Kawasaki er5 2005 running issues
VengefulRat
PostPosted: 13:28 - 28 Dec 2024    Post subject: Kawasaki er5 2005 running issues Reply with quote
So here's a bit of a wall of text.
Bought my Er5 a few months ago. Bought it cheap since it wasn't running well. Got a carb rebuild kit and got that done. After two days of working on those, managed to put them in and with everything on factory spec, started and it's alive! Fantastic! There's also a water leak at the top where the radiator cap is located but not too worried about that. So anyways, back to the issue at hand.
I have the radiator fan now with a switch connected directly to the battery. Whatever is going on with the fan wiring, as soon as it kicks in, the bike either pops the fuse for the fan or it once popped the main fuse of the bike. So the wiring there is dodgy. Also, had the multimeter on and the bike is getting 12.5v charging while idling and even during revving. So I'm pretty sure the reg is gone. i just want to confirm with other people before I take out money for another regulator.
So, that's one issue mentioned. With the carbs, after fitting them and having everything stock. I do notice it is running rich. Back fires a ton when letting off the cash from high revs or changing gears. otherwise, she goes. However, the bike stood for about two weeks while waiting for a clutch cable. Now I'm riding again and this happens.
So will start and get going. But under 3k rpm, she's feeling very heavy. Like there's a whole cylinder missing or something else is preventing spark. Feels like it wants to die. But then suddenly lurches forward and it's all good.
Once I get close to home, she wants to completely give in. If I give throttle, suddenly she bogs, under 5k rpm, bogs. I have to rev her up before I can pull away from most stops.
I know the carbs aren't perfectly tuned but they were running a hell of a lot beter than this. The little dip it takes when revving from idle is something that bothers me. It's the bogging down that makes me pucker up and worry.
So if anyone has some advice, I'm all ears.
Thanks for reading.
And thanks for any help.
jaffa90
PostPosted: 16:03 - 28 Dec 2024    Post subject: Reply with quote
Hi, is the tank breathing for the fuel to flow, also is there an in-line fuel filter (crap from the tank /tap?) and what fuel tap position are you using and what happens if you leave the tap on PRI position???
PostPosted: 16:30 - 28 Dec 2024    Post subject: Reply with quote
So misfiring/running on one at idle. I'd address that first. I'd be thinking electrical. If you can work out which it's misfiring on, you can swap ignition componants over one at a time until it switches sides. A laser thermometer is handy for this because you can check the header pipe temperatures. The old way was to put a drop of oil on the headers and see if it was burning off.
Have you checked the plugs and plug caps. When were the plugs last changed? Are the caps all corroded and manky? The plug sit down into a recess on the head which has a small drain hole which comes out between two of the fake cooling fins on either side of the head. It's a magnet for road dirt and junk. Then if the drain hole gets blocked, it's a water trap. It can land up as an absolute filthy mess of corrosion and road dirt in there.
Don't just go in with a plug spanner, give the recess a good soak in WD40 then blow any detritus out with an airgun, there are often small stones and bits of grit in there which will drop into the engine if not removed first. If you don't have an airline, I've used blu-tak on a stick before. You will also need either ther original plug spanner or a long tube spanner, a normal plug socket won't fit in there.
I'd also check the terminals on the coils are clean and the frame earth from the coils because the brackets often go rusty.
Then charging. Don't assume it's the reg/rec. On some models of EX500 motor, the magnets on the alternator rotor could come adrift then smash and cover everything with magnetic dust. I'd do a test on the alternator.
So the three output wires are where you're testing (3 yellows I think). You want equal resistance between each pair of yellows and an open circuit between each yellow and a frame earth. With the engine running and the meter on volts AC, you want a fairly high voltage between each pair of yellows. It will fluctuate with revs, could go as high as 50v.
That would tend to suggest the alternator function is ok but ultimately, the only real way to check the magnets is to pop the cover off and look.
I presume the air filter is new/clean since you've also had the carbs off.
If you're running it on total loss, I wonder if you're getting enough power.
blurredman
PostPosted: 17:02 - 29 Dec 2024    Post subject: Reply with quote
I would also test coils, HT leads, spark plugs, and caps and replace whatever fails. I had same problem. It was a long time ago though so a pair of 2nd hand coils was stupidly cheap. The miser in me would not replace multiple items in bulk so readily these days though. Laughing
PostPosted: 09:12 - 30 Dec 2024    Post subject: Reply with quote
Did you flush the tank? Rust and water can cause a lot of issues.
WarrSquirrel
PostPosted: 09:17 - 30 Dec 2024    Post subject: Reply with quote
I'll give all the ideas a go.
Also, new account because for the life of me, I can't find my old account. Can't log in and can't reset password.
Anyways. The spark plugs, oil, oil filter, everything is new. Did a full service. Also checked the air filter. It was clean with no blocks. So didn't have to replace that. The HT leads I'll have to check for spark. See what happens when I switch or plug them out or something.
As for the stator. That one I've never run a multimeter on. So I'll check a few vids on how to test it correctly. I'm going to take off the tank tomorrow and undo everything on the cooling at the top and see what needs to be replaced that's causing the leak. As you said, might be water collecting due to gunk build up. So I'll clean that all out as well. Don't have an air gun or compressor but I'll loose it with some cleaner or some kind, and blow it out with a can of air or something like that.
The fuel tap I leave on prime permanently. I have a secondary valve between the carbs and fuel tap. I don't think it's an air lock. But to be safe, I'll pop the petrol cap and ride home with it open and see what happens.
So test test charging on both ends. Clean spark plug holes, just in case. Check tank vacuum and fix water leak. Got a busy two days ahead of me.
WarrSquirrel
PostPosted: 10:11 - 30 Dec 2024    Post subject: Reply with quote
That might be more of a difficult task. Don't have anything to flush with and can't leave it to stand for a few days since it's my main mode of transport. Off for the next two days so have t o make them count. But I did look inside the tank. Saw no rust or debris. Fuel flows fast and strong from the tank as well.
jaffa90
PostPosted: 10:50 - 30 Dec 2024    Post subject: Reply with quote
Hi again, """""(The fuel tap I leave on prime permanently. I have a secondary valve between the carbs and fuel tap)"""
Ok then what happens if you leave the secondary valve on as well with the bike doing nowt?
PotatoHead202...
PostPosted: 12:42 - 01 Jan 2025    Post subject: Reply with quote
That intermittent running sounds like coils
Suzuki V Strom 1050XT, Honda CBF500 ABS,
WarrSquirrel
PostPosted: 05:54 - 04 Jan 2025    Post subject: Reply with quote
I've checked everything else. It might be the coils at the end. The charging system isn't an issue. That works. The carbs I know are not perfect. It idles and rides but the sudden loss of power and coming back again is supposed to happen at all times when it's the carbs. It's only happening when it's warmed up. So might be the coils that can't handle heat anymore.
WarrSquirrel
PostPosted: 05:56 - 04 Jan 2025    Post subject: Reply with quote
I'll give that a shot when I'm riding to work this morning. I'm at a loss at the moment. I have no idea what else could be causing this. Might have to end up giving money to a bike shop but can't afford that yet.
What I don't understand, it was running fine for a while and then one day, I checked, the one spark plug was a bit loose. So I tightened it a little, nothing excessive, and that's when it started doing this weird power loss when bike gets hot. I'll have to try to make a video of it.
PostPosted: 08:38 - 04 Jan 2025    Post subject: Reply with quote
9 out of 10 carburettion problems are electrical.
Two other "features" of the EX500 platform. (I've owned three, two GPZ500ss and a KLE500). These happened on all three of them.
The ignition switch can partially fail. So it gives you all the lights and electrics, including the starter BUT it doesn't give you spark. If it's turning over but not starting, look at the rev counter to see if the needle is ticking as it turns over. If it isn't, be suspicious.
The main supply wire for the loom is prone to corrosion. Tends to cause intermittant loss of all power but probably leads to very poor conducting of power on the lead up to it. If you find the starter solenoid, it has a fuse holder on it for the main 30A fuse. The wire leading from the fuse holder to the ignition switch corroded into oblivion on all three of mine. Usually a fat white wire, it can go at either end but it's worth pulling the fuse holder and having a look. The terminal on the fuse could have a moth-eaten appearance and the terminal may be full of green corrosion. I landed up replacing the whole wire on all three of mine because the corrosion had tracked a long way up the wire under the insulation.
A final carb thing I encountered. They were made before ethanol fuel was a thing. My KLE had a lot of misfires and starting issues and actually set itself on fire because the needle valves in the carb got corroded and stuck variously open or closed. it flooded the airbox on a long run and set fire to itself. Luckily it sucked the flames into the engine and self-extinguished leaving a melted hole in the airbox. I'll add I stripped and ultrasonically cleaned the carbs a couple of months before this happened, the needles were actually furry when I inspected them. Happily, you can buy new, viton-tipped needle valves which are ethanol proof.
WarrSquirrel
PostPosted: 10:30 - 04 Jan 2025    Post subject: Reply with quote
I tried taking a video this morning but for some reason my phone didn't save it. Anyway. Cold start with choke. Starts instantly. It idles. Revs. It rides. When it's cold, it's a dream. Rides like a champ. As soon as it gets hot, it bogs. The first 4 to 5k revs, it sounds muted and under power and then suddenly opens up. And once you're riding, it's fine. As soon as you stop and have to pull away, it does that bog, no power issue. I'm trying to figure out how to mount my phone to take a video fo this happening.
PotatoHead202...
PostPosted: 17:57 - 12 Jan 2025    Post subject: Reply with quote
These are exactly the symptoms I had with corroded coils on my 500. The top of one bad cracked and corroded inside.
WarrSquirrel
PostPosted: 06:49 - 05 Mar 2025    Post subject: Reply with quote
So it's been a while I've been riding the bike. It's been dry for the most part and she's been riding really well. On days that it rained, I would get a bigging issue. So I checked first the other stuff. Fuel tap, charging etc. They're all working perfectly. The other day, there was a massive downpour. Managed to get the bike started after a massive struggling and she went. Then there came a second downpour. Man was that even worse.
So now the bike is standing. She starts and idles but can't get revs and power. Here's a video of what happens. Left her to stand for a few days to dry out and see if that does anything. So far, no luck. It's been about five days and still exactly the same issue. I can't see water anywhere. Plugs are dry. Wires are dry. Air box is dry. Nothing changed other than rain. I'm at a loss now.
I the video you will see I have to very lightly touch the throttle. Just a little too much and she dies. If I touch it gently, the revs will climb a little and then start going down until it eventually runs out of fuel almost. But there is fuel. Can stand and idle all day long.
https://youtu.be/FdQfKzSoJLI?si=_p4_GoR8PXojYful
PostPosted: 09:10 - 05 Mar 2025    Post subject: Reply with quote
Well, a logical thing to check would be for water in the fuel. Drain the float bowls into a jam-jar and see if there's water in there. You'd see it as droplets or a layer under the fuel once it's settled for a few minutes.
May also be worth popping the air filter out and seeing if there's water in the airbox.
WarrSquirrel
PostPosted: 10:42 - 05 Mar 2025    Post subject: Reply with quote
I've checked the air filter. It's dry. Took it out and had the bike idling. Still does exactly the same. I can't drain the bowls unfortunately. Bike is stuck at work in the parking basement and yeah, if I start stripping it, management will start complaining. I say that because I can't remove the float bowls. Or drain them anyway. The drain screws I tried replacing when I rebuilt the carbs and they refused to come out. Eventually they stripped. I tried everything to get them out and yeah, they're stuck in place. So only option would be to remove the carbs completely to check.
I've also checked the spark. It's really good. If I remove one plug, I hear a change in the engine and it sparks wildly against the engine. So spark is good. Spark is strong. Spark hurts.
PostPosted: 11:14 - 05 Mar 2025    Post subject: Reply with quote
Have a look in the tank with a torch then, you can often see water if it's in there. Looks like little beads rolling around in the bottom (or in severe cases, a layer of rusty water).
You also get stuff called Kolor Kut which is a paste you put on the end of a piece of dowel then gently poke it into the deeper recesses of the fuel tank. If there's water there, it will turn red.
WarrSquirrel
PostPosted: 11:46 - 05 Mar 2025    Post subject: Reply with quote
WATER IN THE EFFING CARBS! That's the issue. I said screw it. If they want to moan, let them moan. I need my transport running. So pulling the carbs, took the bowls off. Yuuuppp. Water in the carbs. So now I need to know. How that happened? Was it through the seal? Is it from the tank? Is it from the air box? Urg. This is going to give me a headache. But it's a damn start at least! I don't think it's from the tank. I think it's from somewhere else since this only happens when it rains.
PostPosted: 12:20 - 05 Mar 2025    Post subject: Reply with quote
Only way water can get into the float bowl is from the tank. Only way it can get into the tank is from the filler or breather.
If the breather is blocked, it could suck in through the cap lock when a vacuum occurrs in the tank such as when running the engine or if the temperature drops.
So I'd check the tank breather isn't pinched or blocked somewhere, fuel cap seal and the drain under the fuel cap (which should drain any water or fuel overfill from the rim round the filler hole) first off.
I'd also check in the tank for water as per my previous post, you may need to drain it if water has accumulated.
Water can also get in the tank if ethanol fuel has sat in there too long. The ethanol absorbs water from the atmosphere over time and if it absorbs over a certain amount, it splits from the fuel forming a layer of dilute ethanol under the fuel.
WarrSquirrel
PostPosted: 14:34 - 05 Mar 2025    Post subject: Reply with quote
There's a small opening under the air box, that links to the engine. I've got no pipe between that breather hole and the engine. Could that also possibly be an entry way? Sucked in via the air box and the into the bowl, which I doubt since it's in the bowl. So has to be from the tank. But the tank shouldn't have a leak. As I said, it only happens when it rains. Otherwise, she drives beautifully. Did two full tanks before rain came. First rain, boom, blogging.
PostPosted: 15:48 - 05 Mar 2025    Post subject: Reply with quote
Random ER5 tank schematic:
https://images.cmsnl.com/img/partslists/kawasaki-er500-c3-er-5-2003-europe-middle-east-africa-uk-fuel-tank_big3IMG01216737_152b.gif
If you think of the recess around the filler cap as guttering then the pipe "92191" is the downpipe. If the area round the filler cap fills up with water and the pipe is blocked or kinked and the cap isn't perfectly sealing water might creep in.
A quick test you could do is get a cup full of petrol and pour it around the fuel cap recess. Now look under the bike and see if/where the petrol is dripping out to help trace how the pipe is run.
You could pour water instead but 1) you might end up adding more water to your tank! and 2) petrol's a solvent so it might dissolve some crud in the troublesome pipe.
<edit> typo, thanks Raffles!
WarrSquirrel
PostPosted: 06:58 - 06 Mar 2025    Post subject: Reply with quote
I see the pipe you mean. Yesterday when I removed it, fuel flowed freely. What I can do is maybe disconnect it into a jar, see if water comes out as well. That would indicate water in the tank. Currently, the pipe is routed as it should be along the air box.
PostPosted: 09:47 - 06 Mar 2025    Post subject: Reply with quote
.. and condensation
Raffles
PostPosted: 15:12 - 06 Mar 2025    Post subject: Reply with quote
I fear that you may have disconnected the wrong pipe.
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.28 - MySQL Queries: 13 - Page Size: 144.39 Kb
