| Author |
| cresad |
 cresad Nova Slayer
| Back to top |
| MarJay |
 MarJay But it's British!
| Back to top |
| A100man |
 A100man World Chat Champion
 Posted: 15:50 - 17 Mar 2026 Post subject: Re: Engine cut out problem |
| cresad wrote: | I've also disconected the – flasher relay , horns , neutral switch , clutch switched , the new headlight relays that I'd put on amd then the whole new wiring all with the same result blown fuse.
Ah, recent - why new relays? ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600, Skorpion, GT 250 |
| Back to top |
| WD Forte |
 WD Forte World Chat Champion
| Back to top |
| A100man |
 Posted: 18:08 - 17 Mar 2026 Post subject: |
| WD Forte wrote: | a cable near the headstock which supplied power to the solenoid had broken and for me, it was a quick fix. |
This happened to my brothers R100 beemer, and since Ze Germans didn't think it appropriate to fuse the cicuit it smoked and melted half the loom.  ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| Back to top |
| stinkwheel |
 Posted: 18:14 - 17 Mar 2026 Post subject: |
I have a wee trick I sometimes use to find an intermittant short. If you fit a bulb holder with two flying leads with spade connectors on, you can install it where the blowing fuse goes.
Since you now have a load in there, it's no longer a short circuit. The bulb will light instead of the fuse blowing. Then start disconnecting stuff methodically until it goes out/dims and you've located the short. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Back to top |
| cresad |
 cresad Nova Slayer
| Back to top |
| stinkwheel |
 Posted: 22:30 - 17 Mar 2026 Post subject: |
| cresad wrote: |
Just ordered a 20a multimeter to try a similar thing to using a bulb
Thanks , Adam |
If it's a dead short, it'll just pop the meter anyway. If it doesn't, it'll cook the wiring The flasher wiring isn't thick enough to cope with 20A.
If you want to use a meter to do that, set it to measure resistance, take out the fuse, put one lead in the fuse holder and connect the other to earth. When there's a short it will read a very low or zero resistance. When you've moved/removed the part where the short is, the resistance will increase. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Back to top |
| ZebraDriver |
 ZebraDriver Scooby Slapper
| Back to top |
| stinkwheel |
| Back to top |
| Copycat73 |
 Copycat73 World Chat Champion
| Back to top |
| jeffyjeff |
 jeffyjeff World Chat Champion
| Back to top |
| cresad |
 cresad Nova Slayer
| Back to top |
