2013 honda hornet 600 PC41 suspension upgrade query
sell off honda hornet 600
Yes
40%
 40%  [ 2 ]
No
60%
 60%  [ 3 ]
Total Votes : 5
legendracer
PostPosted: 11:34 - 30 Nov 2024    Post subject: 2013 honda hornet 600 PC41 suspension upgrade query Reply with quote
Dear bikers
I own a honda hornet 600 for the past 4 years. I will be getting Yamaha MT 10 SP in near future but I think it's better to keep this inline 4 600cc as a commuter city bike.
It has been weeks since I'm thinking whether to sell off or not, but the relaxed city commuting and corner thrashing is easy on this 600 cc.
Hence I'm thinking of keeping this bike with me for a very long time. I don't know if this worth financial hurdles.
This hornet 600 was designed for relaxed riding and not sharp handling. I know that chassis plays more role.
I'm thinking of Getting adjustable front and rear suspension from nitron UK. Also, akrapovic exhaust decat is in mind. But I'm unsure if I should get a new set of headers, link pipe and slip on our just cut off stock and bolt in link pipe and akrapovic slip on.
Feel free to tell your opinions. I don't mind if you convince me to keep only the MT10 SP and sell off this. Let me know what suspension upgrade options I have in the UK.
Thank you
There is always a surprise waiting on the road which can take you off saddle , no matter how old or experienced you are.
PostPosted: 12:01 - 30 Nov 2024    Post subject: Reply with quote
Or if it's a commuter, does it need a lot of money spending on it. They are pretty good bikes as-is. Does the exhaust need replacing? If not, why bother?
Shock will be tired after 10 years so probably worth servicinging/upgrading.
Fork-wise, is it just the sag that's getting to you? They were soflty sprund as new and a new shock will only amplify that feeling. You could just order up a set of linear springs correct for your weight and riding style and set the sag properly. That's an upgrade that's enormously beneficial and not particularly expensive.
If you wanted a hornet with sportsbike performance, should've bought a CBR6. Are you trying to make it into something it's not? I'd say there's a strong case for appresiating it as it is.
legendracer
PostPosted: 12:15 - 30 Nov 2024    Post subject: Reply with quote
I think I'm trying to make it something it's not. The new bikes like street triple 750 or MT 10 SP are so sharp and powerful that we don't have to struggle so much to keep it in line.
And I'm sure of buying MT 10 SP next. It's just that hornet 600 seemed like a bike which could deliver more with upgrades. I have never been a sportbike rider and prefer naked straight seating posture, hence the hornet 600 with its linear inline 4 power curve.
I thought a professional suspension builder could install shocks like nitron with rebound and preload adjustable at front and rear. I suppose that upgrade at £800 could transform this bike a lot.
I really love the inline 4 free flow exhaust sound. Hence the akrapovic plan but a full system costs £1000 and I couldn't find any used items for my bike.
So that £2000 plan in a bike bought at £4000. And I know MT 10 SP can also do the job of this hornet 600, but in city it needs that heavy clutch play and weight comes into check.
PostPosted: 12:39 - 30 Nov 2024    Post subject: Reply with quote
I think any Hornet has the basics, i.e. a reasonably fun engine and a decent riding position. If you took the bike to a suspension specialist would it be better? Undoubtedly. As good as a Street Triple 765R? Probably not but it would cost you about half the price in total I think.
legendracer
PostPosted: 14:50 - 30 Nov 2024    Post subject: Reply with quote
Thank you. I don't want to feel unaccomplished after that suspension works. I think it's better not to spend £1000 for suspension upgrades. And keep exhaust stock without spending £1000 for this bike. Was thinking of weight saving and bigger suspension upgrade to match latest middleweight bikes but I won't get there with this amount of money.
What would be the reasonable way to make the stock suspension tighter and sharper.
Stick to honda service centre and replace fork springs, oil and rear suspension? Or go to a suspension specialist? Stock parts and rebuild. Guess both would charge almost same for this job. Any pointers please?
PostPosted: 14:55 - 30 Nov 2024    Post subject: Reply with quote
Don't take it to Honda, they'll just put it back to stock. My recommendation would be a quality rear shock, set up properly. A Nitron, Ohlins or that kind of level. Then get a specialist to rebuild the fork to match the shock, and get it set up for your weight and riding style. That'll transform the bike. Remember though, with quality suspension you usually get a wider range of adjustment, so it's easy to make it feel bad or the same as before. The set up part is very important.
PostPosted: 18:11 - 30 Nov 2024    Post subject: Reply with quote
Got to endorse that statement. When I had my STR I was pretty disappointed with eh suspension whatever I did. I then had it set up by a suspension firm at a track day and it was like night and day compared with before.
Triumph Trophy Launch Edition
PostPosted: 19:41 - 30 Nov 2024    Post subject: Reply with quote
There is something to be said for improving and refining an existing product, taking an off-the-peg and making it a tailor-made.
On the Husky I've done all sorts of things that are barely value-for-money on the face of it but I am now very familiar with the bike's construction and running.
PostPosted: 22:02 - 30 Nov 2024    Post subject: Reply with quote
I find suspension is very much a case of diminishing returns. The first bit you spend gives you the most benefit, then it both peters off and gets progrssively more expensive for each increment of further improvement.
Start getting the correct spring rate and setting your sag. That's the most important. After that you get more progressively more fiddling and expense for smaller benefits.
I'll give you the example of my VFR750 which I had the shock rebuilt and sprung for my weight and typical luggage load. I set up the static sag, it had various damping settings, all of which I left factory.
I went on a three day trip to the Highlands on it and towards the end of day 1, the shock shat itself* . I mean it totally shat itself, no damping at all, just a spring. I was still able to ride the bike on twisty highland roads at a fair percentage of my normal speed for the rest of the trip, certainly quickly enough to keep up with the pace of the group. It wasn't fantastic but it was perfectly rideable, even quite enthusiastically. Tendancy to get a bounce-on if you hit a big compression or a double bump but with a bit of fine throttle and rear brake control, it was far from unmanageable. Even got into a race with a random powerranger on a fireblade on the Darva Moor road and while I didn't pass him, he didn't shake me either. It'll have been a 1000 mile weekend and was thoroughly enjoyable.
My point? If I have one. Get the basics right, beware of guilding the lilly on what was a fairly moddle or the road sports commuter bike. Spend the extra on good tyres.
* Later turns out the re-chromed damper rod had de-laminated and blown chrome flakes throughout the internals, tearing all the oil selas and blassers the pressure bladder to shreds. Effectively became a spring with a guide-rod attached.
legendracer
PostPosted: 10:41 - 02 Dec 2024    Post subject: Reply with quote
Any suspension specialists recommendation near Luton who could do both front and rear at a reasonable cost.
ThunderGuts
PostPosted: 07:26 - 05 Dec 2024    Post subject: Reply with quote
Just to sort of tie into the above, I recently had a vaguely similar situation where I was getting a bit dissatisfied with my VFR and toying with changing bikes. In the end I took it to a local suspension specialist (near Manchester, so no use to the OP). He visually grimaced at the general state of the suspension, although said it's partly wear and partly just slightly budget spec from the factory. He did some adjustments there and then, but we discussed an upgrade (Hyperpro front spring kit and Nitron R1 rear shock) and I decided to go for it in the end. The work has literally just been finished and I'm getting the bike back on Saturday!
TG.
PostPosted: 17:58 - 05 Dec 2024    Post subject: Reply with quote
I confidently predict you will want to upgrade the brakes next. My other top tip if it's a VFR750 is to try dropping the forks through the yokes a bit, maybe 1/2 to 1". Sharpens the steering up a lot and your new suspension will keep it under control.
PotatoHead202...
PostPosted: 14:50 - 06 Dec 2024    Post subject: Reply with quote
Yes, it's worth it to a degree.
I can't fathom how so many people will spend hundreds if not thousands on exhausts and remaps but fuck all on suspension that was pretty shit to begin with.
I fitted a YSS shock on my CBF500 which transformed it from feeling like there was a hinge in the chassis to feeling reasonably good.
I then fitted hyperpro springs and about a year or two later a YSS PD valve kit and had the damper rod modded to suit. That vastly improved the front - albeit it still majorly lacks feel compared to a cartridge setup.
I fitted a custom Nitron R1 to my VFR1200F which stopped it feeling like it was dragging it's arse around the whole time. Shortly after I fitted K Tech linear springs and about 3 months after that I had a K Tech Fork Piston Kit added. Again, this vastly improved the handling and general comfort.
More recently I fitted a Nitron R1 ADV 46mm shock to my V Strom. The original wasn't terrible (like the other two above) but it wasn't great. The Nitron vastly improved the damping over rough ground however and has allowed me to be comfortable at much higher speeds.
Everyone I spoke to about the above bikes regretted going for the more advanced Nitron stuff as they simply never adjusted it more than to set the initial sag etc - it coped admirably as it was so would have gone for the R1 instead of the R3 etc.
I asked about having my shocks rebuilt but most recommended getting an aftermarket replacement as the oem stuff was so poor and not a lot could be done to improve them.
I'd thoroughly recommend Lukas and T Tech Suspension in Croydon. I'll guarantee he'll be cheaper than any of the main culprits, he'll send you picture and video updates of any issues (he has one of those fancy machines that measure all the stuff to measure) and will take on jobs others can't be bothered with. I noticed pitting on my VFR1200F fork stanchions and he was the only person to agree to replace them - which he did successfully.
Suzuki V Strom 1050XT, Honda CBF500 ABS,
Robby
Dirty Old Man
PostPosted: 09:40 - 07 Dec 2024    Post subject: Reply with quote
PotatoHead2020 wrote:
I'd thoroughly recommend Lukas and T Tech Suspension in Croydon. .
Today I learned there's a suspension set up person near me, I'll go and see him in the summer.
legendracer
PostPosted: 11:13 - 09 Dec 2024    Post subject: Reply with quote
Same here. I will visit him. Thank you
ThunderGuts
PostPosted: 07:58 - 10 Dec 2024    Post subject: Reply with quote
It's a VFR800X Crossrunner actually; I've got some EBC HH pads to pop in over Christmas to see how they go, but to be honest the brakes are pretty reasonable already.
Picked the bike up on Saturday and gave it a quick spin after a toy run on Sunday; it was raining and generally horrible, but the bike felt a lot more planted and confidence inspiring. I was happy "going with the flow" on a twisy wet road where previously I'd have been a bit preoccupied with it wallowing and crashing about on such a road. The ride is definitely firmer but not uncomfortable. Weirdly it seems to have sharper slow speed control, I assume because it's not wallowing around. It's not a little pit bike, but it feels much better than it did in those situations too.
Looking forward to a dry mild day to thrash it down my "benchmark" road.
TG.
PostPosted: 12:25 - 10 Dec 2024    Post subject: Reply with quote
Ah right. They have opposed piston brakes. The 750s are all on sliding pin callipers which were kind of becoming antiquated when the bikes were new. I did it the other way round on my 750. I upgraded the brakes to 6-pots then had a couple of "incidents" under the now possible heavy braking on the edge of tyre adhesion that highlighted how apalling the suspension setup was.
It's probably turning better because you have reduced rider sag on the rear end meaning it's sitting higher under load. Higher rear end = tighter fork rake angle = faster steering.
legendracer
PostPosted: 14:47 - 10 Dec 2024    Post subject: Reply with quote
Could anyone give some guidance for aftermarket exhaust too please?
New akrapovic system costs £1000. I can go used route too, but couldn't find anything for this bike.
rpsmith79
PostPosted: 15:51 - 10 Dec 2024    Post subject: Reply with quote
Had a second hand Delkevik on mine a few years back, pretty good quality at a reasonable price, plenty of options too, from full systems, to slip on end cans, and loads of styles of cans too
https://delkevic.co.uk/s/Honda/CB600F%20Hornet/2013
The last post was made 1 year, 42 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.85 - MySQL Queries: 15 - Page Size: 117.86 Kb
