2002 Honda Hornet (PC36) 600cc - Metalic Ticking
deakmark
PostPosted: 14:31 - 23 Jun 2026    Post subject: 2002 Honda Hornet (PC36) 600cc - Metalic Ticking Reply with quote
Hi everyone,
I come here to ask some suggestion about my issue which is the following:
Upon starting the engine a audiable metalic ticking can be heard from the right side of the motorbike, which stay the same even at cold and after it warmed up. I attached two video maybe it can be heard there (sorry for the quallity)
The ticking as I heard match the RPM and can be heard around 3.500 RPM. As of when was the last valve clearance was I don't know, sadly.
Anybody has any guess what it can be?
dma
PostPosted: 15:18 - 23 Jun 2026    Post subject: Reply with quote
I mean, you're having to strain to hear that. It's probably a bit of camchain rattle. It's an early 2000s Honda, I'd be surprised if you did NOT get any camchain rattle.
It'll be that the Camchain tensioner is on it's way out. I suspect you'll be able to buy and fit an OEM replacement for not loads of money.
https://www.fowlersparts.co.uk/parts/view/14520MBZD01
Or, you can fit a manual one, but I don't really like them, and I'd rather have an OEM automatic one where possible, especially if they work for quite a while before failing.
deakmark
PostPosted: 14:33 - 06 Jul 2026    Post subject: Reply with quote
Heeey,
Sorry for replaying this late things got busy around me. Thank you for the suggestion I will definitely check it. About its noise, sorry. I made the video after an hour ride which after it become less noisy while cold.
I took another video while the engine was cold and immediately after I started her. Its the most audiable around 0:18-0:22
dma
PostPosted: 16:26 - 06 Jul 2026    Post subject: Reply with quote
If it gets quieter as it warms up, it's camchain. I'm not even going to bother watching the second video.
If you waited this long to investigate it, it can't be that serious. Fix the camchain tensioner and you'll be fine.
twowheelwonde...
PostPosted: 12:59 - 02 Sep 2026    Post subject: Reply with quote
Cam chain rattle usually changes with temperature and revs, so a tick that stays identical cold and hot and tracks rpm points more at valve clearances or a small exhaust leak at the header. A feeler gauge check before buying a tensioner might save you the part.
A100man
PostPosted: 18:11 - 02 Sep 2026    Post subject: Reply with quote
I'm curious - what's your background and where are you based, bikes owned etc..?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.32 - MySQL Queries: 14 - Page Size: 49.08 Kb
