Ybr 125 intermittent starting issues
Coops1990
PostPosted: 08:58 - 29 Apr 2026    Post subject: Ybr 125 intermittent starting issues Reply with quote
I have a 2006 ybr 125 that runs fine for a few weeks then wont start, battery fully charged, strong spark and new spark plug fresh fuel carb is clean. It turns over but doesn't fire.
Anyone have any ideas on the issue?[/quote]
PostPosted: 11:50 - 29 Apr 2026    Post subject: Reply with quote
I started to answer assuming FI then realised it's the older carb model.
I'd pull the plug and check for a spark and if it's wet after
cranking/not starting for a while.
Coops1990
PostPosted: 12:45 - 29 Apr 2026    Post subject: Reply with quote
It is wet after cranking/not starting should it not be?
PostPosted: 17:24 - 29 Apr 2026    Post subject: Reply with quote
Wet plug suggests you're getting fuel and no spark.
If you hold the plug against the cylinder head and press the starter
you should see it spark as the engine spins.
IF not, investigate why.
the diagram I have shows no sidestand switch to feck things up
so I'd check for power to the ECU type thing first
It's not an ECU of the fuel injection type but more of an ignition
control box with a relay to dim the headlight when starting.
There is also a pulser on the stator which sends pulses to the ecu
so if that fails it wont go.
Kawasaki Jimbo
PostPosted: 18:24 - 29 Apr 2026    Post subject: Reply with quote
There’s something missing here. Is it, “Ran for a few weeks, now won’t start”, or ‘Runs, then turns over but won’t start, then runs again’? Is there a long lay-off between running and then not starting? What happens in the interim?
jaffa90
PostPosted: 19:13 - 29 Apr 2026    Post subject: Reply with quote
Also are you using the kick start or electric start and are you using the fuel tap before and after riding ??????
Coops1990
PostPosted: 19:26 - 29 Apr 2026    Post subject: Reply with quote
I think i may have found the issue with the ignition switch i am going to replace and see if this helps - there was no spark earlier but every other time I have checked there has been.
It depends i use the bike 3 or 4 times a week and I could be riding home stop at the shop come back out and it wont start.
Fuel tap is used before and after.
Ayrton
PostPosted: 09:54 - 30 Apr 2026    Post subject: Reply with quote
I had the same issue on my YBR and it turned out to be the ignition switch. The contacts inside get worn and then you end up with this intermittent starting issue. Spraying some contact cleaner down the keyhole helped for a little bit.
Mine was the later fuel injected model though.
PostPosted: 18:09 - 30 Apr 2026    Post subject: Reply with quote
Checking the ignition switch is a good idea,could well be that
The diagram shows 4 wires:
Red: power in from battery/fuse
Brown: power out to the bikes electrical systems
Black: ground
Black/white to 'ecu'
I've swapped them on later FI ybrs and the security screws may be
a hassle unless someone has been in there before
twowheelwonde...
PostPosted: 17:56 - 20 Aug 2026    Post subject: Reply with quote
Worth catching it in the act before you buy the switch. Next dead spell, back-probe the brown wire off the ignition switch with the key on. Power there but no spark points downstream to the pulser or CDI, not the switch. Intermittent faults love to get blamed on the last part you swapped.
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.28 - MySQL Queries: 13 - Page Size: 61.35 Kb
