Leaking petrol from bike
Leoishere25
PostPosted: 19:05 - 13 Sep 2025    Post subject: Leaking petrol from bike Reply with quote
Hi there, I've just bought a Yamimoto 50 bike, it's a year old, been regularly ridden. I filled it up with petrol and it immediately started leaking, quite a lot at first and after about 20 minutes just drip drip. I don't know if anyone has experienced anything similar? The fuel tank says it's half full but have I over filled it? or is there another simple explanation, thanks
PostPosted: 20:01 - 13 Sep 2025    Post subject: Reply with quote
Is the petrol coming from the clear pipe? Can you trace it back to the source?
An overflow pipe might be from a carb (do they bother with EFI on 50cc bikes?) the tank (as in you've over filled it) or the gutter around the tank cap (as in you've spilled some petrol).
to v or not to v
PostPosted: 07:39 - 14 Sep 2025    Post subject: Reply with quote
no its not the clear pipe. you can see the petrol running out in the red circle.
Moto Guzzi V7.
BanditsHigh
Worse than a woman
PostPosted: 09:55 - 14 Sep 2025    Post subject: Reply with quote
There is usually a drain tube from the filler cap to let rain/overfill drain away ... you really need to trace the path of the pipe back to its source ... it it goes up to the tank then it's most likely what I've described (and also earlier in the thread). Thumbs Up
PostPosted: 10:35 - 14 Sep 2025    Post subject: Reply with quote
Its one of these folks.
Do it leak only when running (fuel pump active - preseumed EFi and not carb), or when stationary/off?
https://www.bikingdirect.com/wp-content/uploads/2024/01/Yamimoto-CK50-50cc-Grey-Orange-1.jpg
PostPosted: 11:14 - 14 Sep 2025    Post subject: Reply with quote
Doh! Well done.
PostPosted: 20:35 - 14 Sep 2025    Post subject: Reply with quote
That leak is the bike begging you to burn it and put it out of its misery
Leoishere25
PostPosted: 21:29 - 15 Sep 2025    Post subject: Reply with quote
Thanks all, I've been in touch with the manufacturer and they think it could be due to a leak in the fuel tank itself so going to have a look into that
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.54 - MySQL Queries: 13 - Page Size: 54.24 Kb
