Fixing my leaking boots
Freddyfruitba...
PostPosted: 18:02 - 27 May 2024    Post subject: Fixing my leaking boots Reply with quote
My boots (TCX Classic/Explorer EVO Goretex) have started leaking, presumably due to the soles beginning to come away from the uppers - see photo. Other than that they're in great nick so I'm reluctant to bin them if I can help it. Anybody have any good suggestions for resealing? I did try using a builder's silicone sealant, having tried to clean out the gap first with meths, but it didn't hold at all.
Any better ideas? Other than to stop being a cheapskate?
https://i.postimg.cc/C14tzyjq/boot.jpg
struan80
PostPosted: 18:07 - 27 May 2024    Post subject: Reply with quote
Without any scientific reason I would use superglue. Just make sure you're feet are out of the boots when applying. Laughing
Cheapskate
PostPosted: 18:38 - 27 May 2024    Post subject: Reply with quote
Superglue and water don't play nicely.
Triumph Sprint ST 1050
doggone
PostPosted: 19:02 - 27 May 2024    Post subject: Reply with quote
You can get leather glue search shoe glue it needs to be flexible which superglue isn't.
I can't see it holding long but bike boots are probably easier to stick than hiking boots or mucky work boots.
Minty
PostPosted: 19:16 - 27 May 2024    Post subject: Reply with quote
If they're worth wearing, they're worth repairing. Take them to a cobbler, they will have suitable glue as well as a press whilst it adheres.
My fingers smell of your mum.
PostPosted: 19:19 - 27 May 2024    Post subject: Reply with quote
A non-expanding polyurethane adhesive like gorilla clear (not normal gorilla, it foams up and will push it apart again). Find a way to hold the bit you are gluing down as firmly as possible while it sets up. A clamp and some bits of wood wouldn't be overkill but some tape at a bare minimum.
Or sealskinz socks.
Kawasaki Jimbo
PostPosted: 20:52 - 27 May 2024    Post subject: Reply with quote
Safety gear at end of life. Replace.
PostPosted: 06:29 - 28 May 2024    Post subject: Reply with quote
What stinkwheel said or alternatively there are various shoe glue or boot fix glue products that are non expanding adhesives which are just the job for fixing your soles.
PostPosted: 07:29 - 28 May 2024    Post subject: Reply with quote
Jesus is all one needs to save one's sole.
Take Jesus unto one's heart. Sayeth the Lord.
PostPosted: 11:43 - 28 May 2024    Post subject: Reply with quote
As a pathelogical tight-wad I have successfully fixed new soles to trainers with good uppers (my favourite Gola Harrier high -tops) and prior filled to worn heel with this stuff..
https://www.toolstation.com/stixall-adhesive-sealant/p60981
It's the tits cos flexible and you get loads of it. The downside its that it takes about 24Hrs to properly go off - depending on thickness of application.
Freddyfruitba...
PostPosted: 13:12 - 28 May 2024    Post subject: Reply with quote
Thanks guys - I'm going to give leather glue a try. We'll see!
PostPosted: 18:07 - 28 May 2024    Post subject: Reply with quote
Silicunt sticks like shite to a blanket normally.
Coz you have already fapphed with silicunt it may have polluted the surfaces to be bonded now.
Any adhesive needs some irregularities in the surfaces as a key.
Abrasion before lathering the glue on might help.
Freddyfruitba...
PostPosted: 18:51 - 28 May 2024    Post subject: Reply with quote
Yeah thanks - was going to do that
PostPosted: 19:16 - 28 May 2024    Post subject: Reply with quote
Take them to Timpsons.
Islander
PostPosted: 19:19 - 28 May 2024    Post subject: Reply with quote
Stormsure repair adhesive. It's intended for this sort of thing and works brilliantly. You'll have to improvise a method of clamping it closed and holding it but it won't leak any more if you do it correctly.
You can even build up worn heels with the stuff.
PostPosted: 20:15 - 28 May 2024    Post subject: Reply with quote
Cheap non-foaming polyurethane adhesive.
Expensive non-foaming polyurethane adhesive.
PostPosted: 09:02 - 29 May 2024    Post subject: Reply with quote
By a factor of more than 20x I note...
Islander
PostPosted: 18:57 - 02 Jun 2024    Post subject: Reply with quote
Fair comment. I was recommended the Stormsure by a friend and it really is good stuff. I've even rebuilt heels on pair of my OH's favourite boots. I'll have to try the cheaper stuff to see f it works as well as the Stormsure (no reason it shouldn't).
The last post was made 1 year, 251 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.48 - MySQL Queries: 13 - Page Size: 101.04 Kb
