2006 Kawasaki ER-6f voltage problems
E-troop
PostPosted: 20:44 - 24 Jun 2024    Post subject: 2006 Kawasaki ER-6f voltage problems Reply with quote
Not sure if this is the right place to ask, sorry if it isn't, but I'm having an issue with my bike.
The headlights blew while riding, but after replacing them the bulbs immediately popped.
After a bit of research I checked the voltage with the bike at about 5krpm, and the voltage across the battery was showing over 24v.
The regulator had a burned/corroded pin
So I replaced the regulator (with a cheap non-kawasaki one tbh) and it worked for a week or so.
Now the bulbs are blowing again, and the voltage is spiking again
After more research, I found and cleaned the ground. Still getting voltage spikes though
My questions are:
Have I fried the new regulator?
Is there anything other than the ground connection that could have fried the new regulator?
Is there anything else I should check before wasting money on a new regulator?
Sorry for the long winded post
PostPosted: 21:48 - 24 Jun 2024    Post subject: Reply with quote
It could have cooked the alternator stator in one of a variety of failure modes. I'd do a static test at a minimum.
Three wires run from the alternator to the reg/rec. With the engine off, measure resistance between each pair of wires, each pair should give more or less the same, quite low (probably in the single digit ohm range) reading. Now check resistance between each wire and ground, it should be an open circuit.
Anything different to that and you have a problem.
Robby
Dirty Old Man
PostPosted: 21:29 - 25 Jun 2024    Post subject: Reply with quote
Cheap reg/recs tend to be universally shite as well.
PostPosted: 22:02 - 25 Jun 2024    Post subject: Reply with quote
Yep, some of the cheap ebay ones are not fit for purpose.
I dug one out of the potting compound that had lasted a week on a VFR
and wasn't the least bit impressed at the quality.
The last post was made 1 year, 69 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 39.45 Kb
