Dead Hornet
jay12329
Dr. Evil
PostPosted: 21:05 - 08 Nov 2004    Post subject: Dead Hornet Reply with quote
Went to start my Hornet 6 last night after it had sat in the garrage for about 10 days. The starter would turn the engine but not enough for it to fire, tried a few more times untill all i got from the starter was that horible clicking sound. I assume my alarm has saucked the life out of my battery.
I got the battery charged, starter motor now turns the engine but it still wont start, the first time it sounded like it was going to but didnt. Now when i press the starter button i can hear the starter and engine turning but no hint of combustion.
The bike had been sat for around 10 days on a paddock stand in the garage until i got it out last night.
Any sugestions would be appreciated.
Thanks
J
Robby
Dirty Old Man
PostPosted: 21:22 - 08 Nov 2004    Post subject: Reply with quote
Is the fuel turned on?
Is it sparking?
If you keep trying it will probably catch eventually.
neon
PostPosted: 21:31 - 08 Nov 2004    Post subject: Reply with quote
pick the bike up and give it a good ol' shake Wink
Claud 14.7 to 1
PostPosted: 22:03 - 08 Nov 2004    Post subject: Reply with quote
Try jumping it
With choke if you think you need it.
Check obvious things kill switch/fuel/fuses
STUNTMAN2000
PostPosted: 22:19 - 08 Nov 2004    Post subject: Reply with quote
Do NOT TRY JUMP STARTING IT !!!
If you bike runs a CDI system, if you use jump leads say from a car then you are gona fry your CDI, the car batt runs around 500ma this will fry your CDI coz bike batt's don't carry anything Like a car one.
Thing you can try is Bump Starting it, if your batt is low and you start it off the button it will turn the engine but may not produce enough of a good spark to light the fuel, this will then cover your plugs in fuel and cause it to "FLOOD".
The best thing you can do is, take the batt off give it a good charge overnight and try it again.
If it don't work pull off a plug lead and stick a spare plug into it rest it against the side of the engine and turn it over, see if it sparks a good "White" Spark, If te spark is blue then it is a little bit weak but should still run fine, if the spark is orange then it is too weak to run when in the engine and is probably breaking down under load.
If you get a white or blue spark, then get a can of WD40 Spray and get someone to spray a good squirt of it into the air intake or up the exaust while you turn the bike over.
WD40 burns more easy and faster than anything, this WILL start your engine if you are getting a spark.
If this works and then stops again when you stop spraying the WD40 then you have a fuel problem.
Get beck to me and I'll tell you how to fix that Mr. Green
Good Luck, and let us know how you get on.
Claud 14.7 to 1
PostPosted: 00:26 - 09 Nov 2004    Post subject: Reply with quote
Oh cak sorry I meant push start it. Push start it .
Although I have jumped mine off a car, and its fine. A few times now. Thumbs Up
Always get them mixed up because you have to run with the bike then jump on it, then release the clutch. Smile
Yeah push start is safer. And very effective in my experience.
STUNTMAN2000
PostPosted: 00:36 - 09 Nov 2004    Post subject: Reply with quote
I have jump started a few myself in the past off a car and worked, until the time I tried and broke my old GSXR400 cdi and it cost me £150 to get another one built Embarassed
But never again. Push starting (Bump starting) is always worth a shot with a low batt as you are not using the starter and it helps the engine produce it's own spark with the alternator spinning. Thumbs Up
Lone-Wolf
PostPosted: 01:55 - 09 Nov 2004    Post subject: Reply with quote
Wotcha.
Eh ?
Sorry. lost me there. Where does the ½ amp bit come from ?
It's the propellant that burns well - they have to use butane now 'cos of the CFC ban - holes in the ozone and all that.
'Easy start' or some other Ether based product is useful.
alternatively - give THIS a click.
Cheers.
L.W. - www.moonshiners.org.uk
Wave2k
G's Stalker
PostPosted: 02:16 - 09 Nov 2004    Post subject: Reply with quote
spray a little damp start on the plugs and take it to a big hill
Ducati 1299 Panigale
2009 Corvette C6 z51
Demonic69
The Pink Rhino
PostPosted: 10:47 - 09 Nov 2004    Post subject: Reply with quote
I had the same problem with my RF. Take out the plugs and clean them, give the battery a good charge, then fiddle with the chike while starting. Carb cleaner is also a good thing to use. Just spray it while you're trying to start. you usually have to take your airfilter out, then spray directly into the carb openings.
jay12329
Dr. Evil
PostPosted: 11:16 - 09 Nov 2004    Post subject: Reply with quote
I left the batery to charge over night. Took a little bit to get it started this morning, fiddleing with the choke and throttle until it got going. Def going to get an optimate.
J
Big Pete
PostPosted: 16:18 - 09 Nov 2004    Post subject: Reply with quote
Theres nothing wrong with using a car to jump start a bike engine I`ve done it loads of times. Both systems are running 12v DC, negative earth, so unless you get the leads the wrong way round there isnt a problem.
A car battery is capable of putting out in excess of 100 amps without any difficulty (for cold starting) and and a decent bike battery will put out 40 no problem. A cars alternator will almost always deliver more power (typically 600 Watts vs 150-200w on a bike), but that wont affect your bikes electronics unless you have a short.
Trust me, I`m an engineer
GarageOfPower.co.uk
map
Mr Calendar
PostPosted: 16:29 - 09 Nov 2004    Post subject: Reply with quote
Glad you got it started Thumbs Up
Just wanted to add a check for the future - make sure your kill switch hasn't been knocked.
It can be easily done manoeuvering a bike around.
It also can be very embarrassing Embarassed
Robby
Dirty Old Man
PostPosted: 22:57 - 09 Nov 2004    Post subject: Reply with quote
I've jumped many bikes off cars.
GSXR400 CDI units are just shit.
ZaphodBeeble
PostPosted: 00:50 - 10 Nov 2004    Post subject: Reply with quote
I've jumped a few bikes off cars and car batteries. An electronic or electrical device will only draw the power/amps that it needs. As long as the voltage is right then the amps make no diff. Thumbs Up
Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders.
Fortuna
PostPosted: 02:58 - 10 Nov 2004    Post subject: Reply with quote
Sorry but a car battery would not fry your bike if it's a 12V system.
Current is drawn as required by any electronic device if the voltage is the same. The higher Amps/Hour mean if you jump it from a car battery it will last longer. I have a high amperage car battery in my shed for those cold mornings when the bikes being a bitch. Jump a car from a bike battery though and it will melt.
Current is pulled and not pushed.
stryker
PostPosted: 13:32 - 10 Nov 2004    Post subject: Reply with quote
Yeah I can confirm, recently I had to start my bike using a jump from a 12v car battery many times.
jay12329, I had the same issue as you, it was the battery, enough juice to turn the engine but not enough for a spark. If you had tried jump starting it from your car battery this would of proved it.
Now what?
STUNTMAN2000
PostPosted: 11:46 - 11 Nov 2004    Post subject: Reply with quote
Hmmm.....Maybe I am wrong then, I am only talking from past experiance and trying to stop someone else from breaking theirs.
So if you have a 12v batt on your bike and you jump it off your car 12v... So you now have 24v going into your bike why not just have a 24v batt on the bike in the first place.
Also if your jumping off your car while the engine is running and it's alternator is kicking out (17 for example) so not only are you running double the volts it's supposed to be but the power from your car's alt is also pouring straight into your bike and not even going through your regulator / rectifier (That limits your return voltage to the batt)
But instead you are sending the whole lot into your CDI unit ?
Does not seem a good plan to me.
I am not trying to cause an argument here as I am new to the site, but I would like to find out more on this so can we some more opinions please (for and against)
Cheers Guys Thumbs Up
Demonic69
The Pink Rhino
PostPosted: 15:54 - 11 Nov 2004    Post subject: Reply with quote
Surely you'll only get the output of your battery as you're running them inline, not paralell? You're putting a charge from the car, into your battery, then into your bike?
Big Pete
PostPosted: 17:15 - 11 Nov 2004    Post subject: Reply with quote
You dont have 24v you have 12v still if you have used the jump cable correctly , the batteries are connected in parrallel (making one larger battery) not series (which would make a higher voltage battery)
..... Thumbs Up
The car alternator reg/rec will limit the alternator output voltage to 14.5 - 16 volts, if your bike battery is dead the voltage will be pulled down as it charges, when it is fully charged the voltage will stabilize at whatever the reg/rec setting is. Dont forget this is still a parrallel conection not a series one.
The bike reg/rec doesnt control the output of the battery, it controls the output from the alternator.
GarageOfPower.co.uk
Fortuna
PostPosted: 18:44 - 11 Nov 2004    Post subject: Reply with quote
Just to reiterate what the guy above said.
ohms law says that parallel voltage stays constant.
Parallel is positive to positive and negative to negative
Series is Positive(bike battery) to negative(car battery) etc.
I'll grab my multimeter and do this with some pics.
Do you know what the only difference between a car and bike battery is?
It's capacity. That's it no other difference.
It's an urban myth that a car will blow a bike up.
Fortuna
PostPosted: 19:25 - 11 Nov 2004    Post subject: Reply with quote
Forgot to mention that a bike also puts out roughly 14.5v to 16v when running.
All batteries require a higher voltage to charge. Thats why your headlights dim slightly when you turn off the kill switch.
One last thing, whenever you add things like LED lights etc. and need to add a resistor it should be worked out on the running voltage and not the standing voltage.
kasandrich
PostPosted: 16:52 - 12 Nov 2004    Post subject: Reply with quote
I'm afraid the others are right Stuntman2000 Thumbs Down
!2v is 12v, and as long as you connect up jump leads right (neg to neg, pos to pos) then 12v is all you have, you should not need to run the car to jump a bike.
Richard
CBR1000FM
Ninja
Caption Abuser
PostPosted: 18:12 - 12 Nov 2004    Post subject: Reply with quote
absolutely - done that myself, nothing like the embarrasment of a 16yr old saying 'what about this mister' as he points to the kill switch.....resting in the 'off' position.......after I've spent 10 sweaty minutes 'tracing' and 'testing' faults/ connections etc etc ETC Very Happy
James
4 wheels transport the Body ... 2 wheels transport the SOUL
Fortuna
PostPosted: 22:33 - 12 Nov 2004    Post subject: Reply with quote
Correct, the higher capacity of the batter means you shouldn't have to start the car. Unless of course the car has a low battery as well.
The last post was made 21 years, 345 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 132.87 Kb
