| ilovens125f's |
 ilovens125f's Renault 5 Driver
| Valentino Mossy |
 Valentino Mossy World Chat Champion
| Kickstart |
 Kickstart The Oracle
| Ian (GPX) |
 Ian (GPX) Brolly Dolly
| Valentino Mossy |
| Ian (GPX) |
 Posted: 18:42 - 20 Feb 2004 Post subject: |
Richard,
Yes, you should get them, Post Office said 2 - 3 days, so with luck Monday the latest.
Bits of the bike, yes I got a few items left, like Radiator, carbs, wheels + tyres, 2-stroke oil bottle and sender, clocks (NS125F), forks, and rear swinging arm, wiring harness, and some other bits. |
| Valentino Mossy |
There is a gap of 227 days between these two posts... |
| tominleeds200... |
 tominleeds200... Derestricted Danger
| Keith |
 Keith World Chat Champion
| Kickstart |
| Valentino Mossy |
| tominleeds200... |
| Ste |
 Ste Not Work Safe
| tominleeds200... |
| tominleeds200... |
| Robby |
 Robby Dirty Old Man
| Kickstart |
 Posted: 13:14 - 05 Oct 2004 Post subject: |
If there is metal there then it has come from somewhere. Chances are that it is the piston, with a ring failing. Next most likely would be the circlips that hold the piston onto the gudgeon pin. Next up would be a big end bearing or main bearing that has failed in style.
Whichever it is you will need to remove the barrel and have a look. Once the barrel is off you can check the piston properly (and check the condition of the barrel) and also feel for vertical play in the con rod.
| tominleeds200... |
| tominleeds200... |
| Valentino Mossy |
| tominleeds200... |
The last post was made 22 years, 45 days ago. Instead of replying here, would creating a new thread be more useful? |
