mt10 rear brake
dave001 This post is not being displayed because the poster is banned. Unhide this post / all posts.
Easy-X
PostPosted: 16:52 - 28 Jan 2023    Post subject: Reply with quote
There's not really much to brakes, small piston pumps fluid to another piston. Assuming you don't have some linkage problem (should be pretty obvious) then either the master cylinder is pumping fluid but it's going elsewhere, maybe a leak or a ballooning brake pipe, or it's not pumping fluid in which case it needs a rebuild or replacement.
Easy-X
PostPosted: 00:55 - 29 Jan 2023    Post subject: Reply with quote
Intermittent problem... maybe some grit in the system?
Copycat73
PostPosted: 18:32 - 29 Jan 2023    Post subject: Reply with quote
remove the cover of the fluid reservoir .. whilst lookin at the fluid surface .. fully depress the back brake ... see if any back pressure ..
caveat emptor
Fizzer Thou
PostPosted: 19:41 - 29 Jan 2023    Post subject: Reply with quote
Seeing as the MT10 has ABS I would suppose that any drag has caused the brake fluid to overheat and cause fade.Once cooled down and pressure has resumed,this is a typical example.
If the fluid has never been replaced it would be best to bleed the system through with fresh fluid from an unopened bottle.Bleed the front calipers as well.One 500ml bottle of DoT4 will be enough to do the job and can be bought from the likes of £5.
Always have a 'Plan B'
mtriderrob
PostPosted: 22:09 - 30 Jan 2023    Post subject: Rear brakes Reply with quote
If you do change the brake fluid by bleeding it through, you will probably need to activate your ABS once done and then bleed again otherwise you will still have old fluid in the ABS pump which will just contaminate your new fluid again.
There are 2 ways of activating the ABS on the super ten, one method is to use a jumper wire across a couple of terminals on a plug under the seat followed by operating first the front brake and then the rear with the ignition turned on.That’s the recommended Yamaha procedure for my 1200 Super Teneré so I wouldn’t have thought the MT10 would be much different.
The 2nd more fun way to do it is by riding on a loose/slippery surface and trying to lock the wheels, please only use this method if your riding skills allow you to do so, easy to do on a Super Ten, probably less so on an MT10!
Current bikes; MT01, XTZ1200 & 1981 XV750 which I've had from new, TRS300RR
Scorpa factory 300-still mine despite the fact that some thieving scumbag bastard currently has possession of it
Nobby the Bastard
Harley Gaydar
PostPosted: 16:45 - 01 Feb 2023    Post subject: Reply with quote
Any chance you two can find a language you both understand rather than the pair of you struggling with English when it's clearly not your first language?
Triumph Sprint ST 1050
There is a gap of 2 years, 238 days between these two posts...
viciu080
PostPosted: 18:10 - 27 Sep 2025    Post subject: Reply with quote
I've been having an issue with brakes on my 2017 FZ10. At some point ABS started to kick in even on light braking. There is noABS gauge on or faulty code. I replaced pretty much everything besides brake lines and bled it hundreds of times. After I disconnected ABS pump the wheel would still lock on light braking. I'm really running out of ideas what to do next
Copycat73
PostPosted: 09:12 - 28 Sep 2025    Post subject: Reply with quote
ABS. sensor ?
caveat emptor
The last post was made 1 year, 1 day ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.88 - MySQL Queries: 14 - Page Size: 84.87 Kb
