2008 Deauville rework
sickpup
Old Timer
PostPosted: 17:34 - 09 Jan 2025    Post subject: 2008 Deauville rework Reply with quote
Bought this VA8 Deauville a few year back from a good mate who was moving back to Brazil.
Was a good price considering it had a new very custom Top Sellerie raised, gelled and heated seat that set him back £700 which is now on my main bike.
I knew the bike had some problems courtesy of being looked after by bad mechanics but it should be pretty easy to turn it back into a reliable bike.
Biggest problem with it is the wiring. It had a heated seat, heated muffs, heated grips, two sets of spotlights, 2 wireless phone chargers, USB points, cigarette socket, 3 heated clothing cables and cameras.
Some of the bits were wired (badly) into a switched live on the fuse box but were rated beyond the main loom wiring, some was wired direct to the battery, its all a mess. It all needs stripping out, a fuse box adding via a switched live relay, possibly an always live fuse box, an alarm added and some serious cable management.
Rats nest under the seat
https://www.bikechatforums.com/files/20250109_160839.jpg
Multiple earths taped together
https://www.bikechatforums.com/files/20250109_160920.jpg
Multiple lives taped together
https://www.bikechatforums.com/files/20250109_160834.jpg
After all that it needs a good service, the rad is leaking so that needs repairing, fork gaitors adding and anything else I find along the way.
Tarmacsurfer
PostPosted: 12:53 - 17 Jan 2025    Post subject: Reply with quote
I'm vaguely surprised that didn't lose the magic smoke in a very spectacular fashion. Did I ever tell you the tale of my ZZR trying to set itself alight when the starter solenoid shook loose after a spirited ride took me over an unexpected speedbump and shorted live to the frame just under the fuel tank? Laughing
I'll admit to never having tried the Deauville, but I did spend a truly miserable six months on an NTV before convincing the boss to fuck it off and let me switch to that tatty old XJ9 I was on for years. Honestly hated the thing with a passion, did they actually change much or was the Deauville just a bodywork refresh on the same motor and frame?
I'm immortal. Well, so far.
sickpup
Old Timer
PostPosted: 14:50 - 21 Jan 2025    Post subject: Reply with quote
Pretty much a bodywork refresh and a lot of added weight. My main one has a 2" higher seat and a Hagon shock with a 10% harder spring and a bit more length so would likely suit you better. I also have a 1" higher seat, a standard seat and a lowered seat so went through a few to get things right.
The motor is pretty much the same with a newer design 4 valve head replacing the old 3 valve one so a bit more mid and top end but still far from quick. Still only good for about 45-55 mpg
Handlebars are a lot higher than an NTV so much more sit up position and the huge adjustable height screen and bodywork that keeps the wind and rain off. Better brakes as well.
The mechanics who did that wiring did set light to his old bike claiming they electricity started going the other way. Definitely nothing to do with sticking 30amp fuses into 10amp circuits.
sickpup
Old Timer
PostPosted: 18:47 - 29 Apr 2025    Post subject: Reply with quote
Had some more time today so started taking it apart and found more horrors. About 60%+ of the bolts are wrong, too long, too short, wrong machine screw etc and a fair smattering of panel nuts instead of the correct fittings.
There are cables coiled all over the bike, under every panel.
https://www.bikechatforums.com/files/20250429_154743.jpg
The mechanics who fitted the heated grips decide not to use the fitted multi connectors and changed them for 4mm bullets which are too big then wrapped them with insulating tape so there are snake bellies everywhere.
https://www.bikechatforums.com/files/img-20250429-wa0010.jpeg
The heated grips were so badly fitted that although they had a mount to bolt the controller to the front brake master cylinder, it was cable tied to the handlebars.
Deauvilles have an accessory called a 'Quartet harness' that plugs in and gives 3 powered points to add spot lights, heated grips etc. Instead of using this fully, it has one fitted, the previous mechanics hacked into the loom.
One item was plugged in the Quartet harness and then another bodged into it.
https://www.bikechatforums.com/files/img-20250429-wa0016.jpeg
In the end, I removed all of these cables from the bike, easier to just remove them all and start again.
https://www.bikechatforums.com/files/img-20250429-wa0018.jpeg
There is a take off (that isn't in the wiring diagram) at the rear of the bike for the Honda Averto Alarm, this was used for the camera system fitted to the bike. Again, instead of using a plug and just plugging in the previous mechanic hacked the loom.
https://www.bikechatforums.com/files/img-20250429-wa0005.jpeg
The belly pan kit on these comes with rubber well nuts. Instead of using them the previous mechanic knew better and used panel nuts. This is of course inside the fairing so pretty hard to get to.
https://www.bikechatforums.com/files/img-20250429-wa0020.jpeg
PostPosted: 20:02 - 29 Apr 2025    Post subject: Reply with quote
As a rule previous owners are witless wankers..
sickpup
Old Timer
PostPosted: 21:00 - 29 Apr 2025    Post subject: Reply with quote
It wasn't the owner, he paid a lot of money to a garage to make a mess of his bike.
PostPosted: 21:52 - 29 Apr 2025    Post subject: Reply with quote
"...snake bellies everywhere." Laughing
This is why I started doing my own vehicle servicing: why pay someone > £80 per hour to fuck something up when I can break it for free?
PostPosted: 08:33 - 30 Apr 2025    Post subject: Reply with quote
sickpup wrote:
It wasn't the owner, he paid a lot of money..
Thinking
PostPosted: 09:54 - 30 Apr 2025    Post subject: Reply with quote
Thats a mess
Was it dem Brazilian 'mechanics' did that?
Every time my Deliveroo guy turns up with his scoot I see evidence of their work.
The idiot keeps going back to the feckers though despite my advice not to.
sickpup
Old Timer
PostPosted: 10:07 - 30 Apr 2025    Post subject: Reply with quote
It was.
I believe it's also the shop your local Brazilian mechanic worked in before moving to Bristol.
Thing is these customers will pay £60 an hour for low quality work from someone who speaks Portuguese but won't pay £60 an hour for quality work from someone who doesn't.
PostPosted: 12:07 - 30 Apr 2025    Post subject: Reply with quote
Every time I see and have often had to correct their work
it looks like it was done by someone who might have a box of spanners butnever had training in any kind of engineering or good working practise.
For folk like this to to charge for professional services is a piss take
My guy (a full time delivery boi) bought a brand new PCX from Fowlers the local main dealer.
He came by last week I had a look around it and was shocked by the flimsy, shabby, box platform
"Surely Fowlers didnt fit this" I said
"Oh no, I got the Brazilians guys to do that"
I shouldn't complain I suppose, another job for me soon I expect
sickpup
Old Timer
PostPosted: 12:11 - 30 Apr 2025    Post subject: Reply with quote
Normally 1/2 box section, badly welded with door hinges tacked on at the back so the pizza box can be raised, the seat raised and the scooter filled with petrol.
A very low quality fitment.
Don't forget the bit of ply under the box so it doesn't collapse.
sickpup
Old Timer
PostPosted: 16:18 - 07 May 2025    Post subject: Reply with quote
Managed to get more apart and to remove the leaking radiator today.
Even more wrong bolts, the fairings on both side are damaged, it's going to cost a fortune in fittings so I think I'll just be buying one of the stainless kits off Ebay for £30.
The genuine bellypan is destroyed. Fitted with all the wrong bolts and holes drilled all over it. Broken and put back together with zip ties, badly.
Head races are notched so will need replacing.
The pilot in the headlamp has been hacked into to power two crap spotlights. That'll need cleaning up.
Also looks like the forks will need rechroming as well but I have another bike that I can borrow the forks off to get this one on the road.
Various hoses also need changing and a good service.
to v or not to v
PostPosted: 18:44 - 07 May 2025    Post subject: Reply with quote
is the bike worth your time/expense?
Moto Guzzi V7.
sickpup
Old Timer
PostPosted: 10:29 - 08 May 2025    Post subject: Reply with quote
Yes and no, but mainly yes.
Deauvilles are an odd bike, there is no modern equivalent at a reasonable price that can be insured cheaply in Central London because no one wants to nick them.
If you want a shaft drive and luggage capacity you are looking at BMW's which are a lot pricier to buy, maintain and insure. You could go for a super scooter but these have their own problems, high cost to buy, insure and maintenance as well as being theft targets.
The Best low mileage Deauvilles tend to go for between £4000-£5000 and middle of the road ones needing work from £2500-£4000.
Low quality and high mileage ones needing lots of work start at around £1200.
Already having it sat here and just needing work makes it a viable repair that once sorted will need minimal servicing.
It will cost a lot of hours to rebuild but shouldn't cost too much in money, I'm estimating between £250-£750.
The last post was made 1 year, 188 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 91.18 Kb
