Cleaning Stainless Exhaust - 2010 600 Hornet
Zen Dog
PostPosted: 11:34 - 15 Mar 2026    Post subject: Cleaning Stainless Exhaust - 2010 600 Hornet Reply with quote
When I got my Hornet it had an aftermarket exhaust fitted, but I got the original exhaust with it too. I thought I'd have a go at cleaning it up. Bought a kit from "Dr. Downpipe", came with a spray bottle of acid-etch cleaner, a tube of metal polish, 2 scourers and 2 microfiber cloths. No gloves though. Anyway I thought I'd take some pics of the process.
First set of pics, the exhaust as I got it. Some minor pitting around the header inlets, but mainly its lots of surface rust, scaling and general grunge.
Zen Dog
PostPosted: 15:28 - 15 Mar 2026    Post subject: Stage 1 - Acid Etch Reply with quote
So I gave it a wash with soap and water, then tried out the acid-etch stuff. Spray it on, give it a bit of an agitate with the scouring pad, rinse it off. I did it a couple of times. The effect was pretty dramatic, but mostly it's made the already bright bits brighter. There's still lots of corrosion on the welds and in all the little grooves. Even the nice bits have a sort of satin finish. Still, for about 15 minutes work, no complaints.
Zen Dog
PostPosted: 15:54 - 15 Mar 2026    Post subject: Stage 2 - Brass Brushes Reply with quote
It didn't look at all ready for metal polish to me at this point, so I got out the brass brushes and brush tips for the dremel, and sacrificed a load of them to the God of Shiny Exhausts. Also nearly sacrificed an eye when a strand of high-velocity brass managed to find it's way around my glasses and safety squint.
I spent a few hours on this stage, but I think it was worth it. I'm not sure how well it comes out in the photos but the dremel removed basically all the remaining surface corrosion, out of all the little nooks and crannies. There was now nothing rusty or brown left, and the whole surface has a sort of satin finish, with the inlets having a dark discolouration.
Time for metal polish next, but I'm expecting that to take more hours.
to v or not to v
PostPosted: 22:17 - 15 Mar 2026    Post subject: Reply with quote
ive heard Harpic 10x bleach applied for about 15 minutes then washed off works wonders.
Moto Guzzi V7.
PostPosted: 08:14 - 16 Mar 2026    Post subject: Reply with quote
It's not really a "bleach" in the traditional sense. It's based on hydrochloric acid rather than hypochlorite bleach like most bleaches. So effectively an acid gel.
So yes, it works well to remove corrosion, also works on rusty mild steel pipes. It's also perfectly capable of eating a hole in it if you leave it on too long.
Zen Dog
PostPosted: 10:26 - 16 Mar 2026    Post subject: Reply with quote
Yeah, I'd heard of that too. But apparently it can be a bit difficult to get hold of, and I thought it was probably overkill in this case. Do you think you could create a race exhaust by taking a normal one and then dissolving it with Harpic until it's paper thin? Thinking
PostPosted: 11:06 - 16 Mar 2026    Post subject: Reply with quote
The acid based bog cleaners/descalers are quite common and tend to come in ominous black bottles. I'm pretty sure its safe on (good quality) stainless but less so on mild steel/rust. I've used it with scotchbrite or possibly wire wool in the past to good effect.
to v or not to v
PostPosted: 05:37 - 04 Apr 2026    Post subject: Reply with quote
so have you sorted the pipes, did you try bleach?
Moto Guzzi V7.
Zen Dog
PostPosted: 20:57 - 07 May 2026    Post subject: Reply with quote
I'm still polishing it. It's working, one of the downpipes is now mirror shiny. But it takes forever, even with a dremel supplying the elbow grease. And it's really boring, so I've just got it all setup in my shed, and I go out there and spend 10 minutes doing a bit more when I have the time. I'm expecting this step to take about 6 months at the current rate...
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 62.35 Kb
