Honda CG 125 Indicator Relay Issue
rego21
PostPosted: 20:56 - 20 Jul 2024    Post subject: Honda CG 125 Indicator Relay Issue Reply with quote
Hi all,
I’m "rebuilding" a Honda CG 125 from 1992. When the motorcycle is stall, I can see that the indicators are flashing as expected. However, when I kickstart it the indicator stay stall (no flashing at all) and the relay seems to be gone because when I turn off the motorcycle again and test the indicators they stay stall. Anyone have any idea what the issue could be? Thanks!
PostPosted: 13:13 - 21 Jul 2024    Post subject: Reply with quote
Old electromechanical indicator relays are sensitive to the load on the circuit. If the bulbs are the incorrect wattage, it will not flash correctly (or will flash too fast). If the voltage supply is incorrect, you can have similar issues.
I'd replace it with an electronic flasher relay anyway which will flash at the same speed regardless of what else is going on. It may be showing you have a charging issue or a dead/dying battery which would also be worth testing.
rego21
PostPosted: 13:46 - 21 Jul 2024    Post subject: Reply with quote
Thanks @stinkwheel for the reply. I replaced the relay with a electronic flasher from Aliexpress - a 2 pin one with support for 12v. Like I mentioned it works ok when I don’t kickstarter the motorcycle, just turn the ignition key on and test the indicators everything ok. I believe probably there is a current spike when I kickstarter and the relay burns ( I checked the voltage and seems ok it stays at 7-8v). Could be a ground issue?
PostPosted: 14:08 - 21 Jul 2024    Post subject: Reply with quote
An earth problem is certainly something to investigate. I presume it's a 6v electrical system?
It might also be that the rectifier has failed and is putting out AC instead of DC or an excessive voltage. Is your 7-8v across the battery with the engine running?
EDIT: I think your bike is 12v so where is the 7-8V reading coming from? It's not right.
rego21
PostPosted: 08:34 - 22 Jul 2024    Post subject: Reply with quote
Thanks again for the reply, today I will make some more measures to give more inputs and make sure that my readings are correct. Will get back to you ASAP
rego21
PostPosted: 13:29 - 22 Jul 2024    Post subject: Reply with quote
Hi again!
So to give a little bit more context:
Im not using a battery on this Honda CG 125, it can run from the kickstarter only however the ligths are not going to be stable in neutral. Measured the voltage at the battery plug and what Im seeing is 7-8 volts.
Not much related, but noticed that a recent spark plug i changed (like 1 month ago) its like this. Its dry because I could remove the "black" from it using a toothbrush :
https://i.ibb.co/ng9f9wN/spark.jpg
Can this be related with electricity problems ? (don believe so)
PostPosted: 14:56 - 22 Jul 2024    Post subject: Reply with quote
You aren't going to get stable and sufficient DC out of that charging system without a battery. It'll run the lights fine because they are on direct AC and as you correctly pointed out, the ignition self-excites.
You have no chance of it running the flashers/brake light/horn direct without a battery, a capacitor or a special reg/rec. Even then, they don't really generate enough power directly to light up the incandescants, they rely on the battery storing power and it being used intermittantly.
TL;DR. You need a battery.
rego21
PostPosted: 15:04 - 22 Jul 2024    Post subject: Reply with quote
Thanks again for the reply!
The thing is, with the kickstarter only I can see that the brake light its working when I hit the brake handle, the horn also works and the indicators also work. The only issue is the one I mentioned in the beginning of the post, the relay seems to burn when I kickstart the motrocycle, but the indicators still work however they are stall (since the relay is gone)
jeffyjeff
PostPosted: 16:43 - 22 Jul 2024    Post subject: Reply with quote
rego21 wrote:
.... The only issue is the one I mentioned in the beginning of the post, the relay seems to burn when I kickstart the motrocycle, but the indicators still work however they are stall (since the relay is gone)
If you are happy with the way your indicators are operating, don't do anything and they will keep operating as they do. If you are unhappy with the way they are operating, and you seek technical advice from someone with more knowledge and experience than you have, maybe you should try following their suggestions before dismissing them outright. There is nothing random about the diagnosis that Stinkwheel made based on the information you gave him. He clearly knows motorcycle electrical systems and he gave you sound advice. You might give him the benefit of the doubt.
Consider that the relay and/or flasher might require more current to operate than is available, and that the battery stabilizes charging system output and provides the 'boost' necessary for the blinkerlights to flash.
rego21
PostPosted: 16:48 - 22 Jul 2024    Post subject: Reply with quote
Sorry if I was misunderstood, I never meant to discard Stinkwheel opinion. My goal with the last reply was just to clarify what I'm seeing on my side.
jeffyjeff
PostPosted: 16:51 - 22 Jul 2024    Post subject: Reply with quote
I beg your pardon for jumping to the wrong conclusion.
PostPosted: 18:39 - 22 Jul 2024    Post subject: Reply with quote
I think the 1992 will be a Brazilian model which has two coils on the stator.
One of them provides power for the spark, this is a totally seperate system and has nothing to do with the lighting or accessories. So a running engine tells you nothing about the rest of the electrical system.
The other coil is split in half. When the lights are off, the two halves feed into a basic regulator rectifier which gives a very dirty 12V DC output to the battery. When the lights are on, one half of the coil feeds AC power directly to the lights. The other half feeds even dirtier and less power to the battery. Almost certainly not enough power to light up the brake light and indicators together.
It's a cheap and nasty charging system designed to store enough power in the battery to make the flashers and tail light work when they are needed. It's also basic and reliable if it's used as intended and the seperate ignition coil means it's unlikely to leave you stranded at the side of the road with no spark, even if all the rest of the electrics fail.
I've been trying to make a similar but slightly more refined system work without a battery on my current project bike, I've been using capacitors to do the job of the battery. I haven't been able to get it to work reliably and it's cooked two stators so far. Attempt three is going to be me giving up on the idea and fitting a battery.
I also have two dead flasher relays.
rego21
PostPosted: 20:53 - 22 Jul 2024    Post subject: Reply with quote
You are absolutely right, its a 1992 Honda Brazilian model!
Wow dindt know about that, thanks for the info! What doesn't make much sense on my case, its why the indicators and brake light works without a battery. I believe they should need one to operate, but from the kickstarter they work...
My idea was and still is to use a capacitor instead of the battery, however since I couldn`t go for a ride yet I wasn't able to test the solution properly... What issue have you found so far with the capacitor solution ?
Thanks again!
PostPosted: 22:18 - 22 Jul 2024    Post subject: Reply with quote
I was still getting a fluctuating power supply, despite using several different combinations of capacitor to try to smooth it out. Probably less of an issue with incandescant bulbs but I'm using LEDs on this build and it caused an unacceptable amount of flicker.
The battery also acts as a power sink. Without it, the excess is just dumped to earth by the regulator, this was leading to the stator overheating, then eventually shorting when the insulation broke down and burning out.
I have an oscilloscope now which would probably help with stabilising the output so I would be able to dial out the flicker with a bit of prototyping using different value capacitors but it wont help with the overheating. I'm just going to use a small battery, it's simple and will just work.
Mine is wired for DC only. With hindsight, if I was doing it all again, I'd use an innova 125 reg/rec and copy their system which uses a single coil and passes half the waveform for positive earth, voltage regulated direct lighting and the other half for negative earth charging. It would probably still need a battery to get a clean DC output though. It's a clever system and effectively gets you double the useable power from the same size coil. I'm not going to post a how-to about it though, if you can look at the wiring diagram and understand what's going on, it's something you could think about.
rego21
PostPosted: 22:27 - 23 Jul 2024    Post subject: Reply with quote
Thanks for the great input! Having this feedback I believe I will abandon the capacitor idea and just use a battery instead.
rego21
PostPosted: 07:43 - 24 Jul 2024    Post subject: Reply with quote
Hi again,
I will also try to revive the initial topic discussion.
So I tested the stator (with motorcycle off) and seems to be ok:
Yellow to White resistance is 0.8
White to Ground is 0.8
Yellow is shorted to ground, which I think its normal when the motorcycle is off since this wire is responsible for the front and back light
What Im missing to test is the rectifier which is under the tank and Im trying to avoid to remove it.
My doubt still is, how the indicators, horn and brake light can work when the motorcycle is on ? Can a faulty rectifier power this components ? Or even when faulty it should only put AC at the battery plugs or none at all ?
PostPosted: 17:44 - 24 Jul 2024    Post subject: Reply with quote
It's probably working fine, but it's single phase so it's only giving you a single, half-rectified and truncated waveform. More modern bikes have a three phase output with the phases overlapping.
So the output from yours will look like this, you aren't getting a constant voltage:
https://ctlsys.com/wp-content/uploads/2016/10/Positive-Half-Cycles.png
The output from a modern bike with a three phase output will look more like this:
https://media.geeksforgeeks.org/wp-content/uploads/20231114113858/threephasedrawio-(3).png
rego21
PostPosted: 17:48 - 24 Jul 2024    Post subject: Reply with quote
Thanks again! But, how should this be related to the fact that the indicators, brake light and horn are working when I don't have a battery connected ?
PostPosted: 19:07 - 24 Jul 2024    Post subject: Reply with quote
It'll be running off that power directly from the reg/rec as the bike generates it, that's what usually charges the battery. Just, as you can see, it's not a very constant voltage and the frequency of the peaks is dependant on the rev speed (what I referred to earlier to as "dirty" power). That's what your bulbs are seeing. It'll light up an incandescent bulb reasonably well because by the time the filament has started cooling down in the gap, it'll be heating up again from the next peak (although I'd query if they are reaching full brightness due to the overall feebleness of the output). It could well be upsetting the flasher relay, especially an electronic one.
With a battery (or the right combination of capacitors), those gaps in the output will be filled in by the power stored in the battery and you'd have a more or less constant flat line 12VDC for the voltage output. Which electronics will thank you for.
rego21
PostPosted: 22:01 - 24 Jul 2024    Post subject: Reply with quote
Thanks again, you are great!
So if I understood correctly:
The stator will produce AC that will feed the reg/rec. Then, it will convert to DC and power all the components (I think this was the part I was missing, I was thinking that it would only power the front and back light). Since this DC voltage its unstable it may damage the relay and make it unusable. So without battery what I get is:
Front and back light working
Brake light working
Horn working (probably by pressing the horn I will notice this insatiability of the DC voltage)
Indicators working but stall since the relay is fried
Am I correct ?
PostPosted: 06:36 - 25 Jul 2024    Post subject: Reply with quote
That's right, except the head and tail light are running on AC directly from the stator on a seperate set of wiring and so only work when the engine is running even if you do have a battery. So what you have now is how it's set up to be.
Only the flashers, brake light, horn and warning lights work from the DC side. I'd imagine you probably need to rev it quite hard to make the horn sound like anything other than a strangled duck with no battery which shows how little output there is.
rego21
PostPosted: 09:31 - 25 Jul 2024    Post subject: Reply with quote
Thanks very much for your help, learned a lot from you! I will grab a battery and give feedback when everything is up and running.
PostPosted: 10:13 - 25 Jul 2024    Post subject: Reply with quote
Or a very depressed Roadrunner Smile
rego21
PostPosted: 08:18 - 30 Jul 2024    Post subject: Reply with quote
Hi again,
Thanks for the help the issue was indeed with not having a battery to stabilize the voltage!
However this lead acid battery that I have is quite big, would one like this work: https://bs-battery.com/product/bt4b-5-sla/
Thanks again!
PostPosted: 11:46 - 30 Jul 2024    Post subject: Reply with quote
Probably. I have no experience of lithium batteries on that type of charging system so not sure how well it will play. Others might know more.
This is the smallest more conventional lead acid I've been able to find.
https://www.tayna.co.uk/motorcycle-batteries/powerline/ytx4l-bs/
The last post was made 1 year, 188 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.8 - MySQL Queries: 13 - Page Size: 142.84 Kb
