Rear hub stud unscrewed.
Kawasaki Jimbo
PostPosted: 17:07 - 18 Sep 2025    Post subject: Rear hub stud unscrewed. Reply with quote
I’m putting a new chain and sprockets on my 2003 R1. All seemed to be going well until I undid the self-locking nuts from the drive hub to remove the rear sprocket. One of the nuts didn’t release its grip and just unscrewed the whole stud instead. I can’t see any swarf so should I just screw it back in and finish the job? (Seems unlikely knowing my luck.)
https://i.postimg.cc/YS8dMrPm/IMG-1005.png
https://i.postimg.cc/VvZgMKws/IMG_1941.jpg
https://i.postimg.cc/zBj0DJPg/IMG_1942.jpg
BanditsHigh
Worse than a woman
PostPosted: 17:13 - 18 Sep 2025    Post subject: Reply with quote
Yes, maybe chuck for thread lock on it for peace of mind Thumbs Up
PostPosted: 18:08 - 18 Sep 2025    Post subject: Reply with quote
If it was me, I'd lock two nuts on the end of the stud, undo the nylok nut, clean the threads then re-insert the stud with blue loctite and reassemble as normal.
Copycat73
PostPosted: 08:28 - 19 Sep 2025    Post subject: Reply with quote
i would buy new .. they are not that much from fowlers , Bristol.
caveat emptor
Kawasaki Jimbo
PostPosted: 13:37 - 19 Sep 2025    Post subject: Reply with quote
It was the inner thread I was concerned about but the stud went back in without any more drama and the rear sprocket is on.
My new Wemoto chain tool (£24 cheap but their only other offering was a knock-off DID tool) has holes in the press plate that don’t quite align with the rivets so I can’t install the chain’s side plate. Chinese quality control. I’m now considering whether I should drill the tool to try to make it fit, or buy a better tool (though they all seem to be made in China).
BanditsHigh
Worse than a woman
PostPosted: 17:01 - 19 Sep 2025    Post subject: Reply with quote
As mentioned by both stinkwheel and myself, you need to put threadlock on it ... vibration will not undo the lock nut, but it can make the stud work its way out ... I speak from experience Thumbs Up
Fizzer Thou
PostPosted: 15:28 - 20 Sep 2025    Post subject: Reply with quote
I have a Motion-Pro chain tool and it has been the best tool for so many types of chain,from a cam chain soft link on a KTM enduro and the chains with soft links on all of my bikes,even the XR400.
So as to use the bits that I have in the kit,the anvil was positioned behind the pin and the open end of the tool was used to push on the outer plate.
Always have a 'Plan B'
Kawasaki Jimbo
PostPosted: 21:34 - 20 Sep 2025    Post subject: Reply with quote
I blue Loctite’d it as suggested although the service manual doesn’t require that, but I found an on-line discussion suggesting the torque setting given in the service manual is too high.
https://www.600riders.com/threads/rear-sprocket-carrier-failed-studs.53487/
That, combined with those initially lubricated threads and the age-hardened Nyloc nuts convinced me to tighten using “feel” (and I’ve poo-poohed that advice in the past but having used torque wrenches for some time now I think I have developed “feel”). That translated to 70Nm instead of 100, but I’ll check after a few miles.
I’m sending the chain tool back to Wemoto for a refund and I’ve stumped up for an authentic DID chain tool from M&P. The Wemoto’s side-plate insertion plate has holes about 2mm too far apart when compared to the chain rivets, as shown alongside the rivet “potato-prints” in the photos.
https://i.postimg.cc/x1SqNZ4G/IMG-1944.jpg
https://i.postimg.cc/6QMQSp5z/IMG-1946.jpg
Pete.
PostPosted: 09:10 - 21 Sep 2025    Post subject: Reply with quote
Honda Blackbird specifies 108NM
'busa and GSXR1000 specify 60nm
I'd replace the stud with permanent threadlock because they are not intended for removal, and torque the nut to the factory spec with no threadlock.
a.k.a 'Geri'
Kawasaki Jimbo
PostPosted: 18:40 - 29 Sep 2025    Post subject: Reply with quote
Thanks everyone. In the end I torqued the drive hub nuts to the specified 100Nm as advised.
Wemoto refunded me immediately and the DID tool did a great job, as it should at the price. I used digital calipers to check the dimensions of the assembled link and rivets. The old chain was just beyond the “stretch” limit.
In hindsight I should have done this work a long time ago. The bike had had bad vibrations and was chain-slapping at low speeds when slipping the clutch. Now it feels very smooth. The chain slapping is much reduced. I’m not sure whether to just accept what’s still there and ride around it, or adjust the chain, or open up the clutch and check whether the anti-judder spring plate is the right way round. I believe it is dished but I don’t think I understood the importance of that when I installed new clutch plates earlier this year.
The bike had two new tyres a few weeks ago so with the clutch, new chain and sprockets it is better than it’s been in a long time, and feels like it.
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.51 - MySQL Queries: 13 - Page Size: 67.46 Kb
