| Author |
| virus |
 virus World Chat Champion
 Posted: 19:28 - 30 Dec 2024 Post subject: Softlink Camchains |
Anyone got any experience with them?
MY oilboiler Suzuki needs a new camchain soon. The motor is a pig to get in and out so I was looking at doing a soft link cam chain from above but not sure how easy it is to do and trust? Id be buying direct from a reputable manufacturer of course.
Got a mech CCT in at the moment as the auto one ran out of travel, Normally this would suggest that other components such as camchain guides, big end bearings, piston rings etc. would be in need of a once over at the same time hence its usually a full engine strip to do.
I however built this engine out of a series of second hand parts of various levels of wear and have changed cylinder head and cams for different model parts anyways. Im confident enough that its only the chain itself thats in need of replacement.
John ____________________ own: 81 xs1100g...
| Back to top |
| stinkwheel |
 Posted: 23:00 - 30 Dec 2024 Post subject: |
No experience of them, but if they'll take full engine power on a final drive chain under varying tension conditions and covered in road dirt. I can't see whay they wouldn't cope with compressing a few valve springs while sitting in a spotlessly clean oil bath. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Back to top |
| yen_powell |
 yen_powell World Chat Champion
| Back to top |
| sickpup |
 sickpup Old Timer
| Back to top |
| virus |
| Back to top |
| stinkwheel |
 Posted: 01:51 - 01 Jan 2025 Post subject: |
If they are anything like final drive softlinks, they should specify a diameter the end of the pin needs to be squished out to. It's usually printed on the box or on that little bit of paper you immediately throw away.
Might be in one of the engineering reference books too, they'll probably be an ISO standard chain. I'd imagine there's one kicking about at your work. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Back to top |
| sickpup |
 sickpup Old Timer
| Back to top |
| virus |
| Back to top |
The last post was made 1 year, 17 days ago. Instead of replying here, would creating a new thread be more useful? |
