Honda C110 clutch
Bossboy
PostPosted: 20:59 - 12 Nov 2025    Post subject: Honda C110 clutch Reply with quote
Hi all,
I have the complete unit, it’s been in store for years
I want to take it apart to renew the plates, I guess they are probably stuck, I need to know from anyone who has done this, how many plates friction etc, so I can order
I have looked at drawings but it’s misleading, it only shows a friction plate and a metal plate ?
Any help much appreciated
PostPosted: 23:38 - 12 Nov 2025    Post subject: Reply with quote
You done one of that type of clutch before?
Pretty sure it's a C90 style centrefugal clutch on those? They are a fair bit more complex than a standard manual one. If you don't have a workshop manual, I would strongly suggest getting one, there are linkages, cams, springs and ball bearings to remove before you get to the clutch pack itself which all need to be put back in the right place on reassembly.
Remember to clean out the centefugal oil filter while you're in there.
The C90 ones have three friction plates, 2 of one shape and one of another and two steel plates. I'd imagine the C110 is similar.
Bossboy
PostPosted: 10:48 - 13 Nov 2025    Post subject: C110 clutch Reply with quote
Have to confess it’s the same clutch, I got a complete new basket way back from the states, I could not find enough info, I want to oil and put new plates in before I put back in engine.
I did find info but not enough detailed info on clutch assembly
Can I ask, what workshop manual do you recommend please ?
Thanks for your help
sickpup
Old Timer
PostPosted: 12:39 - 13 Nov 2025    Post subject: Reply with quote
Its been over 30 years since I rebuilt one of those on a C90 but I never needed a manual, they're very simple.
If its in a bike, lay it on its side, makes things a lot easier. Seem to remember there are 3 bent metal levers on top in the centre of the clutch pack, these are the bits that are easier to fit with the bike on its side.
PostPosted: 13:30 - 13 Nov 2025    Post subject: Reply with quote
Here you go:
https://youtu.be/4uc6Qs4FjYI?si=MJ4SuBx6ZiSlOSLO
Which reminds me, you NEED JIS screwdrivers. The centrefugal filter cover is held on with three JIS countersunk screws, they can be tight and you WILL strip the heads if you try to use a phillips or posidrive. They can be tight. Vessel make good ones. They also do ones with an integral impact driver function so you can smack the end of the driver with a hammer to loosen the screw.
It appears you'll also need a castle nut spanner for the centre nut.
Bossboy
PostPosted: 21:06 - 13 Nov 2025    Post subject: Reply with quote
Hello, it’s not a c90 it’s a C110 manual clutch, this is my problem, all the info is for a ct110 which is semi auto
Bossboy
PostPosted: 21:08 - 13 Nov 2025    Post subject: Reply with quote
[quote="stinkwheel"]Here you go:
It appears you'll also need a castle nut spanner for the centre nut.[/quote
This is my problem, all info is for a ct110
My bike is a C110. Manual clutch, 4 speed gearbox
PostPosted: 22:34 - 13 Nov 2025    Post subject: Reply with quote
What year is it? The parts fisches I've found for C110 so far all show the semi-auto clutch with the three ball actuator cam.
Bossboy
PostPosted: 21:02 - 15 Nov 2025    Post subject: Reply with quote
It’s 1964 manual clutch 4 speed, thanks
PostPosted: 22:33 - 15 Nov 2025    Post subject: Reply with quote
Found this:
https://www.icenicam.org.uk/library/Honda/C100_-_C102_-_C110_-_C114_service_manual_1963-01.pdf
Page 18. Looks like the clutch pack itself is the same as the early C90s. Two steel plates, three friction plates but two of one type, one of a different type.
Bossboy
PostPosted: 11:12 - 16 Nov 2025    Post subject: Reply with quote
stinkwheel wrote:
Found this:
Many many thanks
When I took the original clutch to pieces there was only 1 friction plate and 2 metal plates, acootding to the manual there should be 2 friction plates
Getting somewhere at last
Bossboy
PostPosted: 20:49 - 16 Nov 2025    Post subject: Reply with quote
stinkwheel wrote:
Found this:
Hello,
Quick recap, I nay found this reading further on in the manual I downloaded from your link, thank you
It says clutch can be lifted out in following order :
Clutch plain plate
Clutch friction plate
Clutch pressure plate
So riginal clutch had right fittings but was totally stuck
I now can order and replace
Thanks again for your help
cheppaul
PostPosted: 10:01 - 22 Nov 2025    Post subject: Reply with quote
Thanks for sharing the link to the PDF manual. It’s exactly what I need right now. But apparently something happened with my laptop’s software, and my PDFs stopped opening. I converted them to another format using a tool from an article https://www.hrfuture.net/talent-management/training-development/create-pdf-document-with-extreme-ease-with-pdf-guru/ that included its review and useful tips. At the moment, I can at least access the important documents until I resolve this issue. This might be useful for someone else as well.
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 79.8 Kb
