| Author |
| pintofanatic1 |
 pintofanatic1 L Plate Warrior
| Back to top |
| Nobby the Bastard |
| Back to top |
| stinkwheel |
 Posted: 20:37 - 20 Nov 2024 Post subject: |
Well, main suspect would be past the main bearing seal. Could be directly leaking between the crankcase halves.
Alternatively, leaking along one of the cover stud holes or given the age of the bike, if the bikes thrown a chain at some point damaging the crankcase which has then been imperfectly repaired.
Thing to do would be to pop the alternator off, thoroughly clean and degrease the area then leave it to sit for a bit and see if the leak becomes apparent. If nothings showing, reassemble and run it for a bit so the engine's hot then have another look.
If there's still nothing, remember it's possible it has been a very small leak going on for a very long time. It might be easier to ignore it.
How to fix it would depend on where it was coming from.
Be gentle with that alternator. 70's Honda inline 4 alternators are pretty effective but run on a mixture of voodo and black magic and are difficult to repair or replace. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Back to top |
| RhynoCZ |
 RhynoCZ Super Spammer
| Back to top |
| Nobby the Bastard |
| Back to top |
| stinkwheel |
 Posted: 13:20 - 22 Nov 2024 Post subject: |
Well, I for one got the OPs meaning. He had oil leaking from a cover that shouldn't have oil under it.
The rocker cover on that bike would be the "right" place to get an oil leak, entirely understandable and probably easy to fix by fitting a new gasket.
The alternator cover is the "wrong" place because that bike has a dry alternator and so there shouldn't be oil under the cover to be leaking in the first place.
My enfield bullet also has an oil leak in the wrong place, it persistantly weeps oil from the left side of the head gasket. There are no oilways on the left side of the engine. I have elected to ignore it. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Back to top |
| Fizzer Thou |
| Back to top |
| stinkwheel |
| Back to top |
| Fizzer Thou |
| Back to top |
The last post was made 1 year, 17 days ago. Instead of replying here, would creating a new thread be more useful? |
