 Ehud L Plate Warrior
 A100man World Chat Champion
 Posted: 22:14 - 26 Mar 2026 Post subject: Re: 1995 Yamaha tenere xtz750 |
| Ehud wrote: | Hello. I have a 1995 Yamaha tenere xtz750
It started with having trouble holding 3000 RPM with full choke right after starting. The RPM would begin to drop until it was about to stall unless you gave it a little throttle. Eventually it got to the point where it won’t start at all anymore.
I have now removed the carburetor and cleaned it, and it doesn’t look like there’s anything wrong with it. I have replaced the spark plugs, ignition coil, ignition cables, and the CDI box. I have checked that it gets both spark and fuel. I’m starting to give up because I can’t see what the problem is.
It doesn’t fire at all or show any sign that the fuel is igniting. It doesn’t backfire or shoot anything back into the carburetors either.
Help, please. Thank you |
Long shot - sure you reconnected the plug leads onto the correct cylinder? ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600, Skorpion, GT 250 |
 jaffa90 World Chat Champion
 sickpup Old Timer
