1995 Yamaha tenere xtz750
Ehud
PostPosted: 17:24 - 26 Mar 2026    Post subject: 1995 Yamaha tenere xtz750 Reply with quote
Hello. I have a 1995 Yamaha tenere xtz750
It started with having trouble holding 3000 RPM with full choke right after starting. The RPM would begin to drop until it was about to stall unless you gave it a little throttle. Eventually it got to the point where it won’t start at all anymore.
I have now removed the carburetor and cleaned it, and it doesn’t look like there’s anything wrong with it. I have replaced the spark plugs, ignition coil, ignition cables, and the CDI box. I have checked that it gets both spark and fuel. I’m starting to give up because I can’t see what the problem is.
It doesn’t fire at all or show any sign that the fuel is igniting. It doesn’t backfire or shoot anything back into the carburetors either.
Help, please. Thank you
PostPosted: 22:14 - 26 Mar 2026    Post subject: Re: 1995 Yamaha tenere xtz750 Reply with quote
Long shot - sure you reconnected the plug leads onto the correct cylinder?
jaffa90
PostPosted: 01:03 - 27 Mar 2026    Post subject: Reply with quote
Are the choke valve plungers free and working to let more fuel through?
Also starter spray should tell you if fuel mixture is not getting through.
sickpup
Old Timer
PostPosted: 12:27 - 08 Apr 2026    Post subject: Reply with quote
A lot of Yamaha's of this era including your bike use a vacuum fuel pump which always fails. The diaphragm starts leaking and they fail.
The cost of this from Yamaha is over £300. Luckily rebuild kits are available for about £30 on Ebay or new pattern fuel pumps are available off Ebay for £18-£40.
Never liked these fuels pumps, seen too many of them fail.
temeluchus
PostPosted: 03:17 - 18 Apr 2026    Post subject: Reply with quote
Had the exact pump fail on me on a same era Diversion.
I replaced it with a later model divvy electric pump, used a relay energised by the ignition switch.
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.13 - MySQL Queries: 13 - Page Size: 43.78 Kb
