YBR ESD Power Loss
jeffyjeff
PostPosted: 19:09 - 12 Jun 2026    Post subject: YBR ESD Power Loss Reply with quote
12 June 2026
https://live.staticflickr.com/65535/54575078048_e81c6eccd1.jpg
2015 YBR125 ESD purchased new (old dealer stock) in 2019, 23100 km on the odometer. The ESD model has a carbureted engine (Mikuni BS25) sold primarily, dare I say, in the third world. The Pakistani YBRs are ESD models as are YBRs sold in Central and South America, to my knowledge. No electro-mechanical issues other than a TPS replaced at 20800 km. The bike is well-maintained (over-maintained to be honest) and runs better than it did when new…up until yesterday.
I was riding on Moroccan highway N6. It was 35 degrees C, and I was about 60 km into my trip and riding at 80 kph. Several km after turning the fuel tap to "reserve", the bike suddenly lost all power. To wit: instantaneous loss of throttle response and uncontrolled deceleration. After slowing to around 60 kph, the power magically returned. I kept riding, and after an uneventful 10 km, I started to think, "maybe that was just a little hiccup, nothing to be too concerned over." Then it happened again. No hesitation, no stumbling, nothing to indicate that the carburetor was starving for fuel; just an immediate loss of throttle and resulting deceleration. I thought "ignition power loss," but then I noticed my high-beam indicator illuminated even as the bike was in the state of power loss. As I slowed, the power immediately returned when I downshifted from 5th to 4th. Well that's odd. The glitch recurred 3 times over a 12 km stretch, and each time I was able to recover power by downshifting, except the last time required two downshifts to third before power returned. Six uneventful kilometers to the petrol station, where I filled the tank. I rode twenty-eight kilometers to home (after filling up) without any recurrence whatsoever. I had the fuel tap on reserve most of the way to see if that might be a contributing factor.
The instantaneous onset of power loss suggests ignition system failure, but it is odd that downshifting the transmission could bring about such an immediate return of power; coincidence? Maybe, but I have never experienced a repeatable coincidence like that.
I would normally dismiss the fuel system as the cause due to the split-second onset of symptoms, but it is hard to ignore that the problem manifested shortly after turning to "reserve", and only occurred when the engine was drawing fuel on the reserve standpipe.
I'm in Morocco until September. When I return, I'll probably have a spare fuel cock and an extra ignition coil in my bag. In the meantime, I intend to keep the fuel tap in the reserve position to see if that makes a difference. I checked the fuel filter (part of the petcock) and it was unobstructed. Once I run the tank down to less than 5 liters, maybe I'll drain it and remove/inspect the petcock. Specifically, I will be looking for a crack, hole, or damage to the shorter standpipe.
If anyone can suggest actions or observations I might make in the meantime, I'm all ears.
Thanks for reading.
PostPosted: 20:51 - 12 Jun 2026    Post subject: Reply with quote
Well, a fuel tap obstruction seems possible.
Or even vapour locking in that kind of heat with a prolonged ride (fuel in the float bowl boiling). Especially with a small amount of fuel in the tank to get heated up.
jeffyjeff
PostPosted: 19:36 - 17 Jun 2026    Post subject: Reply with quote
stinkwheel wrote:
...Or even vapour locking in that kind of heat with a prolonged ride (fuel in the float bowl boiling). Especially with a small amount of fuel in the tank to get heated up.
Thanks for that idea. I had not considered vapor lock, last week the temperature around here got up into the low 40's and the bike performed normally (albeit with a little more fuel in the tank.) I spent part of 1976 in Arizona, and vapor lock was a common occurrence on some of the military vehicles we had in our fleet. Similar to fuel starvation, vapor lock would make the engine falter before stalling out altogether.
I did drain the carburetor, and found 5 or six small (<1mm) water droplets in the fuel. Morocco had an unusually wet winter this year. I'm wondering if maybe some water momentarily obstructed the main jet, and when I down-shifted the increase in vacuum caused the water to pass. Probably a little far fetched as theories go, but worthy of further investigation, I suppose. I intend to drain the tank, or at least measure rate of flow on the fuel tap normal and reserve positions. I will carefully inspect the fuel for water inclusion, especially from the reserve tap. Being in a rural area here, there is no fuel line available in the nearest village, and that has delayed me so far.
I also took a peek under the tank where the coil resides. It is covered in dust and the mounting bolts look a little rusty. I'll probably remove it for a good physical inspection and clean up of contacts and mounting points. It also occurred to me to inspect the magnetic pickup and circuit connections to the ecm.
This is a relatively remote area, and I really don't want to risk the bike taking a big shit miles from nowhere. Once i poke around a little bit, I'll feel a little better about venturing further afield. Hopefully I'll find something out of the ordinary.
jeffyjeff
PostPosted: 20:52 - 22 Jun 2026    Post subject: Reply with quote
Yesterday I drained 1.5 litres out of the tank on both fuel tap positions: 78.9 seconds on the run tap, and 78.4 seconds on the reserve tap; so there is no apparent obstruction in the petcock reserve position. Also, no evidence of water in the fuel whatsoever.
I checked the side stand switch circuit for continuity. Seems that a momentary open in that circuit could result in the symptoms I was experiencing without generating a check engine light. Especially considering the downshifts brought the engine back to life. Maybe it wasn't the downshift, but the clutch action (clutch switch closed) that caused the ignition circuit to reactivate. Possible, but does not explain why the engine kept running after the clutch was reengaged. I should keep a paper clip on the bike in order to bypass the side stand switch if need be. I did not trace the wiring further than the side stand switch and pigtail, so if the problem lies further inside the wiring loom the paper clip idea won't work. I do not intend to dissect the wiring harness until I'm more convinced that the problem lies there. In the meantime, I'll keep poking around looking for abnormality.
Upon removal of the side cover, I did notice that a wire for the carburetor heater circuit had come loose from the thermo sensor, but that is totally independent of the ecu and the ignition circuit.
PostPosted: 11:46 - 01 Jul 2026    Post subject: Reply with quote
Might be fuel might not.
Member the YBR that went from Bristol to Stornoway and back in a wet cold winter and got with 24 miles from home and suddenly stopped?
it started again then stopped but had to be shipped the last few miles home just in case
It was the EFI model and the fault code said 'bad coil' but that was bollocks
It was oxidised contacts on the regulator. Once they were
cleaned it ran just fine again.
the point?
check/clean electrical connections and grounds from time to time
but especially if experiencing intermittent problems
Also the side stand switches on YBRs have been known to cause problems and can easily be by passed if suspect
jeffyjeff
PostPosted: 22:16 - 02 Jul 2026    Post subject: Reply with quote
So I took the bike out on my local test route last week, and the sudden no-power glitch manifested 4 times in 40 km under very similar environmental conditions. It happened with the fuel tap in both run and reserve positions, and in each case the power returned before I could even react; so there are two more data points. I decided to dive deeper into the ignition system, and was surprised at the apparent condition of the wiring upon removal of the fuel tank. Much of the harness was spotted with a kind of furry discoloration; resembling mold growth. Some of the exposed wire insulation also had dark spots. I cleaned up the harness with a damp rag and compressed air, and inspected the terminals at the accessible connectors, including the ECU and ignition coil. I removed the coil and cleaned up the spade terminal and mounting points with 400 grit sandpaper, then reinstalled and checked the spark.
I was surprised to observe a really weak spark. It was indeed a blue spark, but it was really small, a micro-spark that appeared to dance around the spark plug center electrode. I removed the coil once again and checked primary and secondary winding resistance against the manual specs.
My coil measured 0.9 ohms on the primary, and 7.84 k ohms on the secondary.
https://live.staticflickr.com/65535/55371031618_cd48e2f3c2_c.jpg
My coil has a single spade, like those on the 2005-06 YBRs and all XT models. As stated earlier, mine is a 2015 YBR ESD model, an orphan (at least in terms of available technical information), so I'm really not sure if my readings are out of spec or not.
On a hunch, I went down to my local hardware guy, who sold me a Chinese coil for a Honda GB125 (less than 5 quid!) that matched my OE coil dimensions exactly. It also matched my OE coil ohm readings exactly. I mounted it and found, unsurprisingly, no change in my weak spark condition.
Then I remembered that last year I had replaced the spark plug. My YBR takes an NGK CR6HSA spark plug. Last year, I found a set of four at an attractive price off Ebay. Oddly, they came in a Honda branded box (probably for a Honda inline four of some sort), but I really wasn't concerned about that much at the time.
https://live.staticflickr.com/65535/55370983643_3482b79398.jpg
I checked the spark on a used OE NGK plug and voila! The spark strength returned to about 80% of what I expected. I reassembled the motorcycle, and today I took it for a 60 km test ride with no recurrence of the issue.
So now my suspicions are focused on the spark plug. Perhaps I unintentionally installed a resistor type spark plug into a resistor type spark plug cap. Or perhaps I unknowingly obtained counterfeit NGK spark plugs that do not perform up to standard. Maybe both.
At any rate, that is where things stand today. Time will tell if the abnormal operation has been repaired permanently or temporarily.
PostPosted: 13:14 - 03 Jul 2026    Post subject: Reply with quote
Hopefully its fixed
the coil specs on your bike especially the primary suggest CDI ignition to me so you could probably swap out all manner of cheap GY6 coils an stuff to keep it running
Re the plug cap
The early CDI type CXs used resistor plug caps and they were notorious for rotting out internally so it if occurs again it's maybe worth checking
jeffyjeff
PostPosted: 13:41 - 03 Jul 2026    Post subject: Reply with quote
WD Forte wrote:
....Re the plug cap..The early CDI type CXs used resistor plug caps and they were notorious for rotting out internally so it if occurs again it's maybe worth checking
Good to know, thanks. Haynes says the plug cap is 5k ohms. I tried to measure but the reading was all over the place. Right now, I'm using the cap that came fitted to the GB125 coil. It's a bit of a tight fit due to the angle that the lead connects, but useable. Interesting to learn that some OE plug caps have a finite service life. Maybe that was a contributing factor. Cheers.
twowheelwonde...
PostPosted: 08:27 - 21 Aug 2026    Post subject: Reply with quote
That furry green on the harness is copper corroding under the insulation, which gives exactly this kind of intermittent high resistance. Instant recovery with no light points at a connector or a safety switch, not fuelling. Worth a wiggle test with it running, and clean the side stand and clutch switches and the main earth.
jeffyjeff
PostPosted: 15:04 - 25 Sep 2026    Post subject: Reply with quote
UPDATE 25 SEP 26: I now have ridden the bike 1361 km since the power loss incident without recurrence. I recently performed the 24000 km service, which includes a valve lash check and adjust. Valve lash was within Yamaha specification. I opened the petcock to drain the tank, then tried to invert the tank to remove all remaining fuel. Unfortunately, the steel cup (with the fuel nozzle restrictor hole) prevented the unusable volume from completely draining out. I could have removed the petcock but was not inclined to do so. Peering inside with a torch, I did not find any debris in the tank. This whole ordeal has made me hypersensitive to consistent smoothness of engine operation, and I have experienced an occasional hiccup that, prior to June 12, I would not have given a second thought. These instances are rare, however, the last one occurring 540 km ago. I am inclined to believe that the coil and spark plug change has done more to alleviate the condition than anything else I have done. The bike is running great under some fairly extreme weather conditions. In the past month, the thermometer has reached 46C in my area, and I have ridden frequently in temperatures up to 42C after filling the crankcase with Shell Helix 20W-50.
sickpup
Old Timer
PostPosted: 07:19 - 27 Sep 2026    Post subject: Reply with quote
CR6HSA plugs are a resistor type plug, it's what the R in the name means.
jeffyjeff
PostPosted: 16:22 - 27 Sep 2026    Post subject: Reply with quote
Thank you. Can you comment on what the other letter designations stand for?
jaffa90
PostPosted: 19:33 - 27 Sep 2026    Post subject: Reply with quote
Google states,
Code BreakdownC: Specifies a 10 mm thread diameter with a 1.0 mm pitch, requiring a 16 mm hex wrench/socket to tighten.R: Indicates a built-in 5 k-Ohm resistor (radio muffled) used to suppress electrical and radio frequency interference (RFI).6: Represents the heat range index (on NGK's scale, lower numbers are hotter and higher numbers are colder, making 6 a medium-hot baseline typical for smaller 4-stroke engines).H: Denotes a 12.7 mm (1/2 inch) thread reach/length, categorized as a short base.S: Stands for a standard copper core center electrode.A: Signifies a special design or non-standard tip configuration differing from base models.
jeffyjeff
PostPosted: 23:44 - 27 Sep 2026    Post subject: Reply with quote
This is very informative, thank you. I find it interesting that Yamaha would specify both a spark plug cap with 5 k-ohms resistance and a spark plug with 5 k-ohms resistance. Clearly they have. I wonder why.
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.1 - MySQL Queries: 13 - Page Size: 91.08 Kb
