Herald Mirage 125 EFI Bogging Problems
Sulez
PostPosted: 00:42 - 25 Sep 2024    Post subject: Herald Mirage 125 EFI Bogging Problems Reply with quote
Hello, ive got a herald mirage 125 same as the lexmoto tekken and i had a bogging issue, when i open the throttle the bike dies completely if i constantly twisit the fthrottle fast the bike will rev up. I have replaced the whole throttle body and this made no different i even fitted a new injector because i though it was fuel related. Before you say its compression i checked this first and it read 150psi which is perfect so i believe its a wiring issue but i dont know what it can be, can someone point me in the right direction. Also i have changed the spark plug and put fresh fuel in the bike, also did the valve clearances 0.00y for intake and exhaust.
PostPosted: 00:53 - 25 Sep 2024    Post subject: Reply with quote
Let's quantify this situation, might be helpful...
Is this just in neutral or while riding? Does it idle okay? Whereabouts does it bog out? half-throttle, three quarters, etc.
You've bought new parts that didn't make a difference. Did you put the old parts back? (Sometimes you can make things worse by introducing new variables.)
Fuel, air and spark are the essentials. Throttle body and injector are the endpoints but is enough fuel coming out of the tank? Don't know this bike but it probably has a tiny fuel pump either inside or external to the tank, maybe that's the problem.
Have you checked the air filter and intake for blockages? Have you tried taking the air filter out to see if it's better or worse?
Finally spark. Always worth eyeballing the plug out of the bike to check the spark is bright and strong. After that I'm wondering if it's a timing issue as that would change as you go up the revs. Maybe a cam sensor fault?
Oh, and any engine warning light on this bike?
PostPosted: 08:32 - 25 Sep 2024    Post subject: Reply with quote
Did you do something to it just before the bogging down started?
Triumph Sprint ST 1050
PostPosted: 16:18 - 25 Sep 2024    Post subject: Reply with quote
Year? mileage? and as above, any eml light flashes?
Sulez
PostPosted: 00:53 - 27 Sep 2024    Post subject: Reply with quote
The bike starts up fine, when i rev it half throttle it will bog but if i rev it very fast with multiple twists it will rev up abit higher but then still bogs and the engine light comes on randomly and goes off thats whilst it is started btw. I scanned the bike and it was saying a pending fault P0107 "Manifold Absolute Pressure" this code is caused by a faulty MAP sensor but this bike doesn't even have a MAP sensor so i am very confused. Also i have put the original parts back on the bike and no difference was made and i checked the fuel, aire and spark there is a very strong spark. There is plenty of fuel coming from the tank and i replaced the fuel pump/injector they are both one part on this bike not separate. It has a external fuel pump that bolts up to the top of the injector then into the throttle body.
Sulez
PostPosted: 00:54 - 27 Sep 2024    Post subject: Reply with quote
no i bough the bike with this issue lol it is the most strangest problem i have come across. The bike will bog down and cut out if i continue to keep the throttle twisted.
Sulez
PostPosted: 00:57 - 27 Sep 2024    Post subject: Reply with quote
the bike is 2021, the mileage is roughly 8k miles and yes there is a eml light when is running but it randomly clears and comes back. and even when there is no eml light on the bike still has the same bogging issue
Sulez
PostPosted: 01:00 - 27 Sep 2024    Post subject: Reply with quote
i believe it is a intermittent wiring issue because the bike randomly was working fine then when i switched it off and tried it again the bike went back to bogging, so its definitely some wiring issue. Does anyone know if there is some sort of hidden relay or something that would cause this issue or which wires should i check, i wonder if the ecu is faulty could this cause this issue? i did unplug it and re plug it to see if it would fix anything but sadly didnt
PostPosted: 07:51 - 27 Sep 2024    Post subject: Reply with quote
Does the EML light flash when you turn it on?
PostPosted: 17:04 - 27 Sep 2024    Post subject: Reply with quote
It probably does have a MAP sensor but like most small EFI singles
it's part of the throttle body assembly which has the TPS MAP and IAT
all in the same unit.
YBR's have this as did the Honda Forza I worked on/fixed recently
when I replaced what Honda called the above the sensor unit.
'hidden relay'? as in what they dont want you to know about?
it sounds as if you're playing swap and hope and making assumptions
Not best practise, test dont guess is a better method.
I'd start by opening checking and cleaning all electrical connectors and
ensuring the bike has good consistent grounding throughout.
EFI only uses a 5v supply to most sensors and the signal levels are even lower than this, so bad connections or grounding can easily give it conniptions.
Sulez
PostPosted: 21:06 - 27 Sep 2024    Post subject: Reply with quote
no it stays on as a solid light then goes off randomly
Sulez
PostPosted: 21:11 - 27 Sep 2024    Post subject: Reply with quote
If you google 2021 Herald mirage throttle body assembly you will see it does not have a MAP sensor at all it only has a tps sensor thats it. And some efi bikes do have hidden relays wrapped in the loom i had this issue on a similar bike. I have cleaned all the electrical connections today with contact cleaner and still no hope, i even took all the ground points off and sanded them. do you know how i can fix this problem thats showing on the code reader P0107
PostPosted: 21:54 - 27 Sep 2024    Post subject: Reply with quote
Sounds like typical chinese crap then
Burn it
Sulez
PostPosted: 21:06 - 29 Sep 2024    Post subject: Reply with quote
Burn it
hahaha
slowasyoulike
PostPosted: 22:37 - 29 Sep 2024    Post subject: Reply with quote
Here's a video about a Lexmoto that's showing fault code P0107, no idea if it's any use mind because I can't be arsed to watch it...
https://www.youtube.com/watch?v=s9oeAxkZVNg
Best of luck, I suspect you're going to need it.
PostPosted: 13:03 - 30 Sep 2024    Post subject: Reply with quote
That video's got a god awful CG voice track
fuck that, I bailed 10 seconds in but did spot a pic of the combined IAT and IAP sensor on the inlet tube forward of the throttle body
The bike uses a Delphi ECU
probably an MT05
fault code P0107
"open circuit for intake pressure sensor
or
signal end pins shorted to battery negative"
This means its getting either a too high or too low a voltage
on the ECU's IAP pin
the ECU will expect to get voltages between say 1.5v and 3.5v
on this pin and anything out of bounds will trigger a fault
Its either bad connections or the sensor unit has failed
not magic hidden relays
https://imgur.com/vhp9rya.png
There is a gap of 265 days between these two posts...
AaronStan1
PostPosted: 22:36 - 22 Jun 2025    Post subject: Reply with quote
Hello, I have a Herald Mirage 125 (2021) and I seem to be having the same problem. Did you fix the problem? If so, how did you fix it? I'd really appreciate your help.
Aaron Stanbury
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 2.33 - MySQL Queries: 13 - Page Size: 91.57 Kb
