Poor starting moped
Farmingstock
PostPosted: 22:26 - 02 Jul 2025    Post subject: Poor starting moped Reply with quote
I have a 4T Piaggio Zip 50cc that will eventually start but takes forever.
Changed the plug (spark is fine)
Checked the valves (.10 and .15)
Changed the choke to manual
Charged battery fully
Changed the fuel
Checked the fuel pump (fine to the carb)
Cleaned the carb
The bike will start eventually and starts fine once it’s started but once left overnight or for long periods it takes forever to start and you get the feeling it isn’t going to start.
Any suggestions?
PostPosted: 22:49 - 02 Jul 2025    Post subject: Reply with quote
compression check?
Farmingstock
PostPosted: 22:55 - 02 Jul 2025    Post subject: Reply with quote
A100man wrote:
compression check?
Not done one because the way the engine is located Can’t get a tester into the plug hole without removing the engine.
It runs fine once started and doesn’t lack power for one of them!
sickpup
Old Timer
PostPosted: 23:57 - 02 Jul 2025    Post subject: Reply with quote
Get one with a rubber hose, not a push on one.
Iirc if you remove the under seat bucket you can get access to the head that way.
Farmingstock
PostPosted: 16:47 - 08 Jul 2025    Post subject: Reply with quote
Had another look today and can’t test the compression without taking the engine out, there is bearly enough room to get a socket on the end of the plug!
that_impulse_guy
PostPosted: 10:15 - 09 Jul 2025    Post subject: Reply with quote
it does sound like you need to investigate "changed the choke to manual" a bit more.
there is nothing that changes the starting procedure between hot and cold, besides the choke. Going over what you said, power is fine, hot starting is fine..restarting is fine.
so check out choke a bit. If you changed it to manual was it because you had good information that the automatic choke wasnt working? etc etc...go over that part of your thinking and redo if you find error in the logic. You perhaps have more info now, than when you did this specific mod that may contradict an earlier finding.
as a far flung "hey but what if it isnt the choke coz Ive checked it 100 times" then assuming all else what you said is true there is nothing else to check.
Ayrton
PostPosted: 10:50 - 09 Jul 2025    Post subject: Reply with quote
Sounds daft but have you checked the air filter? I spent ages trying to figure out why my scooter wouldn't start and a new filter fixed it Laughing The old one just became too blocked up even though it didn't look too bad.
Farmingstock
PostPosted: 21:08 - 02 Aug 2025    Post subject: Reply with quote
Took the air filter off completely and put my hand over the end of the carb where the air filter would connect and the bike starts much better. Any idea of what the problem could be and how I can fix it?
sickpup
Old Timer
PostPosted: 18:03 - 04 Aug 2025    Post subject: Reply with quote
The auto choke is broken.
Farmingstock
PostPosted: 15:33 - 07 Aug 2025    Post subject: Reply with quote
Bought a new autochoke, however the problem is still there! Auto Choke works as it should!
Think the issue is fuel delivery to the carb, if I blow into the tank or cover the air filter side of the carb while turning it over so more fuel gets sucked in the bike starts fine!
jeffyjeff
PostPosted: 21:19 - 07 Aug 2025    Post subject: Reply with quote
Why do you say that the auto choke works as it should? What you are saying here defies logic. 1. An operational choke will restrict airflow into the venturi throat of the carburetor. Placing your hand over the intake will do nothing, since airflow is already restricted by the choke. Rather than a choke plate, your carburetor probably uses an enrichment valve (most bike carburetors do). Even with a new valve, a blockage in one of the carburetor passages could render the enrichment valve ineffective. 2. Blowing into the tank to aid starting makes no sense. The carburetor float and needle valve will seal the fuel inlet to maintain the prescribed fuel level in the carburetor float bowl. You could blow into the tank until you are blue in the face and still not force a drop of fuel into the carb.
Carburetor disassembly and cleaning is apparently in order.
Farmingstock
PostPosted: 21:46 - 07 Aug 2025    Post subject: Reply with quote
So the autochoke works by lengthening to close and shortening to open, without trying to sound condescending, I have checked this works! I know the autochoke works!
The bike uses a vacuum pump to pump fuel, this is fed by suction on the inlet, when I cover the carb air filter side with my hand it sucks more and lets fuel into the carb! By a process of elimination, my guess is the tank vacuum pump is faulty! Again I know the carb is clean, the autochoke works and the bike starts ok when I know it’s getting fuel to it from the tank with the hand over and more vacuum trick! So my next step to prove my theory as I know the carb is clean and the autochoke works! Is to use a temp tank gravity fed and see if it starts ok, if it does then the problem is 100% the vacuum pump!
jeffyjeff
PostPosted: 23:02 - 07 Aug 2025    Post subject: Reply with quote
OK. Then is it possible that you have an intake vacuum controlled fuel valve with gravity fuel feed to the carburetor? If so, the problem could be the vacuum valve, but odds are that you have a leak in the line between the vacuum valve and the carburetor. You can test by disconnecting the vacuum tube from the carburetor, tape over the nipple on the carb, and apply vacuum to the tube as you crank the motor over.
Your fix might be an inexpensive piece of vacuum tubing.
Farmingstock
PostPosted: 23:39 - 07 Aug 2025    Post subject: Reply with quote
Tried taking the vacuum hose off and there are no leaks in it, can’t hold the brake, throttle tube and vacuum at the same time but will give it a go, with some zip ties on a couple of things!
Will try my method first then try yours to double check things!
If it starts ok with direct feed fuel it is the tank/pump/pipe that is the problem!
that_impulse_guy
PostPosted: 10:12 - 08 Aug 2025    Post subject: Reply with quote
i admire whats going on, but when you consider the original post says the bike starts fine when its hot then you're left wondering if a vacuum fuel tap not getting vacuum can actually be the problem.
bugeye_bob
PostPosted: 12:58 - 08 Aug 2025    Post subject: Reply with quote
Starting it with the petcock on prime would test that.
Farmingstock
PostPosted: 18:05 - 08 Aug 2025    Post subject: Reply with quote
I have tried fuel directly to the carb and its still no better!
When I said in the first post it starts fine when warm, I should have been more specific:
When the bike has been left for any period of time over 30 minutes or so, it will turnover for 20 seconds and not start, with no matter what I do with the throttle on/off/ then all of a sudden it will start after turning it over and over, then once started, I can turn it off instantly (not warm) and it will start fine over and over again until left for a while!
However!
If I take the air filter intake off cover the carb with my fingers and turn it over (fingers wet with fuel) it will start better!
It won’t start with kick start at all until it’s been started with electric start, then it’ll kickstart everytime!
I have checked the autochoke, tried a manual choke, sprayed carb clean around the carb to check for air leaks, checked the vacuum and fuel pipe for leaks, checked the valve clearance, replaced the spark plug and air filter!
Once the bike starts it rides absolutely fine.
Hopefully that clears everything up! But the problem still remains
PostPosted: 18:43 - 08 Aug 2025    Post subject: Reply with quote
Going back to what jeffyjeff said: the "choke" on the carb isn't a choke, it's a fuel enchricher...
If you can start it with a manual choke - i.e. your hand over the intake - then either the pilot circuit or fuel enricher or both are not doing their job properly: it's a carb problem.
Farmingstock
PostPosted: 07:53 - 09 Aug 2025    Post subject: Reply with quote
The carb is clean, the bike ticks over fine, it’s hard to think the pilot jet/circuit has an issue if the low revs are fine, should I just clean again?
PostPosted: 11:35 - 09 Aug 2025    Post subject: Reply with quote
What sort of air filter system does the bike have? Bone stock or something aftermarket?
Farmingstock
PostPosted: 11:43 - 09 Aug 2025    Post subject: Reply with quote
Bog standard, bikes completely stock.
jaffa90
PostPosted: 18:14 - 09 Aug 2025    Post subject: Reply with quote
Have you checked the carb fuel level ?
On very old bikes they had a tickler to raise the level for easier starting from cold and on some newish lawnmowers they have a rubber pressure plunger to pressure the float lower to raise the level with no choke system.
I take it that you are not using the throttle on a cold start with auto choke!
Farmingstock
PostPosted: 18:48 - 09 Aug 2025    Post subject: Reply with quote
It’s a 2006 so not that old really, the carb has a little pump on it that works fine, the float bowl isn’t adjustable it’s just a plastic one with nothing to adjust.
I’ve tried starting all different ways regarding throttle position, but generally don’t touch it.
When the bike does start it ticks over high on choke for 10 seconds or so then drops down, like the choke circuit is working fine.
I fitted a clear fuel filter today to check fuel flow on start up and looks fine.
Just can’t figure it out! Banging my head against the wall!
jeffyjeff
PostPosted: 21:01 - 09 Aug 2025    Post subject: Reply with quote
The odd thing is that the symptoms do not appear to be temperature dependent, and fuel flow to the carburetor is apparently unrestricted. Thinking about it, the carb float bowl should have enough fuel to start the engine and run it for about a minute just on the fuel in the bowl. It behaves almost as if the bowl has run dry and the engine needs to crank for a short period to allow the vacuum valve to pass fuel to the carburetor. Of course, without a leak, it is unlikely that is happening.
Maybe the float bowl has some debris in it that displace some of the volume in the bowl...perhaps from running poor quality fuel. Or possibly the float level is set too low. Or maybe there is a piece of crud lodged between the float and the needle valve, causing the needle to seat when the fuel is at an abnormally low level.
Just some suggestions of things to check. BTW, does the engine oil smell of fuel?
Farmingstock
PostPosted: 20:00 - 11 Aug 2025    Post subject: Reply with quote
Not had chance to take the carb off again to check the float bowl again, but there is no fuel smell in the oil, it takes 21 seconds of turning over no throttle to start! I videoed it just to know how long! But then after that it’ll start instantly
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.22 Sec - Server Load: 1.49 - MySQL Queries: 13 - Page Size: 126.65 Kb
