z750 indicators flashing quickly
Zeus
PostPosted: 15:31 - 20 May 2025    Post subject: z750 indicators flashing quickly Reply with quote
Both my indicators on the left side were flashing to fast, then the next day the back left stopped all together. I put in new bulbs but no change. I did notice I had loads of corrosion in both indicators. The one even had water inside the bulb. I've put a picture below of the corrosion. I did scrub the bit that makes contact with the bottom part of the bulb but no change. Would the other rusty parts stop a good connection?
Thank you.
https://i.ibb.co/Ld0kdZLr/IMG-20250519-145036863-HDR.jpg
PostPosted: 18:24 - 20 May 2025    Post subject: Reply with quote
Thas yer bad grounding mate
probly
PostPosted: 21:45 - 20 May 2025    Post subject: Re: z750 indicators flashing quickly Reply with quote
Thank you.
Yes.
PostPosted: 09:54 - 21 May 2025    Post subject: Re: z750 indicators flashing quickly Reply with quote
Shocked and it still lit?
blurredman
PostPosted: 10:53 - 21 May 2025    Post subject: Re: z750 indicators flashing quickly Reply with quote
Yes I wondered if this was actually the case.
Zeus
PostPosted: 15:35 - 21 May 2025    Post subject: Reply with quote
Yes the one with orange rust water inside still works. I'm going buy a new indicator for the other one, only problem the bolt is rusty as heck and I can't get it off, and why is it seized bolts are always in tight spaces you can't get at. Very frustating Mad Mad Mad
PostPosted: 17:10 - 21 May 2025    Post subject: Reply with quote
My Russian bike has a novel solution to this issue. Instead of trying to seal the indicators with o-rings and suchlike, they made them with a small hole in the bottom of the shell so if water gets in, it can get back out again.
PostPosted: 21:01 - 21 May 2025    Post subject: Reply with quote
Ah not exactly within teh bulb then, the indicator enclosure.
The last post was made 1 year ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 59.25 Kb
