mar 2024    Post subject: Reply with quote
Have you considered that you may have resistance in the starter circuit? You can conduct a voltage drop tests to check 1) the starter power feed and 2) starter ground. Voltage drop should be no more than 0.5 volt during cranking. Worth a try just to be sure; I would not condemn the starter before doing a voltage drop test on the vehicle. You might have a problem in a cable, connection, or starter relay. If you are not sure of the battery, you can have it load tested at an auto electric shop or auto parts store. Just a suggestion.
PostPosted: 12:37 - 11 Mar 2024    Post subject: Reply with quote
Update:
Started fine today after leaving it overnight.
Not assuming it isn't the starter though, will leave it a couple of days and see if it still starts.
PostPosted: 12:44 - 11 Mar 2024    Post subject: Reply with quote
This is only for first charge right? Otherwise every battery would get 'buckled plates' in use since most alternators output more than any carcharger. Eg my XJ can output upto 17A and my car charger only 6A maximum.
Fizzer Thou
PostPosted: 13:55 - 11 Mar 2024    Post subject: Reply with quote
The leaflets that I have received with new lead/acid batteries have always said to give them an initial constant rate charge and the lifespan has always been years,not months.
The Yuasa versions for my Exup and the R1 have been delivered dry charged with the seperate acid packs and using the in-line wire wound resistor has always benefitted the long lifespan after charging for the required time.
Once on the vehicle it would be the regulator which would monitor the output voltage for the benefit of keeping the battery up to the optimum.
Years ago I did have a problem on a car with a voltage reulator that was allowing the output of 17vdc to cause the battery to overcharge and pop off the plugs,spraying acid all over the area under the bonnet.The battery itself suffered as a result.
PostPosted: 15:00 - 11 Mar 2024    Post subject: Reply with quote
They aren't allowed to ship them with acid packs to proles any more in the UK in case we throw it in one anothers faces. So they now ship lead acid batteries pre-filled in a big plastic bag and hope the postman keeps the arrow facing up... Because that's obviously a lot safer and because nobody would think of taking the plugs out and emptying the acid back out of it again if they wanted to do a bit of impromptu acid face throwing.
PostPosted: 16:39 - 11 Mar 2024    Post subject: Reply with quote
Yep that'll do it, also excessive sulphating, often due to to undercharging I read . I still doubt though that a normal working battery charger operating at 14.5V will damage a battery even if the current rate exceeds the 1A guide. In service they can pull more than that for sure.
PostPosted: 17:50 - 11 Mar 2024    Post subject: Reply with quote
Battery is still showing 12.8V.
The last post was made 1 year, 326 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 132.99 Kb
